05-08-2012, 09:22 PM | #1 |
Need help decoding a VIN number
Hey all,
I was hoping to find a little help in decoding the VIN for my truck. It is a 67 GMC Camper Cruiser and the VIN is: M2590DP4100B Thanks for any help! |
05-09-2012, 12:06 AM | #2 |
Re: Need help decoding a VIN number
Seems out of order for my data. WAG it to be a V6 Wideside 2500 '68. Serial number 41008. Built at Pontiac plant.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-09-2012, 05:13 AM | #3 |
I think your missing 2 C's.
C=2wd??????? M= v6 2= 3/4 ton 59=127inch longbed OD= wideside P= pontiac assy plant C= 1967?????? 4100= build number B= GVW 6001 to 10,000
CHEVY/GMC VIN DECODERS |
05-09-2012, 09:30 PM | #4 |
Thanks Bruceman! The info I posted came directly off of my title so I hope that is not incorrect. However, I do believe I am missing 2 C's because my truck is a 67 (at least according to the title and grille with GMC stamped into it, and it is also 2wd) However, it is listed as having a GVW of 5,000 pounds and you are saying my VIN calls out 6,000 plus......now I am really confused.
05-09-2012, 09:47 PM | #5 | |
Vintage 4x4s
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
05-09-2012, 11:27 PM | #6 |
VW is on the right track, let us know what door jam vin says. Nice lookin truck BTW. And nice badges!!
05-13-2012, 10:58 AM | #7 |
Hey Bruceman!
I will definately post some pics of the VIN badge and SPID in glovebox shortly. I also believe there were 2 C's missing! |
05-13-2012, 03:32 PM | #8 |
05-13-2012, 05:27 PM | #9 |
Cool, I saw a few pics of your truck with the front drop spindles and it looks GREAT!!!
05-13-2012, 08:10 PM | #10 |
Here is a pic of the SPID in the glovebox and the tag inside the drivers door jamb.
05-13-2012, 09:12 PM | #11 |
CM2590DPC4100B... Way to go bruceman1968 !! Hats Off. Knew something was wrong just couldn't put it together that night. Now when do we see a picture of this wonderfully equipped truck? Special paint too....
05-13-2012, 11:03 PM | #12 |
Here she is undergoing the transformation: Old parts are starting to pile up!!
05-13-2012, 11:31 PM | #13 |
Thanks SS Tim, Nice to get that shout out from you. You nail this stuff all the time. The 67 gmc has a 14 character vin. I have never seen a decoder for it anywhere so I made my own using the GMC sites and GM reference materials.
Erik, Really nice lookin truck! I think that's 515 vermillion poly, which would be a special order on the 67 GMC.
05-14-2012, 11:43 AM | #14 |
Vintage 4x4s
Wow Erik, thats a rare and special truck. It looks to be a special order truck. While its yours to do with as you choose, I hope it doesn't loose to much originality. If you want a modded truck you may want to start with something less unique. Thats a collectable piece the way you found it. I am really curious about your hydraulic steering since mine has that listed also but it has a conventional style power steering gearbox. It is believed that the 67's all had ram assist if they had power steering. What does yours have?
Special K, here is an example of a Custom with the fancy side badges. I'm surprised to see the 305 on the SPID, that would be base for a CM vin. Actually, I'm surprised to see a SPID at all, most 67's GMC's didn't have. I have one similar to Eriks and wish it was that original. Mines been repainted, was originally aqua or mint green. I bought this for parts but I am thinking more and more about restoring it.
05-14-2012, 06:38 PM | #15 | |
This truck was special ordered in NY and I have the documents showing that (they were in the glove box). I wish I still had the 10 1/2' camper that was ordered with it...that would be pretty cool thing to have. It shows it was ordered Maroon (Vermillion is suppose) however, I posted pics on a different thread and someone commented that was not the original color since the firewall and door jambs are more of a silverish color (Fawn perhaps). Also, the body mouldings were removed at some point and the holes filled. I do not know why. There are some areas that show possible evidence of a repaint so I am not really sure what to think at this point. Someone mentioned a cab swap but I do not think that is the case unless the glovebox door was switched since the SPID matched my title and VIN. The VIN plate in the door jamb does not appear to be original though.... You mentioned the word collectable. How collectable do you think it is value wise? I guess I should hang on to the original parts like the rear and the split ring rims? They are laying in the garage taking up space now... Sorry to ramble but sometimes that is the best way to get the most information. |
05-15-2012, 07:49 PM | #16 |
Vintage 4x4s
it looks like the cab vin plate has the original rosette rivets and it matches the spid so it must be original. Why did you think it wasn't? The paint comment on the other thread was made without knowledge of the special order and custom paint option on this truck.
As far as collectability, it really isn't that common since 1) it is a 67 gmc 2) its a camper cruiser, and 3) most importantly, it is a special order truck. You will see 100 or so smallblock later years for every one of these. It is desireable to me and a select few others so value wise not as valuable as some other trucks but it certaily is more unusual. If you were closer id be throwing you dollar figures. Posted via Mobile Device
05-15-2012, 08:24 PM | #17 |
From what I have seen and read over the years I'm willing to bet that the fawn is correct and original for your truck. The rivets look fine. From the pictures I'd say you have a nice, fairly original truck. If it were me I'd start tracking down the moldings and think about putting them back on. Campers are out there and if you wanted to, a period rig could be reassembled.
