Old 09-21-2012, 10:29 AM   #1
Wallee
Cheap performance mods thread!
Post your cheap hp gain performance mods, can be anything as long as its cheap! So we have a figure of cheap I would say anything 200 dollars and under could be considered cheap when you think of what could be spent on a engine.
Wallee is offline   Reply With Quote
Old 09-21-2012, 11:04 AM   #2
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Cheap performance mods thread!
Quite simply in the number one spot should be the black 4 HOLE phenolic 1" carb spacer.
Number two could be long tube headers.
prostreetC-10 is offline   Reply With Quote
Old 09-21-2012, 11:11 AM   #3
Wallee
Carb spacer, any info on how it works? Excuse my ignorance on spacers but how do they work and how much power increase are we talkin?
Old 09-21-2012, 11:28 AM   #4
prostreetC-10
My Carbon Footprint
In a nutshell....they isolate the carb from heat and extend the throttle bores in the base plate by 1". This gives the fuel a little more time to atomize before it is whirled into the intake runners. They can be great for our trucks in helping the low end torque. On general street applications, you should run a 4 hole on both dual plane and open plenum intakes. Must be careful when using on spread bore intakes. Usually will require a thin steel plate for proper mating. It's not that they provide a tone of HP, it's that the HP gains to cost of item is really good. Could be in the 3-8 HP range or more. What I seem to notice is a pickup in throttle response.
Old 09-21-2012, 11:33 AM   #5
Wallee
Nice! Love the detailed information, I might have to look into doing that on my truck.
Old 09-21-2012, 11:41 AM   #6
prostreetC-10
My Carbon Footprint
Actually....I'm going to change the number one spot. I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle. Nice parts that are not properly tuned/setup do not provide performance gains! You can gain/lose tons of hp just by having a carb and timing all messed up!
Old 09-21-2012, 11:55 AM   #7
Wallee
Your right about that for sure!
Old 09-21-2012, 12:08 PM   #8
Coley
Coley's Avatar
Smile Re: Cheap performance mods thread!
Definitely 'ditto' on the tune-up comments posted by Pro-Street. The other mods (under $200) that come to mind would be either an aluminum intake (dual plane) manifold and/or a set of reasonable exhaust headers. These would/could be economical if bought as quality used....and I'm a big fan of that!!!
Now, back to the carb spacer...that is really interesting. I thought that they were best for high rpm advantage, not lower rpm torque? I'm not sure where I got that 'high rpm advantage' info, it isn't from experience either way.
If that is the case.....hmmmm, I'm going to look into that mod a little further.
Question: what about the aluminum carb spacers? (note: it seems to me that the aluminum ones...which there are a lot of....would transfer heat just like the cast or aluminum intakes....so I'm not sure why the alum. ones would be much good). The phenolic ones (non-metal) sure make a lot more sense for heat isolation to me.
Good thread guys...keep the ideas and feedback comin'.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-21-2012, 12:20 PM   #9
geezer#99
geezer#99's Avatar
You're right Coley about the heat transfer part. You know they make them out of wood too!!
geezer#99 is online now   Reply With Quote
Old 09-21-2012, 12:23 PM   #10
C-10 simplex
i agree with the tuneup----get the ignition dialed in precise for the engine.
Also, i think theres transmission modulator thing that can either be adjusted (free) or replaced ($12) to provide higher rpm shift points.
Also, if quadrajet then different metering rods and jets. Cheap.
C-10 simplex is offline   Reply With Quote
Old 09-21-2012, 12:59 PM   #11
dmw319
I have one I just put on my intake (which I think is a spread bore) but I dont have a thin steel plate (there was one but it seemed redundant so I took it out). Truck seems to run fine though? Hmmm
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 09-21-2012, 01:31 PM   #12
BMERDOC
BMERDOC's Avatar
C-10 Simplex is right about the ignition. Timing, not just initial, but how it advances and how far it advances really makes an improvement. More reseach and tinkering involved and the parts don't cost a lot.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-21-2012, 01:47 PM   #13
Wallee
On that quadrajet thing, new metering rods and jets? Any certain kind of jets? Hard to do?
Old 09-21-2012, 02:38 PM   #14
Coley
Coley's Avatar
No, not hard to do..but you have to figure out if you actually need to to begin with and what your particular engine needs.
Usually just a carb rebuild restores a lot of power through the better tuning. After that you have to find out which carb you have....then check to see what rods and jets you have in it. From there you can start with just changing the rods....this leaves your idle, low speed alone and changes your mid throttle.
You can bring on the secondaries sooner by adjusting the 'opening point' on the left (passenger side) of the carb....but be careful. Too much adjustment here will create bog.
Coley
2000 Dodge Ram 1500
Old 09-21-2012, 03:30 PM   #15
Wallee
Coley
Thanks! I might check into that, anyone else liking all these ideas!?
Old 09-21-2012, 04:03 PM   #16
Gumby
Gumby's Avatar
a higher stall torque convertor, best seat of the pants mod ever. I don't come around corners and have to open all 4 for a laugh, just flash to TC to stall speed
Gumby is offline   Reply With Quote
Old 09-21-2012, 04:04 PM   #17
cdowns
cdowns's Avatar
REMOVE WEIGHT a noticable amount of weight reduced give a noticable measureable differance in performance FREE
SYNTHETICS rear and tranny spin easier wheel bearings roll easier
less airflow under a vehicle cause less drag// i've built front air dams for less than a hundred
Old 09-21-2012, 05:50 PM   #18
C-10 simplex
RE: the metering rods/jets etc. Yes, find out what you have for a baseline and then you may only have to go bigger one size and that may have a noticeable effect.
Old 09-21-2012, 10:56 PM   #19
cableguy0
The absolute cheapest power you can get is setting the timing and ignition curve properly. A weight and spring kit for an hei is 9 bucks. In most cases between setting the curve and timing properly its worth 25+ horsepower for under 10 bucks and an hours work.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-22-2012, 12:16 PM   #20
kikkegek
kikkegek's Avatar
I would suggest loosing the ugly flex-fan or fan-clutch and installing a electrical fan.
engine will rev easier, because you loose the heavy fan and you will gain a couple of HP.
the mod is easy and will cost you under $100,-
engine bay will also look much cleaner.
and then make a fanshroud using:
http://www.cadvision.com/blanchas/54...FanShroud.html
kikkegek is offline   Reply With Quote
Old 09-22-2012, 12:31 PM   #21
Gumby
Gumby's Avatar
Ive done em all, inake, carb, ign mods, exhaust
Only mod that was ever an instant "oh my" giggle like a school girl every time, was my TC upgrade. And its only a 2200 stall 12" from ACC accperformance.com
would like a 2800 10" now
Old 09-22-2012, 01:21 PM   #22
prostreetC-10
My Carbon Footprint
What sucks is sometimes removing weight can be very expensive because some things must be replaced with a lighter part. Lighter part = racing part (sometimes) = $$$.
I know what you meant though. I reduced friction by going with this thing they call a rolling.....or roller cam. Not cheap either!
Old 09-22-2012, 05:56 PM   #23
terry b
terry b's Avatar
steal a car with a great motor and put it in your truck.
terry b is offline   Reply With Quote
Old 09-23-2012, 11:53 AM   #24
Coley
Coley's Avatar
Another inexpensive one is to switch from the stock 1.5:1 ratio rockers to the 1.6:1.
This adds lift to the valves which gives the same results as a mild cam changeout...without changing the cam. You would see a noticeable improvement in your low end torque and response straight away.
Ideally the rockers would be roller or equivalent...and you might get a good deal locally (used) or thereabouts.
Coley
2000 Dodge Ram 1500
Old 09-23-2012, 02:54 PM   #25
prostreetC-10
My Carbon Footprint
Just be careful because that can add .030 of lift or more (or less). Don't want to take springs that might be at there limit and send them into coil bind or something else. Granted...there is a lot to take into consideration in this area.
