06-07-2012, 12:52 PM | #1 |
15x12 & 325/50/15 MT's
Is anyone running that wheel and tire combo? If so, I'd like to see pics because I'm thinking really hard about running them next year when I swap out rears.
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
06-07-2012, 03:45 PM | #2 |
It's Better With Nitro
Re: 15x12 & 325/50/15 MT's
That might be an in between size from what most are running. I run a 16x12 wheel and Hoosier Pro Street radials on the street, which ends up being a similar size to the MTs you're asking about. I run a 15x10 wheel with a set of 315/60 - 15 MT drag radials at the track. Here's a photo of my 16x12s with the Hoosiers...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
06-07-2012, 05:52 PM | #3 |
"Where were you in '62?"
Front wheels: Weld Racing Draglite 90-Series Wheel 15 x 7 Rear wheels: Weld Racing Draglite 90-Series Wheel 15 x 12 Front tires: Falken Visa 912 Tires - 758 P215/65R15 96H Rear tires: Mickey Thompson Sportsman Pro Tire, 29x15.50-15LT
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 06-10-2012 at 08:33 AM. |
06-07-2012, 08:35 PM | #4 |
I am running a 15x12 with a 315/60/15 MT DR. essentially the same tire just a 30" tire vs a 28" tire. When I get home on tue I will try to get some pics for you.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
06-07-2012, 09:03 PM | #5 |
I love the look of this tire and wheel combo.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
06-08-2012, 12:50 AM | #6 |
Do you guys have any side shots?
06-08-2012, 12:08 PM | #7 |
~Rest In Peace~
im running 15x6 fronts and 15x14 rears with 31x18.5x15 MT sportsman drag radial
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-08-2012, 08:40 PM | #8 |
Willie,
Doed MT call the sportsman a drag radial? I ask as I 5hink the compounds are different. In other words, I think the dr is actually softer. Posted via Mobile Device
06-08-2012, 10:33 PM | #9 |
Mickey Hides:
Street: Sportsman Pro Sportsman S/R Radial http://www.mickeythompsontires.com/street.php Strip: ET Drag ET Drag Radial ET Drag Sport Compact ET Drag Jr. ET Street ET Street Radial ET Street Radial II ET Street Radial Pro http://www.mickeythompsontires.com/street.php Hoosier Hides: http://www.hoosiertire.com/ http://www.hoosiertire.com/pdfs/speccat.pdf Coker Tire Pro-Trac Hides: http://www.jegs.com/webapp/wcs/store...+Tire+Pro-Trac Take one set off the front and leave 4 in the back... Pro/Foot
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 06-08-2012 at 10:44 PM. |
06-08-2012, 10:50 PM | #10 |
Truck and auto performance nut
Well mine are the 315/60-15 MT ET Street d/r's...mounted on a 15x10 rally wheel with 4.5" b.s. The 1st pick shows 15x8 rallys (4" bs?) with 275/60-15 BFG's.
I need to get some different wheels with a 5.5" to 6" b.s....or even more if they're over 10" wide.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
06-09-2012, 12:11 PM | #11 |
68GMC, That's pretty bad a$$ looking. I've been looking at tires the last several days and, I might just go with a 15x10 and the 325/50 because, I like some sidewall bulge and I don't think I'll have it with the 15x12's. But still a 15x5 w/ a 205/75/15 and a 15x10 w/ a 325/50 will still look good and I should have to mini tub it.
06-09-2012, 12:14 PM | #12 | |
06-09-2012, 12:38 PM | #13 |
Brandon Street Car Mafia Last edited by limitedstreetoutlaw; 06-09-2012 at 12:50 PM. |
06-09-2012, 12:47 PM | #14 |
what b.s. are those? and did you make that bed cover?
06-09-2012, 12:52 PM | #15 |
7 1/2 bs......and yes its home made
Brandon Street Car Mafia |
06-09-2012, 01:06 PM | #16 |
I like the cover, looks clean. I need to get everything tucked up under too...as you have there. These wheels only come in 4.5" or 5" bs....so I may have them modified or just replace the whole set with something else, but I still want my track tires on a separate set of rear wheels that match the main set.
06-09-2012, 01:22 PM | #17 | |
06-09-2012, 10:30 PM | #18 |
Mean Green
Once you go 12's you never turn back! lol
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
06-10-2012, 07:34 AM | #19 |
We are putting that exact combo on my son's street Strip Truck. Here are a few pics.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
06-10-2012, 11:31 AM | #20 |
What brand and style wheel are you running? I originally wanted Weld Rodlites but, now I'm thinking about Centerline Convo Pro's instead.
06-10-2012, 11:40 AM | #21 |
Weld Draglites.
06-10-2012, 11:52 AM | #22 |
djracer, where did you find blem M/T's and how much cheaper were they? What is the backspacing on the wheels?
06-10-2012, 12:29 PM | #23 |
Mean Green
Dang Kevin I like the wheels you and JR picked out.
Correct me if I'm wrong. One of the great benifits to a 12" wide wheel is to help square up the tire for a better better contact patch. Posted via Mobile Device
06-10-2012, 05:09 PM | #24 | |
last time. I had a 33 10.5 w tire on a 10 inch wheel before but now I will have them on a 14 inch wheel. Thanks for the props on the wheels. I hope to get back on his truck real soon.
06-10-2012, 05:13 PM | #25 | |
I don't remember the exact back spacing but its not much. We are building a narrowed 9 inch for the truck.
