Old 06-06-2012, 02:12 PM   #1
66 lwb cs
66 lwb cs's Avatar
How to shorten the mounting brackets on bench seat?
I did the search thing and alot of people have mentioned it but found no write ups or pics of what and how it was done so here goes. Has anyone one shortend the legs on the stock bech seat and if so how'd you do it how did it turn out and any pics would be appreciated. If you have a link to this somewhere where it has already been covered then that would be appreciated too. Thanks in advance.
66 C20 LWB CS 327/TH400 A/C
66 lwb cs is offline   Reply With Quote
Old 06-10-2012, 01:47 AM   #2
66 lwb cs
66 lwb cs's Avatar
Re: How to shorten the mounting brackets on bench seat?
Anyone?
Old 06-12-2012, 05:17 AM   #3
scum1
scum1's Avatar
hey im actually gonna do this tomorrow on my truck..cut the seat and shorten the steering column..im not that tall only 5'10 but i like to sit a lil lower and a lil further from the wheel..im just going to mark my line while the bench is in the truck on all the legs, and then pull it out cut x amount out and weld it back together. i can take some pics while im at it
scum1 is offline   Reply With Quote
Old 06-12-2012, 05:40 AM   #4
MikeS.
MikeS.'s Avatar
Please do, I'm thinking of doing the same thing.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 06-12-2012, 03:24 PM   #5
scum1
scum1's Avatar
well i went out there today and shortened the column, and it made me think that now i dont wanna lower the seat that much..i might be able to get a lil lower when i get it upholstered by just having them use a firmer thinner peice of foam on the seat and the back rest. the column helped with the space alot..
Old 06-12-2012, 05:46 PM   #6
brokenspoke
brokenspoke's Avatar
I put a 90'3 truck seat in my 65....I now sit in it instead of on it.....one of the better changes..imho
brokenspoke is offline   Reply With Quote
Old 06-12-2012, 07:06 PM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I have a later model Chevy truck seat that fits well. The frame is fab'ed up.
I dont know if you can just cut some of the frame out and re-weld it? Do you have pics of your current seat frame?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-12-2012, 09:56 PM   #8
KVB
What is a 90'3 truck seat. What truck does that come out of. Does it have the 3 point seatbelts built into the seats?
Ken
KVB is offline   Reply With Quote
Old 06-12-2012, 10:08 PM   #9
hugger6933
I am thinking he meant to say 90's model truck seat. I have seen a number of those in trucks. I have one but it still is to tall for me or at least my belly. I need a tilt with the column pushed down and a shorter seat and maybe a smaller wheel on top of that. I'm 6'2 375 or so. That is the main reason for wanting power steering on the 64 "blue Bob" so I can put on a smaller wheel and I will probably add a tilt to it as well. Don't see many of those on C-60's. I will look at the seat frame tomorrow and see about cutting the stands . I think if there is room you could take some masking tape say 2 inches wide and use that as a guide on what to remove . Once the taped portion is out, then you can fit it back up and weld it back together.
hugger6933 is offline   Reply With Quote
Old 06-13-2012, 07:07 AM   #10
brokenspoke
Ken
Opps I meant to say 90's.....I also used a 80's camero steering wheel...gave me more belly room
