09-13-2012, 10:36 PM | #1 |
69-72 Blazer/Truck Yard Sale
Alright guys, I need to move the remaining parts off my two Blazers that I'm not going to use. The list is below. Many of the parts are not Blazer -specific. Prices are negotiable. Reasonable offers will be entertained. Let me know what you're interested in. Prices do NOT include shipping.
In addition to the parts below I have the following: 383 GM Crate Motor - Locked up. Needs to be worked out - $150[/B] NP208(?) Transfer Case off a 700R-4 Trans - $300 2WD Steering Gear tapped for hydro assist steering - $200 Crossover Steering Arm for Dana 60 Axle - $100 Holley Fuel Pump - $70 Painless Wiring! Brand GM 86-89 TPI Mass Air Flow Extra Length Wiring Harness & ECM - Includes manual and wiring diagram - $300 Aftermarket Tubular Motor Crossmember - New - $125 Complete Factory Automatic Steering Column - $35 Factory Front Leaf Spring Shackles w/ Hardware - $20 Leaf Spring U-Bolts, Shackles & Hardware - 3 5/8" Wide on Center x 13" High - $25 Electric Dual Blade Fan - $60 Sanderson Street Rod Headers - Good condition just could use a cleaning / polishing - $150 - SOLD Factory Front Suspension U-bolt Shackles (?) - New Silver Powdercoat - $60/pair Last edited by dujobu; 09-30-2012 at 04:32 PM. |
09-13-2012, 11:15 PM | #2 |
Re: 69-72 Blazer/Truck Yard Sale
Whats the part # on the headers? Im in if they'll work for me.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
09-13-2012, 11:42 PM | #3 |
Active Member
hello,
How much for the fans shipped to 34243? Do you happen to have the schroud it mounted to? Were they hooked up for a ac truck? put my name on them til I figure out shipping costs... Do they both work? betty |
09-14-2012, 06:24 AM | #4 |
Have you looked into what went on with the 383? Just froze from sitting? Seized up while running? Have you pulled the oil pan or heads? I'm really interested,but would like more info. What heads are on it? Was this a crate long block? Have any idea how many miles are on it or it's history? I'd buy this if I had more info. Thanks
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 09-15-2012 at 05:55 AM. |
09-14-2012, 06:52 AM | #5 |
I am interested in the blue tubular motor cradle. Any specs and how much shipped to 33578?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-14-2012, 09:15 AM | #6 |
09-14-2012, 12:23 PM | #7 |
Ill get in line for the 383, ill give you 100 bucks for the short block, you can sell the heads
lmk
09-14-2012, 04:22 PM | #8 |
I am interested in the steering column. I can pick it up too.
Wilson 1972 Cheyenne LWB, 350ci TH-350. Restoration in progress. |
09-14-2012, 07:59 PM | #9 |
Very interested in that motor. Can't say "I'll take it" till I know what you have. But,I'll take it "as offered" pending response.
09-14-2012, 10:01 PM | #10 |
(007) aka Houdini
interested in the flexfans pm sent!
Live life one day at a time! |
09-15-2012, 10:09 AM | #11 | |
I believe it froze from sitting. I bought the truck from VTBlazer and the motor was mounted in it, ready to be hooked up. But I believe it sat for a while (few years?) indoors. Then it came here and sat outside for a couple of months. I pulled the spark plugs and shot penetrant into the holes. Then I put a wrench on the crankshaft bolt and it snapped the bolt off. I have not pulled the oil pan or heads. Not sure of what heads are on it. I'll have a look. No idea of mileage or history. I had limited conversations with Kurt (the guy I bought it from) and now I can't reach him with questions. He's unresponsive.
09-15-2012, 11:33 AM | #12 |
09-15-2012, 11:37 AM | #13 |
As with most of these parts, it came sitting in the bed of the Blazer I bought from VTBlazer. It wasn't hooked up, and I don't have a running motor to hook it up to, so I don't know if it works. I can only assume it does because Kurt had intended on installing it in the truck. He just never got around to it.
I do not have the shroud. I don't know if it was hooked up for A/C. Let me know. |
09-15-2012, 11:39 AM | #14 |
I'll get you a shipping quote and if you get it and it doesn't work (which I don't think will be the case), I'll refund your $$.
09-16-2012, 01:49 PM | #15 |
Thanks for the reply. I know Kurt and can speak with him about this if I need to. I'd like to get this from you now that I know it wasn't locked up while running. I see you're in Wilmington,that's not too far for me. Could you post a picture of the engine? I would like to see how "weathered" it is.
09-16-2012, 03:27 PM | #16 |
Interested in headers pending shipping price if they get to me. LMK.
Posted via Mobile Device |
09-16-2012, 03:34 PM | #17 |
75002 is zip code for shipping price on headers.
09-16-2012, 03:57 PM | #18 | |
I don't know for sure it wasn't locked up while running or not, but Kurt doesn't seem like the kind of guy that would have mounted up and sold me a trashed motor. So I figured it just sat too long. Here are some pics. Let me know when you'd like to come up. I work close to home and am self employed so my schedule is flexible. I have an engine hoist here as well. Do you need the heads and valve covers too? Or just the block? Pics from today…
09-16-2012, 06:59 PM | #19 |
Still looking for a price for that engine cradle (blue)??
09-16-2012, 07:28 PM | #20 |
09-16-2012, 09:08 PM | #21 |
I thought about this more today and have decided to let it pass. If you were local I'd come over and pull the heads/pan to have a better grasp on what I might be getting into. Thanks again for your replies.
09-16-2012, 10:29 PM | #22 |
I'll get in line on the block with the heads
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
09-17-2012, 03:34 PM | #23 |
Ill let zicc get in front ofme as i really only want the block. If he doesnt buy it ill getback in line
09-17-2012, 04:16 PM | #24 |
I will step up second in line for the headers please!
09-17-2012, 05:37 PM | #25 |
thanks PM sent
