Old 03-07-2012, 09:57 PM   #1
dennislbrooks
dennislbrooks's Avatar
auxillary battery tray
If you do not mind moving your washer bottle you can install one of these. If you use a continuous solenoid that turns on with the key ON, it will be a functioning auxillary battery.
dennislbrooks is offline   Reply With Quote
Old 03-09-2012, 12:01 AM   #2
OldCreek
OldCreek's Avatar
Re: auxillary battery tray
That looks like a nice kit....who makes it?
I bought an aftermarket tray previously but it seems to becoming more expensive.
This time around I made my own by cutting up an old, passenger side original tray and retrofitting it.
But, I like this set up...looks good.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-09-2012, 10:33 AM   #3
Burt4x4
Burt4x4's Avatar
I added one to my 72K5. I got mine long time ago from an online sale. Can't recal what it was pulled from but at one point in 67-72 GM did install a Driverside batt tray.
That kit looks good ~ drivers side is just a mirror image of the pass side tray
Oh and I use www.hellroaring.com Iso/Combiner to keep both batts charged and the second batt is 100% backup or I can combine the batt power when winching heavy loads. Not cheep but awesome product!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-09-2012, 11:10 PM   #4
dennislbrooks
I make the side brackets and purchase the tray.
Old 03-10-2012, 09:38 AM   #5
dennislbrooks
Also, the radiator does not have to be removed to mount the supports as it bolts or metal screws to the front radiator support. One or 2 holes need to be drilled but it also uses an existing hole for lineup. Attached is a pic of the solenoid setup. positive battery cable goes to the solenoid connection seen. White wire is from the ignition ON. 10 gauge black on far side goes to the main battery --- fused.
Old 03-10-2012, 09:48 AM   #6
dennislbrooks
Shown where I found the best place to remount the washer bottle in my k10.
Old 12-03-2022, 02:21 AM   #7
kehstr
kehstr's Avatar
I know this is an old thread, but really am hoping you have the measurements for the side panels on the battery tray?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 12-03-2022, 04:24 AM   #8
dennislbrooks
Measurements or a template? I may have a pair without the tray. Rockauto used to have the trays for a 67-72 c/k10.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
Old 12-03-2022, 05:48 AM   #9
Richard
Not trying to stifle OP's brackets. While hard to find OEM aux battery trays can still be found. Just post a WTB in parts. IMO better options for an aux battery than a relay/solenoid. Dual output alternator or an isolator.
Richard
Old 12-03-2022, 11:46 AM   #10
kehstr
kehstr's Avatar
Mostly measurements. There was an old thread on it, but cannot seem to find it
@Chad's Fab
Old 12-08-2022, 10:55 AM   #11
jeffahart
jeffahart's Avatar
You can buy one already built and painted. A quick bolt in.
https://www.holley.com/products/exte.../parts/BBA72AX
j
White K20
jeffahart is offline   Reply With Quote
