Old 04-22-2012, 04:04 PM   #1
zenchal26
zenchal26's Avatar
zenchal26 project 57
Got some work done on the 57. 3" drop axle 3" monos up front 6" monos in rear
zenchal26 is offline   Reply With Quote
Old 04-22-2012, 04:08 PM   #2
zenchal26
zenchal26's Avatar
Re: zenchal26 project 57
Before
Old 04-22-2012, 11:22 PM   #3
Kim57
Kim57's Avatar
Welcome.
Nice looking truck.
What are your plans for it?
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-22-2012, 11:57 PM   #4
Kabwe
Certified Car Nut
Kabwe's Avatar
Looking good man.
Kabwe is offline   Reply With Quote
Old 04-23-2012, 12:33 AM   #5
zenchal26
zenchal26's Avatar
350, 700r4, wide whites
Old 04-23-2012, 02:14 AM   #6
55Cameo
55Cameo's Avatar
Really nice, looks good
Build thread:55 Cameo R!! http://67-72chevytrucks.com/vboard/s...d.php?t=519851
55Cameo is offline   Reply With Quote
Old 04-28-2012, 01:01 AM   #7
zenchal26
zenchal26's Avatar
So I started to mock up the eng and the only way I can get the hugger headers to clear the stock steering box is to move it over twards the pass side 1 1/4" to 1 1/2". How big a deal is this going to be? Are there reasons why I can't mount the eng like this? This is my first build so I'm a newbie to this stuff.
Old 04-28-2012, 08:08 AM   #8
Russell Ashley
Russell Ashley's Avatar
Your truck is coming along nicely.
If you are not set on using headers you can get a set of Chevy ram horm manifolds. They fit with no clearance problems.
Russell Ashley is offline   Reply With Quote
Old 04-28-2012, 10:15 AM   #9
Kim57
Kim57's Avatar
That shouldn't be a problem. The GM did that to make room in production vehicles.
Kim
My build thread
Old 04-28-2012, 12:06 PM   #10
1project2many
FWIW I have an original V8 truck and the cheapie headers I used clear the steering box no problem which indicates the right headers will work with the engine in the stock location. They were removed from a 73 K1500 if you need an application. IIRC I had to move the clutch return spring tab some. But offsetting the engine is a viable option albeit a fair amount of work given the price of a cheap set of headers.
1project2many is offline   Reply With Quote
Old 04-28-2012, 02:14 PM   #11
OrrieG
OrrieG's Avatar
Here is how the rams horns fit. I ran this same exhaust with the stock steering box with no problems. Unless you are racing or running at higher rpm the rams horns flow ok, are more efficient because they hold the temp and quieter because they are cast iron. And they don't rust out.
Old 04-30-2012, 02:52 PM   #12
zenchal26
zenchal26's Avatar
I got it to fit here are some pics and closer ones of suspension
Old 04-30-2012, 03:03 PM   #13
zenchal26
zenchal26's Avatar
more pics
Old 04-30-2012, 04:49 PM   #14
1project2many
The engine's lower than stock which explains the header issue.
Are you going to have room to install a fan belt around that lower pulley? Looks really close to the crossmember.
Old 04-30-2012, 05:24 PM   #15
_Ogre
_Ogre's Avatar
nice looking truck, what forum do i know your name from?
i'm thinking hotrodders.com? the 55-59 thread
nice motor mounts, i had a similar pair in my truck for the past 25 yrs.
mine were flat on top off the frame towards the motor, might explain the header fit problem
looks like you have it cured
lots of 47-55 trucks have the same offset to clear the exhaust and steering box
shop air compressor timer
Old 04-30-2012, 05:25 PM   #16
zenchal26
zenchal26's Avatar
Just enough room to slip it by, made sure of that before I welded everything in. The engine is where it wants to be, set the trans cross meber in first and went from there. Lower center of gravity is better anyway right.
Old 04-30-2012, 05:29 PM   #17
_Ogre
_Ogre's Avatar
just realized that those are my old motor mounts
i see you got them
Old 04-30-2012, 05:42 PM   #18
zenchal26
zenchal26's Avatar
nope yours would not work had to make up my own. yep been on hotrodders
Old 04-30-2012, 06:39 PM   #19
_Ogre
_Ogre's Avatar
want your $8 back?
cost me $12 to ship
Old 04-30-2012, 06:51 PM   #20
zenchal26
zenchal26's Avatar
No, thanks for the offer though
Old 04-30-2012, 08:05 PM   #21
Rude Dude
Rude Dude's Avatar
I agree motor is to low
Rude Dude is offline   Reply With Quote
Old 04-30-2012, 09:03 PM   #22
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Like the C-notch in the rear, did you make it yourself? Cool project!
ChuckDriver is offline   Reply With Quote
Old 05-01-2012, 10:13 AM   #23
zenchal26
zenchal26's Avatar
Bought the c-notch kit from p.o.l. As for the eng being too low this wont hurt anything right?
Old 05-01-2012, 11:35 AM   #24
mr48chev
mr48chev's Avatar
It doesn't hurt a thing, they just look a bit lost down that low but it saves reworking the floorboards.
Old 05-01-2012, 01:16 PM   #25
1project2many
Lower engine will help it handle a little better and won't hurt anything but when it's time to change plugs you're gonna be reacing a looong way down.
