08-20-2012, 05:42 PM | #1 |
Re: HOW TO: Install HID Lighting & HID lighting explained
Even if they're not illegal, they're still not considerate for oncoming drivers. A regular bulb type headlight housing is built so that all of the reflector surface, and the fresnel lens work together to aim the very small source light the filament of an incandescent bulb out into a usable pattern, with minimal glare. Everything about the way a housing aims the light hinges around the size and location of the filament. HID bulbs are many times larger than the filament of a halogen bulb, and the whole thing glows just like a florescent bulb- there's no thin filament as the focal point of the housing, so the housing can't properly aim/distribute the light. This causes glare for oncoming traffic, and an unfocused light pattern for you to see with.
These are fine for a show car, but they definitly aren't an "upgrade" for a street car. If you have a two headlight system, you also lose the high/low beam function and end up with a beam pattern suited for neither driving in traffic (low beam/minimal glare), or back road/high speed driving where you need longer distance visibility. I'm not knocking the vendor, just stating the facts about how these kits work. I've had friends with drop-in kits in their cars, and they've been pulled over for them. If you want a true upgrade that makes the light output use-able and responsible using HID's, you need to retrofit OEM HID projectors. Halogen bulb on top (note the small filament) vs HID bulb on bottom. The whole HID bulb glows when lit- there's no way a halogen housing can aim the light coming from such a large light source. If your light pattern isn't sharply cut off above eye-level, than you're causing unnecessary glare for oncoming drivers. Regular halogen bulbs/housings can get away with less of a sharp cut off since they're not as bright, but the intensity of HID's makes the cut off necessary to minimize glare to a reasonable level.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
10-10-2012, 10:37 PM | #2 |
what do you think of these http://www.ebay.com/itm/7-HALOGEN-H4...sories&vxp=mtr
11-19-2012, 03:39 AM | #3 | |
-Bruton 1968 GMC long bed 5.7/700R4 --I'd rather push a Chevy, than drive a Ford.-- |
11-30-2012, 03:26 PM | #4 | |
Boss Hogg
This is the truth. Just popping in HID bulbs in non-HID housings is improper and irresponsible! You WILL cause glare and unsafe conditions for others! Not to rain on a sales parade, but it is like any mod, do it right. |
11-30-2012, 03:32 PM | #5 | ||
11-30-2012, 04:28 PM | #6 |
I'm going to see if I can get lightwerkz (http://shop.lightwerkz.net/HID-Projectors) to retrofit some projectors into some 7 inch jeep headlights.
I really dig the Mercedes G-glass headlamps. I'm hoping the retrofit would look something like this:
-- 1968 fleetside - nolimit wide ride front and rear + ridetech |
11-30-2012, 04:47 PM | #7 | ||
Here'a a better explanation of why drop in's cause glare. This is the mechanics of lighting and aiming and everyone agrees on this stuff. In a Halogen housing the shape of the reflector and the design of the fresnel lens work together to aim the light into a cut-off pattern on low beams. Everything about the beam pattern hinges around where the filament is located. The edge of the glowing filament creates the cut-off pattern when aimed out the reflector and lens. When you change the light source size and placement you also change how the light is aimed because the reflector/lens combo hasn't been redesigned to work with the new light source. The aim is determined by the placement and size of the filament, and the glowing filament's edge is the center point by which the aim is designed into the housing. HID's use a completely different way to control the beam pattern. The "shielding" shown in the pic is a flap that drops out of the way to make a full high beam pattern. When it's up it creates the low beam cut-off. A solenoid controls the position of the flap. The aim/shape of the low beam cut-off is not determined by the size or placement of the light source- the edge of the flap blocks off a section of the reflector's light. When you understand these two diagrams it becomes obvious that it's impossible to change the size and placement of light source in a housing without changing the aim and increasing glare. HID's have a huge light source compared to the small filament in a halogen bulb. Drop in's also lose the high/low beam feature because there is only one filament and no flap/solenoid to control the light beam. Quote:
Proper aim is that the beam pattern drops 3-4 inches every 25 feet. This allows for a low beam beam pattern that shines far enough out for city driving in traffic but doesn't cause excessive glare when topping a hill or driving in areas with differences in elevation where oncoming traffic is lower than the opposite lane. No matter how bright your lights are, they need to be aimed slightly down. The brighter the lights are, the more they need a sharp cut-off on low beams.
Tags |
headlights, hid conversion, relays |
