![]() Join Date: May 2012
Re: DURG's Black 65 C10
Worked on installing the 1-1/4" Porterbuilt (ADDCO) sway bar. The center of the sway bar came out exactly on the lower radiator support crossmember. I drilled out all 4 of the rivets, replaced the top ones with 7/16" bolts, welded on a new mount tab for the lower mounting hole so it lined up with the rear sway bar bracket, and plugged the old mounting holes.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
