Old 09-21-2012, 10:58 PM   #1
cubber
Air Ride Questions (coils to bags)
Hello all, I am getting ready to swap my drop coils for some air bags. I have the bags (fiestone 2500s) and an 8 gal. air tank. I am not looking to play much, just raise to ride height an set down at shows. What compressor do you all recommend? Should I ditch the 8 gal tank for a 5 or 3? Also, I was going to do a bolt in c notchh in the rear, and stay with factory a arms in the front. I know I'll need shock relocators all around, and an adjustable trac bar. I would like to hear tips, opinions and input, and would LOVE to see some pics of trucks on bags, but no more mods than a c notch. I want to get an idea of how low I might get. thank you all.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 09-22-2012, 01:45 AM   #2
thekid54
Re: Air Ride Questions (coils to bags)
I would suggest ditching the 8 gallon tank. Unless you have an EDC (engine driven compressor) you'll be pumping air into that thing forever. I'd go with a 5 gallon, heck if you don't plan to play with them much you could probably get away with a 3 gallon. For these trucks I would also recommend a bigger airbag, like the #2600, or something equivalent to that size.
thekid54 is offline   Reply With Quote
Old 09-22-2012, 09:26 AM   #3
andrewmp6
Yeah a 3 gallon would be fine is you just want a simple up and down.Have you looked at http://www.porterbuiltfabrication.co...-Basic-Kit-799
Old 09-22-2012, 11:12 AM   #4
cubber
I had heard that a lot of people use 2600s, especially on the front. I found a good deal on the 25's, and thought since my truck is one of the lighter ones, short step w/6 cyl, I would try them out.
Porterbuilt makes some nice stuff, it just seems to be really expensive.
=MATTHEW
Old 09-22-2012, 12:14 PM   #5
thekid54
It's not so much about the weight capacity. It may seem counter-intuitive, but with a larger bag you'll need less PSI to achieve the same amount of lift as you would with a smaller bag. The lower PSI equates to a lower spring rate which equals a better ride.
As for the Porterbuilt products, they may seem pricey, but I think you get a much better value for your money compared to other manufacturers.
Old 09-22-2012, 12:25 PM   #6
SCOTI
SCOTI's Avatar
I won't disagree that some aftermarket parts are priced inconsistently (bags from one place $95ea; same brand @ another place $65ea), but Porterbuilt offers great products @ a reasonable price. Not the cheapest on the block, but still reasonable for what you get.
To many, quality & support when needed are worth that expense. I recall more than 1 guy choosing a knock-off 'raised crossmember' that wound up going to Porterbuilt for support (and, Porterbuilt helped them!). How many companies would do something like that?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-22-2012, 04:15 PM   #7
cubber
I am thinking about putting the stuff I have (bags and tank) on CL and just starting over. I really want the Porterbuilt stuff, and no more work than I need to do to the rest of the truck, I should probably spring for it. I tend to overthink my spending sometimes.
What do you all recommend doing on the front end? I just totally rebuilt it (less than 500 miles) and i hate to ditch it, and I doubt I could sell it.
=MATTHEW
Old 09-22-2012, 05:38 PM   #8
SCOTI
SCOTI's Avatar
Never hurts to try & sell it especially if you have receipts to show minimal age.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
