![]() Join Date: Oct 2011
1968 C10 5.3 swap, the easy way.
This is my second LSx swap. First was in the 68 firebird. I learned a lot and wanted to do a simple and affordable swap in my 68 and make it my daily driver. (This was my only vehicle at the time) I have been trying to use as many factory parts as possible. I did all this in my garage and driveway with very limited amount of tools. I borrowed a engine hoist and stand from a friend and got to work. I removed the front end as an entire assembly which is very easy to do. Next I mocked up the engine with all the accy's on including the a/c. Everything to fit which is great because the accy drives from a fbody or any other platform cost alot to convert too. I fitted it with the included truck exhaust manifolds but I had to notch the frame. I ended up using camaro LS3 exhaust manifolds which fit great and no notching is needed. I got them for 80$ used. Next I bolted on the engine and frame mounts. i drilled new holes for the 73-87 truck frame mounts and bolted them down. The driveshaft seemed like it would fit without being modified but it was tough to move the engine forward just using a engine hoist by myself. I ended up using a ratcheting tie strap tied to the engine and frame. I just ratcheted the engine forward until the drive shaft could be installed to the rear end. The mounts have a few inches to adjustablility which is great. Below are my costs. Engine with all accy including computer. 600$ 130000 miles Tranny, got lucky my dad had an extra 4l60E with low miles. Free 2001 Camaro fuel tank with fuel pump, radiator and e fans. 200$ (Edit Do not use a camaro radiator. It will overheat due to not enough cooling capacity for the heavier trucks) A stock replacement worked great for me off of ebay.) Engine mounts 120$ Ls3 exhaust manifolds (80$) Radiator hose (25$) Wiring harness. It came with the engine. To save alot of $$ reuse it. Its basically a stand alone. Its ugly and needs to have everything mounted in the same position of the vehicle it came off of. PCM and battery needs to be mounted on the drivers side. fuse block wiring info http://www.lt1swap.com/underhoodfuseblock.htm All wiring related info can be found on lt1swap.com How I kept it simple. Used dirty dingo adjustable mounts for mid to late 80's GM trucks. They have 2 inches forward and back adjustability. Next I got frame mounts for free from the same era of trucks. [ATTACH] The engine mount on the left is the factory inline 6.(not used in swap) The mount on the right is a late 70's clam style mount(both l and r used in swap. This pic is used to show the difference between mounts. I usually have a extra PCM or two for sale. I will put a base tune with vats deleted and all emission related junk. PM for details. Last edited by vannatta20; 04-05-2015 at 04:01 PM. Reason: just because |
Re: 1968 C10 5.3 swap, the easy way.
more
Goods news
A guy with a truck
Nice! That is the easy way. How far forward is your engine? What trans did you remove? Good work so far
![]() Posted via Mobile Device
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Thats sweet!! I like what your doing and how your doing it. Keep us posted.
Good question on the tranny. I had a factory 3 speed manual. The engine sits more to the rear. Ill take some pics. I am using the factory wiring harness and fuse box.
A guy with a truck
She sounds like a thumper. Stock cam?
Stock cam just sounds mean with no exhaust.
First start today installed in the truck! |
Nice! I like it, but I think I would have added power steering. Oh, and loose the clutch pedal.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
i like your choice in music....
![]() Join Date: Aug 2004
Check out Doc's Blocks for the AC manifold/lines that will work for you.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#15 |
motivation!
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana ![]() instagram - @esso_c10 @projectpawpaw |
#16 |
I got a underdash a/c from a friend for 40$. Going to plumb up the system next week and test it out. If it doesnt cool well enough I will the the vintage air gen 4. Any one have a cheap set of auto pedals
#17 |
those are sweet guages!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#18 |
A guy with a truck
A basic cluster is 3-hole and will fit your gauges perfectly. You can remove the clutch pedal
#19 | |
its about a 1/2 inch to wide. I am going to return it and get the basic 3 gauge panel. How can I remove the clutch pedal? Looks like pivot rod is welded to it. I could take the angle grinder to it... |
#20 | |
its about a 1/2 inch to wide. I am going to return it and get the basic 3 gauge panel. How can I remove the clutch pedal? Looks like pivot rod is welded to it. I could take the angle grinder to it... Also whats the easiest way to plug the gas cap hole. How can I get the gas cap in there and make it stay put? |
#21 |
tell me about those gauges...what brand and where do i get them? they appear to work with the LS engine??
#22 |
Truck and auto performance nut
if the cab gas tank isn't worth saving you could drain it, clean it out, and cut the filler neck off and make a bracket to hold it in place. Then put the cap on and leave it.
Or....fill it with a piece of metal and weld it in, use some filler, and a little primer and your done. You can buy the precut metal piece at various dealers selling parts for these trucks...or make your own.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#23 | |
![]() ![]() quad gauge I paid 90$ amazon mis priced it though.... ![]() |
#24 |
A guy with a truck
The clutch pedal and rod should come out, but you'll have to drop the column and pedal assembly. I've seen where guys will use a piece of flat bar and a carriage bolt through the filler cap to sandwich it in place, if that makes sense. What did you do for a tank?
#25 |
My fuel tank is a hot mess. I tried a LS1 camaro fuel tank and that did not fit at all underneath my bed. The tank is now im my bed tool box... Going to get a custom tank and house the LS1 fuel pump assembly.
