Old 08-18-2012, 11:58 AM   #1
ScottH
ScottH's Avatar
Can I use stock shocks with a 3/5 drop?
I bought a set of drop springs for my truck from CPP. 3" for the front and 5" for the back. The truck has brand new stock shocks in it and was wondering if I can keep the new shocks with this drop? I've read some threads that say yes and others that say no. Some have mentioned installing a rear shock relocation kit.
Any advantages/disadvantages either way?
Any info or suggestions would be appreciated.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 08-18-2012, 12:03 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Can I use stock shocks with a 3/5 drop?
You need drop shocks front and rear at the minimum. If you don't believe me, try driving it and see what happens
An adjustable panhard bar and relocater brackets are also needed if you want the rear end centered and the shocks to function properly.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-18-2012, 01:51 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Depends on what part numbers you have. Stock replacement shock lengths vary significantly between manufacturers, even between product lines. I know that the stock replacement blue Monroes will work, but you will definitely want relocators out back- new shocks or not. Early Classic Enterprise or Classic Performance Parts are good ones.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-18-2012, 04:00 PM   #4
ScottH
ScottH's Avatar
Thanks guys......so if I get the relocators for the rear, do I need other shocks or I can use the stock ones with the relocated mounts?
Old 08-18-2012, 07:26 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Maybe. What shocks do you have?
-Chris
Old 08-19-2012, 12:37 AM   #6
ScottH
ScottH's Avatar
Dont know what brand shocks r in there just yet, picking up the project next weekend.
Once I know I will update the thread.
Thanks for all the info.
Scott
