Old 03-30-2012, 09:43 AM   #1
67cheby
67cheby
67cheby's Avatar
Thinking about going with an aux trans cooler for my 700r4 looking for input
in the thought line of keeping my engine compartment as Smooth as possible i am thinking of getting rid of my transmission cooling lines running off of the radiator and mounting an auxillary cooler under the cab on the inside of the frame rail , I am looking for input , Is this a good idea, will it keep my 700r4 cool enough, what brand/style/length, i have never used one before so just looking for some input !
67cheby is offline   Reply With Quote
Old 03-30-2012, 09:48 AM   #2
67cheby
67cheby
67cheby's Avatar
Re: Thinking about going with an aux trans cooler for my 700r4 looking for input
also does anyone know what this is for on my radiator ?
Old 03-30-2012, 10:50 AM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I have heard both good and bad....I would not remove the radiator cooler lines, I would add an additional cooler to the system to help with the heat transfer. Dont chance it with a 700R4.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 03-30-2012, 12:15 PM   #4
n2billet
Village Idiot....
n2billet's Avatar
I used a 30' finned heat sink cooler on my truck without any problems (I've had the tranny checked twice) if I was you I would mount the cooler on the outside of the frame away from the exhaust.
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 03-30-2012, 01:06 PM   #5
67cheby
67cheby
67cheby's Avatar
Thanks Keith i think this is what i am going to do !
Old 03-30-2012, 09:09 PM   #6
haulnrat
haulnrat's Avatar
Looks like a fitting for a heater hose with a threaded in plug. Is the plug plastic.
I would look for remote transmission cooler with an electric fan too make sure you get enough air flow.
haulnrat is offline   Reply With Quote
Old 03-31-2012, 08:53 AM   #7
chipflyer
chipflyer's Avatar
I am building a 36 chevy street rod and just had a good discussion about this with my local and well established transmission shop. I want to do the same thing as you and asked the owner who has been in business over 30 years and he said running just the external finned heat sink type would be fine, and not a problem UNLESS I planned to drive the car in the winter. He explained that those finned style coolers will not allow the fluid to be warmed to the minimum operating temperature when it's cold out and that is not a good thing. Just something to consider.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 03-31-2012, 09:17 AM   #8
big_al_71
big_al_71's Avatar
We installed mine on the radiator support in front of the radiator and has been there since 08..here is a picture.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-31-2012, 11:17 AM   #9
67cheby
67cheby
67cheby's Avatar
thanks everyone for the info i do appreciate it !
Old 03-31-2012, 01:31 PM   #10
oldgoalie
It is agood idea to have the trans fluid warm up if you are going to drive it in cold weather. TruCool coolers work good. Their LPD series allows the fluid to flow through only a small portion of the cooler untill it warms up and then will flow through the rest of it. They come in all different sizes so finding one to fit is pretty easy. I am sure there are other brands out there that work the same too.
oldgoalie is offline   Reply With Quote
