Old 04-27-2012, 07:08 AM   #1
n1njazx7
What headers to use?
I'm looking to get a det of headers for my 72 C10. I'd like to get a set of mid-length headers to keep as much ground clearence as I can. I'm not having any luck finding any listed for a 66-87 truck so, I'd like to know if anyone has tried a set of 88-95 headers on 66-87 truck?
http://www.ebay.com/itm/160749951469...84.m1438.l2649
It looks like to me that they would fit. Anyone have any ideas?
n1njazx7 is offline   Reply With Quote
Old 04-27-2012, 09:58 AM   #2
RexDodge
Re: What headers to use?
If you don't get a set of shorties I will guarantee you'll loose ground clearance no matter what brand/year you go with. I you are bagging then it's a concern. If you are not then just how low are you going? Mine will be 4.5/6 and I expect to use extreme caution with speed bumps and such. I have Hooker Super comps with a 1 7/8" tube. Even with the 1 5/8" tube I believe there would be issues. Shorties would be the way I would go if I changed. I had mine left over from a drag car I parted out so I just slammed them on. We'll see how it goes.
RexDodge is offline   Reply With Quote
Old 04-27-2012, 10:25 AM   #3
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I've only started my truck just one time since I installed these headers, but so far I like them a lot & they sit within the frame rails.
http://67-72chevytrucks.com/vboard/s...d.php?t=314836
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 04-27-2012, 11:47 AM   #4
RexDodge
WOW! Those are REALLY nice! The fit looks amazing.
Old 04-27-2012, 01:41 PM   #5
n1njazx7
I forgot to say I have Trick Flow heads with angle plugs. That's what is making this harder to find a set of headers.
Old 04-27-2012, 05:16 PM   #6
passthebuck
I have them installed on trick flow gen 1's with angle plugs & they fit great.
passthebuck
#5642
Old 04-27-2012, 07:34 PM   #7
Jeffs70
Jeffs70's Avatar
I have these on mine other then mine do not have the chrome, the only modifications I had to do was to the frame, slight trimming and they worked great.
Jeffs70 is offline   Reply With Quote
Old 04-27-2012, 10:19 PM   #8
n1njazx7
So let me get understand you correctly, you did get the 88-95 headers to work on your 66-87 truck?
Old 04-28-2012, 01:08 AM   #9
Jeffs70
Jeffs70's Avatar
Yes just had to trim the frame back a bit and all fit fine.
More Pictures
Old 04-28-2012, 11:04 AM   #10
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
If I were to go with headers I'd use the Clear Image too.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-28-2012, 12:40 PM   #11
Leftlane
Just curious as to whether these would also fit with a little frame trim.
http://www.ebay.com/itm/Header-GMC-T...d8e8a9&vxp=mtr
Stainless with the (better?) ball flange; and similar money.
These are manifold replacements; and made to bolt up to an existing Y-pipe.
But if you had the Y-pipe stubs and flanges???
Looks like 1 3/4" though, not 1 5/8".
1971 C10 SWB 350/350 A/C PS PDB
Leftlane is offline   Reply With Quote
Old 04-28-2012, 09:57 PM   #12
Jeffs70
Jeffs70's Avatar
Those type there require you to cut away and modify your engine stand towers. or maybe buy some different ones.
Old 04-29-2012, 08:34 AM   #13
Leftlane
Okay, I see the number one and two cylinder tubes go under as opposed to over.
Is that what will interfere with the frame mount?
Old 04-29-2012, 09:35 AM   #14
Jeffs70
Jeffs70's Avatar
Yes exactly
