Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-02-2012, 07:22 PM   #51
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
Got a bunch of parts from Porterbuilt last week. Now I need to find some time to finish grinding rivets from the rear spring hangers so I can install these goodies
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 09-02-2012, 09:50 PM   #52
VA72C10
VA72C10
VA72C10's Avatar
nice stuff!
Old 09-02-2012, 10:10 PM   #53
Pop's C-10
Pop's C-10's Avatar
coming alone nice
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 09-08-2012, 12:52 AM   #54
Wasted Income
Boosted Member
Took advantage of the cool, rainy night to tackle some unsavory work that I've been avoiding on the blazer.
Got all the old brackets/spring hangers/bump stops/etc cut off the frame, and started mocking up the rear suspension.
Turbo diesel
Old 09-09-2012, 09:30 AM   #55
gringoloco
A guy with a truck
gringoloco's Avatar
Looks good! Wish someone had a bolt-in solution back when I converted mine. What's the plan for upper spring mounts?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-09-2012, 09:46 AM   #56
jjzepplin
jjzepplin's Avatar
I would feel bad rodding such an original truck too.
Oh wait that's what I am doing.
Strike that.
How fast was that pass on the vid?
I have a 4wd I am converting to 2wd too (not like yours by any stretch)
So I am also interested in the rear spring mounts. Or Bag?
4wd frame is more narrow in the rear right?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is online now   Reply With Quote
Old 09-09-2012, 04:51 PM   #57
Wasted Income
Boosted Member
I am getting away from air-ride on this truck. I am going to be running coil-overs on all 4 corners. I'll show the rear coil-over mounts when I get to that point. Going for more of a handling aspect on this rig, rather than just being low.
Turbo diesel
Old 09-19-2012, 10:51 AM   #58
Wasted Income
Boosted Member
Thanks to Bennett-G4L, I have some new shoes on the way for the project.
Coys 18/20 combo.
Here's a couple pics of them on his ride.
Turbo diesel
Old 09-19-2012, 01:26 PM   #59
Bennett68C10
Bennett68C10's Avatar
Just got caught up on your build, this blazer is going to be awesome. I love tue porterbuilt parts. I know you will love the wheels and thanks again.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-19-2012, 01:50 PM   #60
Wasted Income
Boosted Member
Strike that.
I don't feel bad anymore. I'd feel worse spending a bunch of coin on a truck that wasn't truly what I wanted.
The vid was a 12.1 et pass if I remember correctly. I didn't get my fast pass on vid that night, which was an 11.95.
Regardless if you go spring, or bags, you will need to either buy or fab a spring mount on the outside of the framerails, since as you mentioned, the frame rails are narrower at that point on the 4x4 frames. I am not going with coils, or bags, so my setup will be different than most. The coilover setup will be similar to a 4-link, in the way that they're mounted.
Turbo diesel
Old 09-23-2012, 09:28 PM   #61
Wasted Income
Boosted Member
Took some measurements, drilled some holes, and got the trailing arm crossmember bolted in today. Used some PVC pipe to mock up the rear suspension without actually having to have the rear axle in.
Also clamped the fuel tank up to the frame to check the fit. It's sumped with a -10 fitting.
Turbo diesel
Old 09-23-2012, 10:05 PM   #62
Pop's C-10
Pop's C-10's Avatar
killer
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 09-26-2012, 09:29 PM   #63
Wasted Income
Boosted Member
Well the wheels showed up...and since I don't yet have a rolling Blazer chassis, I decided to throw them on my blue C-10 and see how they look. I'm real happy
Turbo diesel
Old 09-26-2012, 10:14 PM   #64
Bennett68C10
I'm glad you like them, they look awesome on your truck. Enjoy.
Keith
66 Suburban
IG: bennett68c10
Old 09-26-2012, 10:58 PM   #65
gringoloco
A guy with a truck
gringoloco's Avatar
Not too shabby for a long bed
-Chris
Old 09-26-2012, 11:19 PM   #66
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
Man I have been away from this section too long ! Subscribed
thanks for bring me back... Wasted
JOHNORO is offline   Reply With Quote
Old 10-02-2012, 11:06 AM   #67
Wasted Income
Boosted Member
Called up Rob at NoLimit and ordered up their WideRide IFS setup for the front. Should be here by Friday...can't wait to have a rolling chassis again.
Turbo diesel
Old 10-03-2012, 11:28 AM   #68
lopemaxx
lopemaxx's Avatar
i see why you sold me the LS1, very nice
70 Chevelle SS (clone), 454, 350 auto
71 K5 350, 350 auto, 3" body lift, 35's
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |____|__|___]
*.*..*.*.._@_ _ _ _ @
lopemaxx is offline   Reply With Quote
Old 10-05-2012, 01:14 PM   #69
Wasted Income
Boosted Member
Didn't get anything done on the truck(s) this week, but I did get to work on wiring the shop, and putting up some lights. Kinda important with the days getting shorter and all...
Turbo diesel
Old 10-05-2012, 03:06 PM   #70
Wasted Income
Boosted Member
Haha, my wife just posted this to my facebook wall...at least she has a sense of humor about it...
My WideRide IFS showed up!
Turbo diesel
Old 10-05-2012, 04:49 PM   #71
gringoloco
A guy with a truck
gringoloco's Avatar
Nice. That was a fast delivery. Gonna be cool to see this one come together. You planning on running stock inner fenders?
-Chris
Old 10-06-2012, 03:57 PM   #72
Wasted Income
Boosted Member
Yes, planning for stock inner fenders.
Pulled the main crossmember out of the box to take a peek. Gotta find some time to start measuring and drilling holes.
Also picked up a clean 68 Chevy front clip while up in WI this weekend.
Turbo diesel
Old 10-08-2012, 08:58 AM   #73
Wasted Income
Boosted Member
Hope to be rolling by the end of the week.
Turbo diesel
Old 10-10-2012, 09:48 AM   #74
Wasted Income
Boosted Member
Got the crossmember up to the frame last night...after cleaning up the shop, it's all the further I got before the wife wanted me to come in for the night...
Also, while I was waiting for parts to show up, I built this patina'd die-cast blazer. Got it on my desk at work to keep me motivated
Turbo diesel
Old 10-10-2012, 10:00 AM   #75
floyd
Since you are going coil overs and have plans for Big Hp are you doing anything more to the frame to increase its stiffness to get all you can out of those front and rear suspensions?
After drilling some holes in my frame(2wd conversion) I can tell they sure arent made out of the same material as later model GM trucks....
Nice build either way
floyd is offline   Reply With Quote
