#51 |
Boosted Member
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
![]() Got a bunch of parts from Porterbuilt last week. Now I need to find some time to finish grinding rivets from the rear spring hangers so I can install these goodies ![]() Posted via Mobile Device
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! Last edited by Wasted Income; 09-19-2012 at 01:44 PM. |
#52 |
VA72C10
![]() Join Date: Mar 2008
nice stuff!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#53 |
![]() Join Date: Jul 2010
coming alone nice
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#54 |
Boosted Member
Took advantage of the cool, rainy night to tackle some unsavory work that I've been avoiding on the blazer.
![]() Got all the old brackets/spring hangers/bump stops/etc cut off the frame, and started mocking up the rear suspension. ![]()
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#55 |
A guy with a truck
Looks good! Wish someone had a bolt-in solution back when I converted mine. What's the plan for upper spring mounts?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#56 |
I would feel bad rodding such an original truck too.
Oh wait that's what I am doing. Strike that. How fast was that pass on the vid? I have a 4wd I am converting to 2wd too (not like yours by any stretch) So I am also interested in the rear spring mounts. Or Bag? 4wd frame is more narrow in the rear right?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#57 |
Boosted Member
I am getting away from air-ride on this truck. I am going to be running coil-overs on all 4 corners. I'll show the rear coil-over mounts when I get to that point. Going for more of a handling aspect on this rig, rather than just being low.
#58 |
Boosted Member
Thanks to Bennett-G4L, I have some new shoes on the way for the project.
Coys 18/20 combo. Here's a couple pics of them on his ride.
#59 |
![]() Join Date: Dec 2006
Just got caught up on your build, this blazer is going to be awesome. I love tue porterbuilt parts. I know you will love the wheels and thanks again.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#60 | |
Boosted Member
![]() The vid was a 12.1 et pass if I remember correctly. I didn't get my fast pass on vid that night, which was an 11.95. Regardless if you go spring, or bags, you will need to either buy or fab a spring mount on the outside of the framerails, since as you mentioned, the frame rails are narrower at that point on the 4x4 frames. I am not going with coils, or bags, so my setup will be different than most. The coilover setup will be similar to a 4-link, in the way that they're mounted.
#61 |
Boosted Member
Took some measurements, drilled some holes, and got the trailing arm crossmember bolted in today. Used some PVC pipe to mock up the rear suspension without actually having to have the rear axle in.
![]() ![]() Also clamped the fuel tank up to the frame to check the fit. It's sumped with a -10 fitting. ![]() ![]() ![]()
#62 |
killer
#63 |
Boosted Member
Well the wheels showed up...and since I don't yet have a rolling Blazer chassis, I decided to throw them on my blue C-10 and see how they look. I'm real happy
#64 |
I'm glad you like them, they look awesome on your truck. Enjoy.
#65 |
A guy with a truck
Not too shabby for a long bed
#66 |
oldschoolblazer@yahoo.com
Man I have been away from this section too long ! Subscribed
![]() thanks for bring me back... Wasted |
#67 |
Boosted Member
Called up Rob at NoLimit and ordered up their WideRide IFS setup for the front. Should be here by Friday...can't wait to have a rolling chassis again.
#68 |
i see why you sold me the LS1, very nice
70 Chevelle SS (clone), 454, 350 auto 71 K5 350, 350 auto, 3" body lift, 35's -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |____|__|___] *.*..*.*.._@_ _ _ _ @ |
#69 |
Boosted Member
Didn't get anything done on the truck(s) this week, but I did get to work on wiring the shop, and putting up some lights. Kinda important with the days getting shorter and all...
#70 |
Boosted Member
Haha, my wife just posted this to my facebook wall...at least she has a sense of humor about it...
My WideRide IFS showed up! ![]()
#71 |
A guy with a truck
Nice. That was a fast delivery. Gonna be cool to see this one come together. You planning on running stock inner fenders?
#72 |
Boosted Member
Yes, planning for stock inner fenders.
Pulled the main crossmember out of the box to take a peek. Gotta find some time to start measuring and drilling holes. ![]() ![]() Also picked up a clean 68 Chevy front clip while up in WI this weekend. ![]() Posted via Mobile Device
#73 |
Boosted Member
Hope to be rolling by the end of the week.
#74 |
Boosted Member
Got the crossmember up to the frame last night...after cleaning up the shop, it's all the further I got before the wife wanted me to come in for the night...
![]() ![]() ![]() ![]() Also, while I was waiting for parts to show up, I built this patina'd die-cast blazer. Got it on my desk at work to keep me motivated ![]() ![]() ![]()
#75 |
Since you are going coil overs and have plans for Big Hp are you doing anything more to the frame to increase its stiffness to get all you can out of those front and rear suspensions?
After drilling some holes in my frame(2wd conversion) I can tell they sure arent made out of the same material as later model GM trucks.... Nice build either way |
