Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Electrical
Closed Thread
Old 04-12-2012, 02:32 PM   #1
rou
I can see the finish line!
rou's Avatar
$17.99 Cargo Lamp to LED Third Light conversion
To read the original thread and discussion on this topic go here- LINK
So I have been seeing all of these LED conversions for our trucks, which makes a lot of sense. What I don’t understand is why they are so expensive. I did a little research and came up with a few components that were too cheap not to try out. Here is what I came up with:
I first researched LEDs and came up with these from Lightobject. $12.45 all in
I then went to Radio Shack and bought terminal and bus strips. $5.54
So I took a new light I got from Brothers (nice piece) and started drilling.
1971 C20 402BB
In the process of a rebuild now
Our first Build - '71 C20 LWB
rou is offline
Old 04-12-2012, 02:33 PM   #2
rou
rou's Avatar
Re: $17.99 Cargo Lamp to LED Third Light conversion
After drying overnight, I wired up the terminal strip
and BANG!
This light is really bright! I’ll take it over the $129.99 LED conversion being sold by an aforementioned vendor.
1971 C20 402BB
rou is offline
Old 04-12-2012, 10:22 PM   #3
rou
rou's Avatar
These LEDs have a built in current limiter so you just run a brake line to the positive, find a ground and they act as a third brake light. I did not touch the cargo light components, so this is a cheap way to have one fixture provide both a cargo lamp and a third brake light.
1971 C20 402BB
rou is offline
Old 04-13-2012, 02:33 PM   #4
rou
rou's Avatar
Originally Posted by Pop's C-10 View Post
If you can solder, you can daisy chain tha power leads & grounds together to eliminate the T-strip & make less of a wire bundle...
That is nice mod..
I may end up soldering the wires when I finally install the fixture. For now the terminal bus was a quick way to test the project. Thanks for all comments!
1971 C20 402BB
rou is offline
Closed Thread
