Re: 67 GMC super custom build
one more. The door latch on the inside of the door just clears so opening and closing the door is not affected either.
Nice work, looking forward to seeing the video.
Here is the video. I hope this works so that you can see it.Power Vent Windows C10: https://youtu.be/ngvIPkc8rxc
Pretty cool!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
I am thinking about adding a clock but not in the cluster. Tell me what you guys think about this. I want to take a 65 clock (because it has the same color lettering as the trucks gauges) and work it into the center of the dash pad kind of facing the driver . like in the pic below . What do you guys think?
Not a bad idea, i would have no idea how to do that myself, Fiberglass?
well I ordered a power brake pedal from a member on the board but really wanted to keep my chrome around the pedal. decided this is what I was going to do and here is the final result. its not 100% perfect but down there it will look good I think.
got my new vent windows from Roger Koop today with no latches. They should work nicely with the power vent windows. also got my a-1 electric power window kit. Now I can start wiring it all together in the doors.
![]() Join Date: May 2007
Roger does great work.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Yes he does. they do look nice
I kind of like this mounted just like it is on top of the dash pad. What do you guys think? would you paint it black or the color of the dash pad? Or not do it at all? Looking for opinions. Molding it into the pad will be way too much work so I decided to rule that out.
here are a few more with the gauges in.. I think it looks period acceptable.
original
#15 |
so where is the 67 impala steering wheel now that you have the custom one ?
#16 |
I really dig the power vent windows man, what a great idea.
#17 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Late to the party....great build!!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
#18 |
VA72C10
![]() Join Date: Mar 2008
really like the power vent windows...very cool!
#19 |
Carpe manana
Nice to see the foam installed - looks great!
#20 |
got them together with the frame!
#21 |
Still Learning
#22 |
I got the accessory compass for 67 today in the mail from member 60-66. I have been looking for one of these for a long time.
#23 |
Today I finally finished up my power vent windows so my next problem was my power windows. I had already wired my 67 with a harness that used standard motors and stock style 3 way switch. I bought the kit from A1 electric (and its awesome) but it uses reverse polarity motors. I was stuck on this as I did not want to run relays and such as I am trying to keep it looking period correct and keeping the stock metal switches was a must. a Kit from Watson street works. http://www.watsons-streetworks.com/i...DF/L07W-25.pdf. it lets you use a 3 way switch and reverse polarity motors. Now my window woes are over!
#24 |
today I put the pad on the truck with the clock to see what it would look like. The pad will be the red color of the other pad when complete if I decide to go ahead with it.
#25 |
a few more with the dash back together.
| Bookmarks |
