03-06-2012, 08:24 PM | #1 |
Serpentine belt set up??
Has any one found a system that can be removed from a stock chevy and bolted on ?? Without running a reverse flow pump rad etc? I would like to get away from the V belt system.. I looked at a early TBI truck that should work but I have not tried it..
WHo knows maybe can add A/C later LOL
62 long box with a little SBC http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
03-06-2012, 08:37 PM | #2 |
Re: Serpentine belt set up??
all serp. systems make the pump turn an opposing direction to a v-belt system. no need to change radiator just make sure u use a pump from a serp system so 86ish and up. tbi on up to 99 vortech will all work on any small block with accessory holes in front of head so like 72?ish on.
96 s10 static drop smooth and blue 99 silverado nothing stock layed out on 24s 65 c10 bagged patina driver http://www.myrideisme.com/Garage/az480 half-assed build thread http://67-72chevytrucks.com/vboard/s...=1#post5206828 |
03-06-2012, 09:02 PM | #3 |
Like the gentleman above said just about any SBC setup will work. Just go to salvage yard and take off the whole accessory drive. Be sure you get one off of a vehicle without smog pump etc, On Rock Auto they sell a AC delete pulley and then you can add a compressor later. If you look on Kwik Performance website they have plans to put a Sanden compressor on if you dont want the R4 compressor. Here is mine. SBC drive off of a 94 truck. (I have mine on a BBC)
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
03-06-2012, 09:34 PM | #4 |
4.3 V6's will fit too
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
03-06-2012, 10:53 PM | #5 |
ElCampo, what did you do to put the sbc acc. drive on the big block???
03-06-2012, 11:00 PM | #6 | |
oldschoolblazer@yahoo.com
03-06-2012, 11:10 PM | #7 |
IF YOU look close at his pics there is an adapter made out of 1/4in plate. its really a good idea. too.
03-06-2012, 11:18 PM | #8 |
here is a good article that is done on a BB but you can get
an idea of how the set up works http://www.carcraft.com/techarticles...e/viewall.html |
03-06-2012, 11:38 PM | #9 |
Bought my set up on ebay for about $190.00 including shipping couple of years ago. Mine came with everything: a/c compressor, alternator, p/s pump and all the hardware. Sand blasted all the brackets and pulleys and repainted. Replace the alt, reseal p/s pump and install a a/c delete pulley. Check out my pic it looks brand new. You can pay for a new GM set up for about $1200 on Summit or Jegs. Check out this article: http://www.carcraft.com/techarticles...e/viewall.html
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
03-07-2012, 10:17 AM | #10 |
Either get a used set up off a 4.3 or 350 or go to a dealer and order part number 12497698 with a/c or a 12497697 without a/c
MY ADDICTION STAN THE MAN |
03-07-2012, 10:48 AM | #11 |
Thanks for the info. I was thinking of the LS water pump.... all good, I did find a pretty cheap compared to others March kit for 210 that will retiain all of my stoff and retro to the new style belt.. It is much cleaner looking as well. I am going have the engine by end of week and have to get going on something LOL
03-07-2012, 10:51 AM | #12 |
Must be nice lol
03-07-2012, 11:55 AM | #13 |
Well I was wrong the kit is 349 with the PS set up.. I amy just run the v belts for now and PC the parts I have. Spent a ton of money and need to stop with the upgrades as the v belt works fine. I just wanted to clean it up a bit. Well always a winter project when I install the new 9 inch rear end
03-07-2012, 02:32 PM | #14 |
I found my setup on craig's list for around $100. This was without the alt., waterpump, and p/s pump.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
03-07-2012, 02:53 PM | #15 |
So that is a metric pump, at least I would think so. The other issue I have is that I am already plumbed for the hydro boost and those line are made I know I can get a SAE to Metric adapter for the pump to solve that issue. Will a older alt take a new style pulley?? or would that have to be changed? Is that a long or short W/P ? Thanks for the info guys
03-07-2012, 02:56 PM | #16 |
I ordered everything for a 1993 c-1500 with a 350.
03-07-2012, 04:31 PM | #17 |
greg65 Did you make your own p/s hoses to fit the metric fittings on the pump to the gearbox? Or did you use late model p/s saginaw fittings (o-rings) on the early style pump? Which p/s gear box did you install on your truck. Havent decided which way to go on mine...Thanks...
03-07-2012, 04:44 PM | #18 | |
All are -6an Russell Performance numbers: 632610 powerflex hose six feet length 1) 648050 -6 to 11/16" -18 inverted flare 2) 640380 -6 to 5/8" -18 inverted flares 3) 620421 -6an 90 degree endura shine hose ends Parker #6 XHBU-SS The box is for a 1972 Chevrolet truck with Rez Manufacturing adaptor plates.
03-07-2012, 05:18 PM | #19 |
What are the prows of having a serpentine belt set up instead of a v belt?
03-07-2012, 07:02 PM | #20 | |
03-08-2012, 10:52 AM | #21 |
Thanks. It is taking a lot longer than I thought to get it back together.
03-08-2012, 04:27 PM | #22 |
Well the wife askes me why I am looking all over craigs list for parts. I explain to her what I am doing, shes says show me ... so I show her a pic of the GM kit as well the march kit. She says I got money saved buy the march kit it looks better... I about fall off my chair... Gotta love her... and she is a KEEPER HA HA ... I hope to score one at the good guys show this weekend if they are there..
03-09-2012, 08:28 AM | #23 |
I am putting hydroboost on mine too. The fitting that screws directly into your old pump unscrews and threads right into new pump. Not sure if that is the question you were asking or not tho. And the adapters for BBC came from Kwik Performance. 139 bucks.
03-09-2012, 09:04 AM | #24 |
These systems are usually easy to score if you don't mind grabbing an entire engine. TBI trucks went serpentine in '89 I think. Same year cut over for F-Body's (Camaro / Firebird).
06-07-2012, 12:56 PM | #25 |
Does this setup bolt to the heads at all? I have camel humps goin on my motor with no acc. holes and rally would prefer to mount a serp. setup that doesnt bolt to the heads.
