08-20-2012, 05:14 PM | #1 |
Wiring harness sugestions
OK. It’s about the time to re-wire. I have heard painless wiring harnesses are the best and easiest, but they seem very expensive. I did the traditional Google search and a few companies came up that were quite cheaper. So I am all ears what is the best out there for the price? If painless is the best I do not have a problem spending the money but if there is another company out there that is just as good I would love to hear about them.
08-20-2012, 05:38 PM | #2 |
Re: Wiring harness sugestions
I built a camaro recently and used a kit from american autowire. very nice piece. they may have one specific for your truck?
08-20-2012, 06:02 PM | #3 |
I am bout to pull the trigger on this:
http://www.speedwaymotors.com/Speedw...ess,42872.html I compared it to Painless and it is $200 cheaper and its the exact same thing.
Jason TEAM C10 HOT ROD POWER TOUR
689 Short Step 68 Step Trucks Sold: 70 GMC, 72 K5 Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins |
08-20-2012, 06:09 PM | #4 |
Interested in this as well, but with my experience, I feel like one custom made for our trucks is a must.
Been looking at this guy... http://www.ebay.com/itm/COMPLETE-WIR...#ht_1429wt_906 Any inputs (Not trying to steal your thread!) Last edited by markreed; 08-20-2012 at 06:14 PM. |
08-20-2012, 06:42 PM | #5 |
It's Better With Nitro
The best kits I've used are from Ron Francis.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
08-20-2012, 09:03 PM | #6 |
I used a harness from Rebel Wire and was very satisfied with the quality and installation process.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
08-20-2012, 11:04 PM | #7 | |
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
08-20-2012, 11:09 PM | #8 |
We rewired w the $125 speedway kit. Super easy. It's what we will use on the next project.
Posted via Mobile Device |
08-20-2012, 11:53 PM | #9 |
From what I have been looking at for my truck I'm leaning to the speedway kit to but I'm having trouble hunting down all the connectors but it's the best I have seen for the money and most likely what I will use
08-21-2012, 01:24 AM | #10 |
How about 'EZ wiring'??
- 1967 Chevrolet C/10 SWB fleetside (New Project). - 1969 Chevrolet C/10 SWB fleetside (SOLD) - 2000 Ford Mustang 232 (DD) - 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver) |
08-21-2012, 02:17 AM | #11 |
I'm assuming this kit just has to be adapted with connectors? if so where do you pick up all the proper connectors?
Active Duty Air Force 02'-Current Proud dad of 3 girls, 1 boy and 1 TBD in Dec of 2012 - Lucky Husband "Family owned and operated since 1969" Dad's 66' Custom Camper - Big Family Small Budget |
08-21-2012, 09:51 AM | #12 |
You can get the connectors, the copper things inside the connectors I mean for Hot Rod wires in Dallas. I had found the 60-66 AAW harness the cheapest from Carolina Classics.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-21-2012, 11:41 AM | #13 | |
Good Call on that. http://www.carolinaclassictrucks.com...re-500560.html |
08-21-2012, 12:11 PM | #14 |
Same one I used and it worked like a champ!!!!
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
08-21-2012, 12:52 PM | #15 |
I will be in the market for a wiring harness as well soon myself...
DOes the sppedway kit have all of the connectors, fuse box etc.? Or is it just wires, and from there you are on your own?
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
08-21-2012, 04:44 PM | #16 |
It seems that most of the cheaper harnesses are missing reverse light wiring, how difficult is it to incorporate this? I would think it would be very easy.
08-21-2012, 05:40 PM | #17 | |
AUTO TRANS: You should have a reverse signal wire comming out of your steering column. This wire will have power when you shift into reverse. That power wire needs to be connected to your reverse lights which should already be (case) grounded. Running a seperate ground wire from the reverse light housings to your frame is recommended. Actually, I can't stress how important it is to have a solid grounding system to ensure these old trucks have good strong lights. MAN TRANS: There should be a switch near the shifter or trans with two wires on it. Normally, there is power 'sitting' on one side of the switch and another wire running out to your reverse lights. When you place the vehicle in Reverse, the switch is made sending power out to your lights via that wire. See, easy peasy, lemon squeezy....
08-21-2012, 06:50 PM | #18 |
I got my harness from Speedway for like $135 and it was complete with fuse box,blinker relay, horn relay, and a all the electric connecters like headlight plugs. Each wire is labeled every few inches and there was plenty of wire length. This is the first vehicle I completly wired but I would use it again for the price for sure..
08-21-2012, 07:01 PM | #19 | |
$135!!!!!!!!!!! :OMG: my america autoo wire kit was over 500 buxs but the best i've used
08-21-2012, 07:02 PM | #20 |
it seems like there is a bunch of wiring kits to choose from. so which one would be the best bang for you money?
08-21-2012, 07:20 PM | #21 |
Speedway 20 circuit kit has more than enough to wire a truck and for $150ish, not completely plug and play but around $300+ cheaper than most kits
08-21-2012, 10:31 PM | #22 |
Awesome replies fellers thank you. This makes me confident I will have to pay out the butt to rewire.
08-21-2012, 11:07 PM | #23 |
I used the 12 circuit kit from Hot Rod Wires, but i have nothing power. I built my truck to be as simple as possible. I had no problem with the kit, I enjoy doing wiring.
08-22-2012, 12:06 AM | #24 |
ECONOMY 12 CIRCUIT MINIFUSE WIRING HARNESS Price: $139.99 EA In Stock
View LargerItem #: 91064017
08-22-2012, 11:51 AM | #25 |
Just an opinion- the cheaper the price the cheaper the quality. Installed an EZ wiring harness for a customer a while back. Hands down the cheapest piece of junk I ever tried to wire a truck with. Circuits are completely inadequate, no place to add anything and odd wire lengths/terminations.
There's a reason why Ron Francis, American Autowire and Painless cost more- you get more with the kit and a better, proven/tested product. Those cheap kits on Summit and Ebay are cheap for a reason. From what I've seen, a lesser expensive kit that seems really well designed is the Rebel Wire kit. |
