Old 09-10-2012, 04:20 AM   #1
savatreatabvr
savatreatabvr's Avatar
Overcome with Frustration!
My 1973 Chevy c/20 454 has never had the power I think it should, I've replaced plugs, wires, cap, rotor, vacuum advance, centrifugal weights, carburetor kit, vacuum hoses! I've adjusted the valves, timing and carburetor so many times I actually thought I had power and then I drove my friends 1974 c/10 454! His truck is bone stock just like mine but it will roast the tires through intersections! Not saying all I want is to do burnouts, I just want it to run the way it's supposed to run! It's always seems to sound like and run on 7 cylinders but all 8 are firing, I've done compression test with no significant differences throughout all 8 cylinders! I know there can't be much of a difference in horsepower from 1973 to 1974, if any, so what am I doing wrong?
savatreatabvr is offline   Reply With Quote
Old 09-10-2012, 05:25 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Overcome with Frustration!
There can be a diff in power between 73-74. remember back then the EPA and insurance company's were cracking down on Detroit hard. A truck motor and passenger motor usually are prepped diffrent. It may be possible that he has a passenger engine in his truck with some more ponies.
A higher stall converter, rear gearing and trans differences can make his feel stronger
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-10-2012, 09:14 AM   #3
tucsonjwt
I drove a 73 C20 454/TH400 for 21 years. That was the fastest vehicle I have ever owned. I know this is not popular with DIYers posting here, but I would take your truck to a shop with an engine analyzer. Not many mechanics have this old school equipment now, since everything is computerized, but I found a shop working on old classic cars here in Tucson who had one and they made the proper adjustments and tracked down/fixed my problems in 30 minutes. I initially went there because I could not pass emissions (just barely) in my current 83 C20/SM465. Also, don't let any mechanic touch your truck unless they have a lot of gray (preferably white) hair, or no hair at all. Unfortunately, this shop no longer works on old classics - just BMWs and Minis, so I guess I will have to find some other knowledgeable old guys.
On a side note, early 454s were noted for having "soft" cams - lobes wore out and caused pushrods to bend/break. This happened on my 73 and a new cam and replaced pushrods fixed the problem. It also happened on my brother's 73 Caprice wagon with a 454, back in the day when it was purchased new and only a few years old. I don't think this is your problem, because the symptoms of this condition were everything was fine until the engine stumbled and refused to run one day.
Also, rear axle ratio makes a big difference in acceleration. Some PO may have changed the rear axle to a low number, like 2:73, in an effort to improve gas mileage - so you might check that. I don't think low ratios help much on 3/4 ton pickups with gas engines since you are hauling around that 1000 lbs. of extra dead weight all of the time, compared to a 1/2 ton.
I did have a 350/350 76 C20 which was in top mechanical condition but was a complete dog. I think a TH400 transmission would have helped on that truck. My current 83 454 C20 will never move very fast with its SM465. This raises the question of whether your transmission is shifting properly.
tucsonjwt is offline   Reply With Quote
Old 09-10-2012, 09:32 AM   #4
LEEVON
Moderator
LEEVON's Avatar
It sounds like you've probably tried it all, but just for kicks what are the specs on your timing? How much initial, mechanical advance and vacuum advance? Are you running manifold or ported vacuum?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-10-2012, 09:51 AM   #5
geezer#99
geezer#99's Avatar
Sounds like you've thrown a bunch of parts at it.
Have you:
1. Put on headers and 2 1/2 inch pipes. Headers are the biggest hp adder on a bbc.
2. Recurved your distributor.
3. Advanced your cam after deegeeing it in.
4. Better intake.
5. Adjusted the apt and secondary air valve on your carb.
6. Properly gapped plugs in the right heat range.
7 Lightened the whole truck. Don't haul more than what's necessary.
8. Perfect wheel balance and alignment.
9. Tires. Narrow are better. Less rolling resistance.
That said you never know what you're gonna get in a stock truck!
Buddy and I bought identical chev short boxes in 1980. 350 turbo 400 3.08 gears. Exactly the same truck. Only difference. Mine was red/white. His was black.
My truck ran circles around his. In a 1/4 mile mine won by 200 feet. I got better gas mileage and never had any warranty work done on it. His was always in at the dealer.
You and your buddies truck both share the 454 motor but his is a c10 and yours a c20.
His is lighter. Wheels, tires, springs etc add weight to yours. His is tuned different from the factory.
You can make yours faster. Just takes a different approach.
Old 09-10-2012, 12:43 PM   #6
tucsonjwt
Meaning no disrespect to others posting here, but my experience is that a stock 454 truck engine is very powerful, and needs no modifications to have plenty of acceleration, assuming you don't have a granny 4 speed behind it like I do.
I think the best first step is to pay a true professional with the proper equipment to check out the engine and transmission first. I am one of those "poke around and see what works" guys myself, but sometimes it is best to go right to a pro - at least to get some (often free) advice. My guess is less than $100 will get you enough professional diagnosis to get you farther to where you want to go than a lot of guesswork. A few phone calls to a few shops in your area would be time well spent, IMHO. If everything checks out OK, some shops promote a Motor Vac, other shops say it only removes soft carbon so it is not worth the money, but you can evaluate - some shops offer money back guarantee if there is no improvement.
Old 09-10-2012, 02:59 PM   #7
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Have you thought about running it on a Dyno ? It'll provide some decent information if your concerned about the make up of your motor
johnnyclack is offline   Reply With Quote
Old 09-10-2012, 03:42 PM   #8
tinydb84
tinydb84's Avatar
My 454 c20 is gutless too. I bought headers, a recurve kit, new carb, and supercharger lol. I'll let know how it runs when I get it all on there
Old 09-10-2012, 04:28 PM   #9
Firebirdjones
They are decent runners with alot of grunt when tuned properly.
I'd guess you have something going on you just haven't found yet. If the engine has never been opened up I'd suspect it could also be a little tired. Weak valve springs, worn cam lobes, loose valve guides, etc etc... If the engine has an oil control issue that might be a clue to some of the things I mentioned.
But again, tuning is everything. Using a wideband is a must to dial in the fuel curve, and the distributor has to be spot on. As long as it's in good shape (dist shaft bushings not worn) then I like to dial in about 16-18 initial and run about 20 centrifical for a total of 36-38 should be fine on todays crap pump gas on a low compression engine like this.
I then like to dial in the "adjustable" vacuum advance to add about 10-15 degrees more timing under light load conditions and hook that to intake manifold vacuum only. Some of these numbers may vary depending on rear gear, transmission, weight of vehicle, octane you prefer to run etc....On a side note, BBC with these dinasour combustion chambers like as much as 42 degrees of timing on the dyno to make max power,,,,but I find that's hard to get away with on the street once in the vehicle, in the heat, crap gas etc....
If everything else is in proper working order it should squirt around nicely for a truck.
My 79 454 1 ton with headers and exhuast, performer cam and intake, along with a sharp tune,,, otherwise unmolested, went 14.70's and it weighs 5300 lbs. It was just as quick as the camaros and mustangs that were coming out in the late 80's
Knowing more about the truck would help. Difficult to diagnose anything on the internet without having it right in front of me.
Firebirdjones is offline   Reply With Quote
Old 09-10-2012, 07:10 PM   #10
thesickc10
First what gears do you have in the rear? If you have a high gear back there your truck isnt gonna move right now matter what you throw at it.
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 09-11-2012, 12:21 AM   #11
savatreatabvr
My truck runs best at this timing mark! When I time it the way it's supposed to be it runs bad! I switched to manifold vacuum because of the pedal response but it doesn't seem to help now!
Old 09-11-2012, 12:25 AM   #12
savatreatabvr
You're right, great answer! I'm not sure what gears I've got but it cruises fine down the freeway so I'm guessing there pretty high!
Old 09-11-2012, 12:32 AM   #13
savatreatabvr
Since the 454 has high miles on it the cam could very well be worn down and the valve springs could be weak to! I replaced a few valve seals recently and the few push rods I checked were straight. Is there a way to check how worn down a camshaft is? A flat camshaft lobe would make it act like it's running on 7 cylinders correct? Now if I put a new camshaft in it won't it wear out everything else faster?
Old 09-11-2012, 01:28 AM   #14
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Cool Re: Overcome with Frustration!
I feel your pain....
I was troubleshooting my 73 C/20 454 Truck for a while.
I first determined that the distributor that was in my truck was not the original distributor GM installed into it.
The correct one I believe should be stamped : 1111213
I have several of these distributors now; all have distributor cam pieces ranging from 718 to 726.
My guess is that GM either changed it over the year, or different vehicle uses.
The same 1111213 may have been installed in factory 454 El Camino's, Chevelle's, Monte Carlo's, and maybe even Impala's and wagons.
Anyways....
Once I obtained the correct 1111213, I cleaned it up, new vacuum advance, and double checked that the advance weights etc were all working properly prior to installation.
Mine has a 718 cam piece.
I dialed it in at 6* BTDC, and left the factory advance springs and weights as they came from GM.
I did grease up the weights on the pole shaft where the weights land and move.
My cam is straight up at TDC.
My truck is a bit sluggish from a stop but once I get into the 45-80 MPH ranges, it really pulls well.
My truck has 120,000 miles on it.
I assume my compression has dropped from cylinder and ring wear.
Thats a start for you.
Things to check :
Compression
Fuel Pump
Vacuum advance piece
Distributor is fulling advancing
Spark Plug Wires
Cap
Rotor
Plugs
Coil
Vacuum hose leaks, brittle &/or cracked hoses
One thing that I have always considered is is whether or not my timing chain is original GM issue.
Those were plastic press on gears over a steel core.
Those plastic gears can :
A: wear
B: break plastic teeth
C: jump time
I initally was of the thought that my power loss could have been from a timing chan that had jumped time.
I am convinced now from my above fixes that this was not the case.
However: I am still going to change to a Cloyes True Roller soon.
One : for reliability
and
Two : to prevent permanent damage or future engine failure from occurring.
Another note :
I determined that the carb (Quadrajet) installed onto my 454 was not the original unit.
I took it off of the 454 and cleaned it as best I could.
At that time I checked all of the securing bolts throughout the carb.
I discovered that the whole thing was loose.
I gently tightened all of the screws that keep it together.
Once reinstalled, that greatly improved the idle, rpm pull, and created a more smoothly operating engine.
I have not done much to it since.
It runs well on a single point, coil, as the factory delivered it.
By the way,
I belive that the factory LS-3 cam is having a 434/434" lift on 112* duration.
I might be wrong.
But, the 434 #'s seem correct in the lower performance it should act like; and it does act accordingly.
Remember,
Back in the early 70's, car manufacturers were up against fuel economy and HP to weight ratios placed upon them by the US Gov't.
I love my C/20.
Rides a bit rough for a daily, but it is ALL Truck!
Hope this is all useful....
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 09-11-2012, 02:07 AM   #15
INSIDIOUS '86
Timing looks almost right it should be about 12 -14 though. See what it shows when it's at about 3500rpm and tell us if the timing mark still moves past that rpm
Old 09-11-2012, 11:49 AM   #16
savatreatabvr
Really I thought the timing mark had to be within the marks on the timing tab? I'll check the timing after it stop raining here in Phoenix, (I know crazy), when this happens it's more like an event, lol! Last time I had the cap off I checked the weights and they seemed to move freely but I'm still considering replacing the whole HEI distributor! Heck I've tried everything else, if that doesn't do the trick I'm replacing the cam! But if I do that I may as well replace the lifters, timing chain and water pump right?
Old 09-11-2012, 11:52 AM   #17
Firebirdjones
That pic tells me a few things. To find out exactly where that is you need a dial back timing light or timing tape on the balancer but a ballpark guess to me that looks like about 16-18 degrees initial.
Keep in mind this has to be checked with the vacuum advance disconnected so I have to ask,,,,is this the timing you have without vacuum assist? If so,,,then 16-18 initial is what I always shoot for. Then I modify the breaker plate to limit 18-20 degrees centrifical.
But here is what I think is going on since you mentioned it runs poorly at the factory timing setting. I'd bet your balancer ring has moved. So you are going to need to verify top dead center with a piston stop and remark your balancer. Even if it hasn't slipped, this should be done on every engine to get your timing "SPOT" on.
Use a simple piston stop that screw into the #1 spark plug. Rotate engine gently until piston touches the stop,,,mark balancer. Rotate engine opposite direction until piston touches the stop,,,,mark balancer.
The exact center of those 2 marks is "ZERO" (top dead center) on the balancer,,,make a perminant mark here and use this as your new indicator to set your timing. I'm betting you'll find that it's several degrees off the original mark and that is probably the beginning of your running problems.
My SCJ was 9 degrees off
Worse case scenario you have a sloppy chain which retards timing and makes the engine sluggish down low, hard to set timing if it's jumping around, but this is a completely different subject. I'd verify that balancer first and foremost, then go from there.
Old 09-11-2012, 11:58 AM   #18
Firebirdjones
Nope, you really need a dial back timing light. With that you simply use the mark on the balancer and "zero" on the tab,,,that's it. Then use the dial to see exactly where it is.
Most of your factory tabs won't go past 12 or 14 degrees. I've found in most all performance applications, and even stock applications, that an initial setting higher than that makes for a smoother, snappier, more vacuum, and all around better performing engine. It also helps engines with camshafts that have a ton of overlap,,they simply won't idle correctly with very low stock like timing settings.
Like I said in post above, 16-18 initial is a good to start with, but you'll have to modify your distributor breaker plate with a larger stop bushing to limit the total advance. HEI's are extremely easy to do this with if that is what you are running. If so I can put up a couple pics of a very simple breaker plate limiter that I've used on them since the 70's. Works like a champ.
Old 09-11-2012, 12:08 PM   #19
LEEVON
Moderator
LEEVON's Avatar
I can't remember the last time I found an engine with TDC at the correct spot on the timing tab. Balancers slip, timing covers are replaced, you name it. I'd invest in a piston stop (Summit has them) and start there. I put a stock replacement cover on my 350 and it was still 8 degrees off. I degreed it with the head off and again with the piston stop, which was pretty accurate. You don't necessarily need a dial-back light if you buy some 360 degree timing tape at the same time as the stop. These are (2) invaluable tools.
You could be at 8 degrees initial and who knows where on advance. If you're not hitting 34-36 degrees you're leaving power on the table.
Old 09-11-2012, 12:08 PM   #20
savatreatabvr
One more question, did my 1973 come factory with an EGR valve? The truck didn't have one when i bought it.
Old 09-11-2012, 12:12 PM   #21
savatreatabvr
Yes it's an HEI and some pics would be great, more the better!
Old 09-11-2012, 12:18 PM   #22
savatreatabvr
I've got one of those old chrome PENSKE 244.2115 timing lights I bought at a flea market for $10, I've always assumed it was accurate but how accurate can it be after 20 years?
Old 09-11-2012, 12:24 PM   #23
savatreatabvr
Yes the vacuum advance is unhooked and plugged when timing is checked. I think it's time to invest in a vacuum gauge, I was told a vacuum gauge will tell me alot?
Old 09-11-2012, 12:24 PM   #24
RPOZ11
RPOZ11's Avatar
One can physically advance a camshaft with an adjustable timing gear set.
Timing can be off when a timing chain jumps.
A replaced camshaft can be a possibility.
You need to physically inspect what you presently have inside your 454.
That will determine what you have.
Guessing will only miss lead you.
I once had an HEI lock up where it did not advance.
EGR: not that I am aware of , no.
My 73 had NO EGR system from the factory.
HO72 build :
2017 SS
Old 09-11-2012, 12:27 PM   #25
savatreatabvr
No but it would be nice knowing exactly how much HP and torque I have!
