Headers and Starters on 1969 BB engines
Hi gents, 69 BB, Hooker comp headers, Tuff Stuff mini starter:
Headers fit fine, but rear pipe touches the starter housing. I can't rotate towards the block or the solenoid contacts it. Do I have this starter on upside down? Can I flip this over - and will the housing clear? Any experience with this would help. I have an inquiry in to both companies, waiting for a response. I'll buy another starter if necessary....... Cheers, Ron ![]()
69 396BB Turbo 400 Fleetside, 3:07 Gears 2.5" & 4" drop 2020 Silverado 2500LT 2006 Subaru Forester 2019 Chevy Cruze |
Re: Headers and Starters on 1969 BB engines
Had same problem no matter where i rotated it hit here's what i did and been great every since
http://www.ebay.com/itm/SBC-BBC-CHEV...item1e6affee32
1971 rs camaro under the knife ls3 6 speed swap 1970 396 big block shorty fleet 67 clone 2010 rs/ss camaro |
#3 | |
Member #1049
#4 | |
Much appreciated! Ron ![]()
I also had to rebend the brakeline. Just to close.
#6 | |
How much clearance did the DB Elec give you? I may order it from ebay (not available here in Canada).
#7 | |
Member #1049
not exactly sure on the clearance dimension.. (it was a couple years ago) but I think it was more than 1/2 inch. (I have Doug throrley Tri-y headers on it)
Is this the powermaster you have? http://www.ebay.com/itm/PowerMAX-Che...item588e6d65b6 If so it is essentially the same as the DB I have.. Most of these I have seen are just a clone of an OEM GM starter from 1994 and up.. I bought the DB because it was less costly than my local auto parts store for a rebuilt one |
#9 | |
#10 | |
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
No problems thus far
good deal
#13 | |
http://www.ebay.com/itm/Powermaster-...item564875e3bf The top of this is quite large, but this is a "clockable" starter, so if I rotate towards the engine I get roughly 1/2 inch clearance. If I trimmed the end off the inside bolt, and machined a little from the front of the housing (at the top) I could gain 1/2 inch more. PITA. $192 Canadian too. I can get the DB for $110 - but it won't be returnable. I'm really inclined to go this way simple because you and weircc have done it.
#14 | |
a staggered mount (the Db is a staggered mount) - I do see another bolt hole in the block.....
#15 |
the powermaster is probably for both 168 and 153 tooth flywheels and the db is 168 only and why isnt the db returnable? you will have to pay shipping but its returnable. try contacting them directly they have a website they may give you better deal not going through evilbay
#16 |
For future dealings you can use a gm pgm starter under # 6449 make sure you ask for the shorter bolts that go with it. In michigan they sell for $110.00
last I checked. It is the same starter that powermaster sells under #9200 for much more. Yes it cleared my hooker super comps. |
#17 |
[QUOTE=weircc;
Ordered the DB electric via ebay, had it in four days (just north of Calgary, Alberta Canada). Even with shipping was less than the powermaster, which I have a $213.00 credit for. Plan to spend it on heat shield. Lots of header clearance, now re-routing the brake lines ha ha. One step forward, 2 back. Thanks all. Ron ![]() PS Anyone add an additional trans cooler?? Nows the time....
#18 |
i think you will be happy
