Old 07-18-2012, 03:10 AM   #1
Ford Assassin
Ford Assassin's Avatar
Talking Added a TVS 1900 Supercharger to my 5.3 Swap...
I recently decided that I'd like to have more fun in my K5. So when a smokin' deal popped up for a Eaton TVS 1900 Supercharger with less than 5k miles on the clock, I jumped on it. It shares the same head unit with the latest CTS-V and new Camaro ZL1. These units are all intercooled too.
I also picked up a the meth/water injection kit that was on the same truck, made by Snow Performance. I hooked it up to a Hoobs switch set to 5 psi. The spray nozzle is inside the air intake tube.
Since this kit was intended for a 2007+ Silverado, it needed a few mods to work on my '86 K5 with a 2001 5.3. Nothing huge, the biggest mods were a 2007+ Silverado water pump to clear the blowers idler, the heat exchanger modified to fit behind my grille, and fabbing a throttle cable bracket since all 2004+ Silverados came DBW instead of throttle cable.
I also upgraded to a Edelbrock 90mm throttle body since the blower is already setup for a 4-bolt 2007+ pattern. Plus you don't want/need any restrictions on the intake side of a SD blower.
A few other mods I did was drilled/tapped the lower intake for 3/8" NPT and 1/8" NPT to allow use of a IAT sensor after the internal intercooler. This way the PCM has the actual air temps entering the engine to adjust the timing better. The 1/8" NPT was connected to a Tee and used for the Hobbs switch and a boost/vacuum gauge inside the cab.
I finished the installed today, still needs a base tune since it will be running as Speed Density with a 2-Bar MAP sensor instead of the factory MAF and 1-Bar MAP sensor. Hopefully I get it in to my buddy's shop tomorrow (Wed) to get it Dyno tuned. I still need to hookup my AEM Wideband gauge too.
Anyway, I'll post updates as the come.
Take care guys!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 07-18-2012, 05:55 AM   #2
Pop's C-10
Pop's C-10's Avatar
Re: Added a TVS 1900 Supercharger to my 5.3 Swap...
That is sweet
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-18-2012, 04:26 PM   #3
Can't kech me
Can't kech me's Avatar
pretty much my dream setup...i love it, now we need an after tune video and 1/4 mile timeslips...
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 07-18-2012, 08:28 PM   #4
Ford Assassin
Just got back from the dyno.....
She made 430/440 HP/TQ to the wheels with conservative timing and 7 psi of boost.
Base HP was 245 on a bone stock 5.3 (no cam, headers, etc).
I think I can live with that....
Cable
Old 07-19-2012, 11:21 PM   #5
Can't kech me
Almost doubled the power!
Old 07-20-2012, 06:28 AM   #6
Ford Assassin
Talking Re: Added a TVS 1900 Supercharger to my 5.3 Swap...
Yup, air intake temps under full boost is only 10 degrees above outside air temp @ WOT too.
I haven't received my copy of the dyno sheet yet, but the torque curve was as flat as a board too.
Cable
Old 07-21-2012, 01:21 AM   #7
snm95ls
That's pretty damn sweet.
Well done.
snm95ls is offline   Reply With Quote
Old 07-26-2012, 01:57 AM   #8
Ford Assassin
A week later and I have surpised a few folks with this old square, especially yesterday against a late model Dodge diesel that was heavily modded on the edge of town. He was prob used to picking on gas trucks, but this time he picked on the wrong square. The look on his face was priceless as I waved just as I was pulling past him.
Cable
Old 07-27-2012, 12:42 AM   #9
Can't kech me
isn't that the best feeling in the world?
Old 07-27-2012, 08:51 PM   #10
79gmcclassic
79gmcclassic's Avatar
we need a video of this supercharged 5.3 going down the road!
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 07-27-2012, 11:46 PM   #11
Can't kech me
Hell yes!
Old 07-28-2012, 12:00 AM   #12
Ford Assassin
I've won countless races over the years in countless cars, its best when they have NO IDEA what just happened in an old truck that isn't suppose to have enough power to get out of its own way.
If it makes you feel any better, it doesn't sound blown.
Working on it, I don't have any friends with a video camera.
Dyno vids:
Cable
Old 07-28-2012, 01:17 AM   #13
Can't kech me
[QUOTE=Ford Assassin;5509275]I've won countless races over the years in countless cars, its best when they have NO IDEA what just happened in an old truck that isn't suppose to have enough power to get out of its own way
Fosho
Old 09-28-2012, 01:52 AM   #14
Ford Assassin
Ordered a RevMax 9.5" Billet converter today, 3600 stall. Might swap to 4.11 gears next to replace the current 3.42's.
Cable
Old 09-30-2012, 02:08 PM   #15
Can't kech me
the stall is really gonna make it come alive. 4.11 gears will make this thing a monster. have any 1/4 mile times?
Old 09-30-2012, 02:18 PM   #16
Ford Assassin
Nope, hopefully first week of November....
Cable
Old 09-30-2012, 08:00 PM   #17
str8axle55
That is pretty sick, I bet it will haul a$$ with the converter and gears.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 12-11-2012, 05:22 PM   #18
Hart_Rod
Hart_Rod's Avatar
Sweet!!! I'm doing something similar and can't believed I missed this....
Hart_Rod is offline   Reply With Quote
Old 12-11-2012, 05:30 PM   #19
Ford Assassin
Converter is in, although now I have completely wore out the factory Gov-Bomb posi.
I have a line on a 9.5" 14 bolt w/6 lugs & 3.73 gears that my buddy will convert to a 5x5 lug pattern. I'll have him weld the tubes to the axles at the same time. Depending on funds, I might upgrade to a Detroit TrueTrac too.
Cable
Old 12-11-2012, 06:59 PM   #20
Pyrotechnic
Pyrotechnic's Avatar
LOL those guys are priceless, running a zillion pounds of boost and looking for naturally aspirated trucks to mess with.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 12-11-2012, 07:19 PM   #21
Ford Assassin
I know its gotta piss them off, those trucks are $50k+ new, plus the lift, rims/tires, and then of course the exhaust and the performance mods....
After all they spent, they get their a$$ handed to them by an old truck that sounds nearly stock (minus the exhaust).
Classic.
Cable
Old 12-12-2012, 11:39 AM   #22
Wasted Income
Boosted Member
Wasted Income's Avatar
Sweet setup. Gotta love a boosted K/5.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-12-2012, 12:17 PM   #23
77ChevySharkBite
77ChevySharkBite's Avatar
awesome!! love to hear that little story haha.
I'm going to have something similar done with mine when its all said and done, only thing different is people will hear what I have, and it'll be more of race me at your own risk.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 12-14-2012, 04:48 PM   #24
OutlawDrifter
love your k5! makes me itch to get mine swapped over to an ls powerplant. i've surprised quite a few cars with my ls swapped 91 z/28. the best was a C6 corvette. he thought he was just going to roll around me on the highway. haha, at the end he was so embarrassed he wouldn't even stop and talk to me.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 12-16-2012, 02:07 PM   #25
flamingbig10
6.0 powered square
flamingbig10's Avatar
looks good, I enjoy seeing peoples faces when they see a 30 year old truck keeping up with them on the hwy, I wish I could of seen that guy face in that new 5.0 when I was pulling away from him, cant wait till mess with them at least once with the
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
