Changing Throttle Body's
I bought a 2004 5.3 with a DBW throttle body, can I change out the throttle body to a cable throttle body or do I need a new intake too?
A guy with a truck
Re: Changing Throttle Body's
Should be a direct swap onto your intake. Minor re-wire and PCM programming will be required as well...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
I had a cable intake and a drive by wire intake and the vacuum line that was behind the throttle body was different. I am unsure of the year model on the intakes I have though
#4 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Thanks for the advice,this is all new worlds for me! I'm looking forward to getting this in my S10 it should be a better DD than the 327 I had in it.
Always a work in progress
I did the same thing and instead of trying to find inserts or a new intake I just epoxied some bolts(head down) in the empty holes. I had to round off the the bolt head but I kept it as a snug fit and then put some epoxy in the hole, put the bolt in the holes and then some more epoxy around it to keep it steady. It holds pretty good and the bolts are hidden by the engine cover any way.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
#7 | |
