Parts and more parts
Re: Loosing Water And Dont Know What To Do
If you might have a head gasket leaking gases into the cooling system, that will push the water into the colleciton bottle and out onto the ground while driving. You can verify this by going to a radiator shop and have them do a gas test at the radiator cap, while the truck is running, to see if they get carbon monoxide gases out of it. I had this issue on my 84 and it turned out that I had bad head gaskets. That iw when I retired the 305 and put in a 350 to upgrade.
Frank |
