#26 |
![]() ![]() Join Date: Nov 2008
Re: Re : Interior Lights
Youngrodder (or anyone else), have you installed below dash LED lights? Maybe in-the-door LED's? Obviously, these same LED's or maybe smaller ones could work great for that but I'm wondering what kind of housings you'd use in the under dash ones? I'm tinking lights that come on with the door opening but you might want to also have a switch on them to turn on one or the other while driving in case you dropped something or wantd to see something you put on the floor. Ideas?
#27 | |
![]() Join Date: Mar 2007
Here is a link to the lights. http://www.ebay.com/itm/350534923301...84.m1423.l2649 You can also get them in many colors. but I would stick with white. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#28 |
![]() Join Date: Nov 2007
Re: 1947-53 LED dome light retro fit
Whoa That is BRIGHT !!! I like it ! Im gonna let my cousin know about it for his 49 and I will try one for my 72 it looks like it will fit !!!
72 C20 Longbed 05 1500 Z71 |
#29 |
If the under dash lights are tied into the dome system they will turn on when the door is open. If you use a modern GM headlight switch you can turn them both on with a twist of the knob. I also thought about under dash lights but may not. If I do it I may put them under the bench seat facing forward. I ran my dome light wireing across the floor, had to much trouble running it in the roof as original, so the wiring is already under my seat, I just have to tap into it. At this point the 42 LED panel I have is plenty bright enough!
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#30 |
Super bright!
Love the under the dash LED idea. |
#31 |
Just installed the led light on my 50 suburban and it's lights up
good ![]() ![]() Posted via Mobile Device |
#32 |
#33 |
#34 |
Not to take this thread too far off topic but....Youngrodder, have you had any issue with the Dynamat sticking to the roof of the cab? I'm also wondering what condition the metal was re: rust?
My '57 has crystalline rust on the can ceiling. I'm gonna sand it off and seal it with KBS. HOPEFULLY, that will adhere fine and roof temperatures won't give me a problem but I wanted to ask. Posted via Mobile Device |
#35 |
Great post Marc, thanks for sharing!
![]() I ordered the led and will do the same. |
#36 | |
No truck question is off topic..ha ha No issues with sticking to the roof. I had more trouble with it sticking to the inside of the doors... Marc
#37 | |
Your welcome. I'm glad others can benefit. I also just received my rope LED lights. I made mention of this idea in an earlier post. I plan to attach them to the back side of my lower dash panel. This will provide some light for my feet. With these lights you can cut bulbs off of the string, so it will be easy to adjust how bright these are. If I get some juice to them anytime soon, I will post some more pics. Marc
#38 |
Update!!
I purchsed a pair of these LED flexible strip lights. They are cheap ($7.99 including shipping) and come with double sided tape already applied. You can also trim lights off of one end if it is too bright to suit your taste. http://www.ebay.com/itm/350542840298...84.m1439.l2649 I just finshed installing them on the underside of my lower dash panel pointing down to the foot wells. I must say they really help to lighten up the cab. I have eveythting wired up to door jam switches. It all works great. Marc
#39 |
I finally got the led lights for the dome light in the mail. It takes pretty well exactly as long as they say it will for them to get here so be patient if you order them. I think mine took almost four weeks to get. I tried them out on a battery and they are BRITE.
I ordered an eight inch long led third brake light a few days ago that will go up in the back window of the 48 and hopefully only be visible to the outside when it's on. |
#40 |
Possible to get pictures of how the footwells illuminate with his ? .
It sounds good & the price is right . TIA ,
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#41 |
VWNate-
I can get a pic but I will wait until I install my black carpet as it will provide a better idea. Right now when I have the lights on they reflect against the silver backing on the Dynamat. I might throw the carpet in this weekend. Mr48Chev My lights arrived a lot fast than 4 weeks, I must have lucked out but for the money you can't go wrong. Marc
#42 |
Thanx Marc ;
I'm keen to try some of this newfangled stuff .
