Old 04-25-2012, 04:04 PM   #1
Fastest32
Fastest32's Avatar
12 bolt rear end w/ 2.76 gears
I found a 12 bolt rear end on cl with 2.76 gears in it. The guy says he pulled it from a 50's truck and it has 6 lug axles. I want to buy it, but I'm scared it wont fit my 64. Did the 50's trucks have 6 lug 12 bolts? I dont mind swapping the whole carrier and ring and pinion into mine if thats easier, but I wanna make sure Im not buying a car rear end or something. I told him Id go back and get it tomorrow. Any ideas?
Fastest32 is offline   Reply With Quote
Old 04-25-2012, 04:18 PM   #2
1963c-10
1963c-10's Avatar
Re: 12 bolt rear end w/ 2.76 gears
Chevy has used the 6 lug in trucks since the 30's. Do you have any of the #'s of the axle tubes? Can run the numbers and see exactly what it is. Also...chevelle and camaro used a 12 bolt rearend that was super tough. Had one in my 69 Chevelle SS w/factory 396 BBC.
1964 Short bed trailer
Old 04-25-2012, 04:50 PM   #3
Fastest32
Fastest32's Avatar
Well if it came out of a truck I should be able to swap the carrier and ring and pinion then? I'm gonna go back tomorrow and look at the #'s stamped on it. It had some but I didnt write them down.
Old 04-25-2012, 05:20 PM   #4
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
I don't think they put 12 bolts in trucks 'till '63
Larry
fleetsidelarry is offline   Reply With Quote
Old 04-25-2012, 05:43 PM   #5
Fastest32
Fastest32's Avatar
Do you think its out of something newer? also, did trucks ever come with 2.76 gears? I took off the cover and counted the teeth so I know its a 2.76 ratio. I wish I wouldve taken a picture of it now. I'll go back tomorrow and take pictures of it and maybe that'll help.
Old 04-25-2012, 09:30 PM   #6
fleetsidelarry
Senior Car Nut
well, that gear ratio was another thing that didn't sound right for a truck 12 bolt from the mid 60's. does the cover look like the one in your '64?
the trucks switched to 5-lug in '71 and stayed that way for several years and the passenger car 12 bolts mentioned earlier would have been 5 lug.
My guess is that you'll get a definitive answer in about 2 hours
a picture would certainly help, though
Larry
Old 04-25-2012, 10:13 PM   #7
Fastest32
Fastest32's Avatar
The cover looked a little different. I feel like mine has a more pronounced ridge, like for the ring clearance. The drums on it were huge. I'll post pics tomorrow after I take pics.
Old 04-26-2012, 12:52 AM   #8
Captainfab
60-66 Nut
The truck 12 bolts didn't come out until the '63 model year.
As far as I know, the 2.76 gears weren't available until sometime in the mid 70's. I picked up a 12 bolt a year or so ago that had 2.76 gears, but I don't remember just what year it was. It is entirely possible that this differential has been put together by someone with those gears for some reason. If the housing is the '71 and newer version, then it will be 1.5" wider than the one under your '64.
Old 04-26-2012, 10:26 AM   #9
Fastest32
Fastest32's Avatar
Ok I got some Pictures!!!
Old 04-26-2012, 10:28 AM   #10
Fastest32
Fastest32's Avatar
Is that pitting on the ring too bad to even mess with? Also the number on the other side of the axle said gm82. I think it was 56 1/2 inches from backing plate to backing plate. It was hard to measure bymyself and around the diff.
Old 04-26-2012, 10:50 AM   #11
Fastest32
Fastest32's Avatar
So, apparantly those numbers are just casting numbers and are worthless.
Old 04-26-2012, 08:56 PM   #12
Rich 5150 69
Rich 5150 69's Avatar
Top right side a little to the back on the axle tube will be a series of letters / numbers, those are the numbers we need to determine what you have...use a wire brush to clear the rust off....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-26-2012, 09:26 PM   #13
Fastest32
Fastest32's Avatar
I think I'm just gonna buy it. Its gotta be a truck rear end right? Im thinking its out of a 70s truck. From what I hear if it's a truck 12 bolt the insides should fit in mine right?
Old 04-27-2012, 12:31 AM   #14
Captainfab
60-66 Nut
Measuring backing plate to backing plate is not an accurate way to measure a differential. The correct measurement is WMS to WMS (Wheel Mounting Surface) If that differential is from a '71-'82 truck, it will be 1.5" wider overall than the original differential in your '64. The '63 to early '70 truck differentials measured 62" WMS to WMS. Also if this differential was installed in a 50's truck, it likely has leaf spring mounting pads on it. If your '64 is a Chevy it should have trailing arms with coil springs. Installation of this differential may require some cutting and welding, but thay depends on just what year of differential this one is. Is there a reason you are wanting 2.76 gears? IMO those are just too tall of gears for a truck. If you're after better mileage, your mpg's may actually suffer from too tall of gears. Higher gears doesn't automatically mean better mpg's.
Old 04-27-2012, 02:16 AM   #15
Fastest32
Fastest32's Avatar
Old 04-27-2012, 02:17 AM   #16
Fastest32
Fastest32's Avatar
Captain, I don't plan on using the whole rear end. I was planning on only using the carrier and ring and pinion. My truck right now has a 250 with the sm420 and is screaming going down the highway. Second gear won't even get you out an intersection. I figured the 2.76 gears would work, do you think it's too drastic of a change? I don't have a tach so i don't know how high I'm revved going down the highway right now, but i don't even like doing it cause it feels way too high. I measured my ratio just by spinning the wheel on a jack and came up with 3.73's. Also the guy wants $100 bucks for the whole rear end. The cheapest I could find a ring and pinion is like 200 a that's for 3.42or 3.08s. Maybe id be better off finding a junkyard set? I wouldn't know what trucks to start looking in though.
Old 04-27-2012, 08:21 AM   #17
koda360
koda360's Avatar
I figure $100 ain't bad for a 12 bolt, given that it's not seized up... If you wanna do all the work, swap in the 2.76s and try it. If too tall at least you can make an educated guess as to what you want. Then you'll have a 12 bolt for a later project, some 2.76s for a lighter vehicle, and a set of extra axles for something...... You could always part it out and you might make a few bucks. Only thing you'll be out is time. Just my 3 cents!
1960 C-10
2000 Dakota R/T
1966 Fury I 2dr post
1984 Big Bronco
2002 Durango SLT (Bride's Ride)
koda360 is offline   Reply With Quote
Old 04-27-2012, 08:57 AM   #18
tincan1966
tincan1966's Avatar
Maybe I approach things differently, but you can effectively change the gear ratio as simply as changing rear tire size, too. If, for example you originally have 3.73 gears with original tires that are say, 30" tall, installing 32-33" tall tires changes the effective ratio. Somewhere I have a formula for figuring all of the numbers. If memory serves,my Suburban has 3.73 gears, but by going with the 275/70/15 tire, my final ratio is closer to the 3.40's or maybe even 3.20's. I chose my tire size, by inputting my desired engine RPM(@ cruise speed-65 mph) and original gear ratio into the formula, and then let the math tell me the tires size I needed.
tincan1966 is offline   Reply With Quote
Old 04-27-2012, 04:37 PM   #19
Fastest32
Fastest32's Avatar
So I went ahead and bought the rear end. The code on the axle tube is raa 276w81. The w is fainter and a little smaller?
Old 04-28-2012, 12:03 AM   #20
Captainfab
60-66 Nut
In my opinion, you need an engine that develops a good amnount of torque right off of idle to be able to pull a high gear like a 2.76. But then again the actual diameter of the rear tires will have an affect. I don't think the 250 makes enough low end torque to make this work like it should, but you may be happy with it. My choice of a gear would be the 3.42's, or an overdrive trans, to keep the highway rpm's down.
Old 04-28-2012, 08:12 AM   #21
Fastest32
Fastest32's Avatar
Well they were pretty cheap. Alot cheaper than changing the motor or transmission. If they're too high I'll start looking at junkyards or somewhere else. Eventually this truck will get a small block and an automatic transmission and the 3.73 will go back in it. Until then I'd like to be able to drive it to work at a decent rpm. I will update after the install. Hopefully they'll work out.
Old 05-12-2012, 04:20 PM   #22
Fastest32
Fastest32's Avatar
Update: I installed the gears in my truck today!! Huge improvement. On my way to work I was running 3000rpm @ 62mph, on my way home, after gears, i was doing 70mph @ 2500. I had to use my old spider gears so that my axles would still fit, and i had to run to the junkyard to Pick up a pinion flange that would work with the new pinion. i went into a panic when i realized my old pinion flange wouldn't work and nobody had a pinion flange. I went to the pick and pull and found a 12 bolt with the right flange under the first truck i looked under! Oh and i got it for $10 too!
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 05-12-2012, 11:36 PM   #23
Captainfab
60-66 Nut
The highway rpm's sound good. How is it on take off from a stop? Can you still take off in 2nd gear?
Old 05-13-2012, 12:42 AM   #24
Fastest32
Fastest32's Avatar
I can still take off in second gear. Still drives good around town. I only drove it today,but so far so good.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 05-13-2012, 01:30 AM   #25
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Thanks for posting an update.
I'm looking at possible 3.07 for my 65.
Right now with my 25" tall tires, a 3.90 rear, and the sm420, I can start off in 3rd, and I keep wanting to shift above 4th when only doing 45mph.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
