Tailgate trim, best way to shine it up?
I have an 86 Silverado, I need the trim to match the paint, shiny. How do I shine up the trim on the tailgate and the bed corner pieces?
![]() ![]() ![]() Posted via Mobile Device Posted via Mobile Device |
Re: Tailgate trim, best way to shine it up?
If you are speaking of the big trim piece on the tailgate, I believe that is supposed to be a brushed look and somewhat dull (not shiny)
But if you want to shine trim, I use this stuff on all my stainless and other small pieces on the classic cars...best stuff out there in my opinion. Has many other uses too. https://www.wenol-polish.com/ If you are speaking of the lower trim moldings, then you have an issue. During these years of production that is a rubber flexible molding that has that simulated chrome attached (more like plastic) and then it usually has a clear covering over that for protection. Usually over time that clear coating starts peeling off. No way to shine this stuff up really. If it's discolored or peeling it's probably time to replace it. |
At an angle it almost has a chalky look to it.
Frequent Flyer
We polished out the trim on my Dad's 76 including the tailgate band, cab trim below the window, etc.
We polished it out with some jewlers rouge and a buffing wheel then some good metal polishing... it took a little time but looks pretty cool. ![]() ![]() |
#5 | |
![]() Join Date: Apr 2009
i will watch this
1981 Chevy C30 440 Holmes 42K one owner miles |
Jwall isnt there a coating on the tailgate trim?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Some of this stuff will have a clear coating on them (usually the aluminum pieces), which will all have to be stripped to buff the aluminum or stainless underneath.
On these aluminum pieces, once it's stripped and polished, it becomes a continual process to keep it looking nice, the aluminum dulls quickly in the weather without a protective coating and also becomes subjected to corrosion. I wasn't aware you wanted to get that serious with the polishing Bassman. In order to do that you'll have to do what JWall did and break out the rouge and buffing wheels, take the pieces off the truck, and plan to spend days on it ![]() |
I want to do the same thing since the clear coat on my thin tailgate trim is kinda milky. But the damned coating wont come off
Frequent Flyer
We did that trim several years back so I cant remeber about the coating... if there was we cleared that off first.
My dad uses that truck for shows & cruise nights so its hard to say about the durablity of it if it was daily driven. The truck was painted 8 or so years ago & thats when we did it & I think we've only repolished the tailgate & cab bands once. |
Active Member
![]() Join Date: Jan 2004
5bassman, Really sharp truck and doesn't look like it needs a great deal more shining as is. I've ordered a tube of the red polish that Firebirdjones refers to (have the same problem with my 87) Thanks for the post!
Lane 1979 Chevy SWB- (Second owner- Father in Law was first) 1979 Chevy Silverado SWB-Red/Red |
#12 | |
Previous owner did a poor job of putting it on. Posted via Mobile Device |
im watching also
Edited by staff |
i added a tailgate trim that i got from a junkyard to my truck i used something called steel wool from autozone and it worked great it gave it a nice shine but of course its not super shiny since its made to look some what dull i guess from the factory but it cleaned up nice!
#15 |
its designed not to be too shiny so when the vehicle behind you headlights hit it they dont shine back in his face.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
#16 |
Yep, same reason stainless backed rear view mirrors were also phased out starting around 1970, so oncoming traffic didn't get blinded by the reflection.
#17 | |
I've even used it to polish plastic taillight lenses, plastic headlights, you name it and it works on it. I like it because you can take a somewhat dull piece of stainless (say window trim) and use it by hand with a rag and some rubbing, it comes out like chrome with a little time spent. Now if you want to buff something that has alot of scratches then rouge and a buffing wheel is the way to go. |
#18 |
#19 |
![]() Join Date: Feb 2012
#20 |
Thanks! Was going to buy it for my son (pictured) but got it for myself instead. 117,000 miles but engine rebuilt at 79000 with larger cam and pistons, hits a good lick but not too much. Supposedly a $5000 paint job,nice original interior. Nice dual exhaust, a little louder than I like. Might replace with some quieter Magnaflow mufflers.
