![]() Join Date: Nov 2002
NEED 8 lug wheels that will accept pur dog dish hub caps
I need a Set of 16" original 8 lug wheels to help make the Longhorn a little bit more factory. I've got a line on the caps, now I just need the correst wheels. If they need blsted that's fine, I was going to do that whe we painted the rest of the truck down the road.
Thanks, Nik |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: NEED 8 lug wheels that will accept pur dog dish hub caps
Nik - I've got a set of 16.5 x 6.75 from a 3/4t 72 Suburban and a set of 16 x 7. I won't be using both and may part with the 16.5's as I'd rather have a set of the 16.5 x 8.25 wheels that my K20 originally had (I would consider trading my 16.5 x 9.75's for 8.25's...anyone...anyone?). Let me know what time frame your under to acquire a set. Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
I could hook you up with the 16" wheels you want,but shipping would be really high. You're better off finding them close to you.
Everything around me is 16.5 or does not work with the centercap.Special K, if you get bored, find out what it would be to ship it, I'm just about at my wits end looking for stockers around here.
Thanks. |
Honestly,I wasn't offering them so much as stating I can't believe these can't be found. I have a set,but at the moment one is in service (other 3 are earlier Ford) on my '72 until I do suspension work and mount the 8.25 x 16.5 set. I'm sure I can locate a set,but not sure when. I'm hoping you'll stumble on some soon.
Carpe manana
The 16x7's with the outward cap nubs were abundant at U-Pull It last time I visited but that's up here in ABQ....
![]() Join Date: Feb 2011
Found a set on an '84 C20 that worked perfect on my truck, 16x6.5. I think any C20 from 73 ~ 87 will work.
Jeff Horsman 1972 C20 Highlander "C" 1966 Olds 442 L69 four speed 1971 Skylark (GS clone racecar) 494 stroker 1986 Buick T-Type |
Just so you know,the GM 16" wheels are 6.5" wide. The 16.5s are 7".
Carpe manana
Thanks....for some reason I thought my 16's were 7".
6>8 Plugless........
![]() Join Date: Sep 2007
Are you still looking for these? I have 2 if you are.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
