#76 |
Boosted Member
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
Yes, I'm planning to box a few sections of the frame, as well as some additional stiffening. I'm also planning for a cage, to protect my family, as well as stiffen up an inherently flexy truck.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#77 | |
Too bad you are on the other side of the country from me. Building a bling cage wouldnt be too tough since the roof comes off. |
#78 | ||
Boosted Member
![]() Quote:
#79 | |
![]() Tube bender is a great investment. I have built several cages and full tube chassis crawlers over the years its alot of fun. You may consider getting some tube bending software if you really get into it.... |
#80 |
Boosted Member
Did some work the past couple nights. Got the front clip pulled off the blue truck, and the engine/trans pulled out. It's kinda bittersweet, seeing as I've been driving this truck for 16 years...
![]() ![]() But then sad turns to pumped when I stabbed the drivetrain between the framerails for mock-up. ![]() ![]() ![]() ![]() Ordered up some steel last night to get a transmission crossmember made. Planning to get the front suspension put together this weekend...and maybe the rear axle underneath it if I'm feeling motivated.
#81 |
Boosted Member
So things are working out how I hoped they would. The Porterbuilt trailing arm crossmember will act as both the transmission mount, as well as the front driveshaft loop.
I was worried that if the mount plates for the trailing arms took a beating from the driveshaft, that they would tweak and bend. ![]() Therefore, it seemed like a good idea to box them in. The additional material should make the side plates bulletproof in the event of a ujoint failure. ![]() On to the trans crossmember. Ended up using tube clamps that are typically used for offroad cages. Gotta love easy transmission removal....especially with my history of shelling transmissions. ![]() ![]() ![]() ![]() Going to add some more tube bracing between the original hoop and the trans crossmember to tie it all together.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! Last edited by Wasted Income; 10-24-2012 at 10:42 AM. |
#82 |
Where did you get those tube clamps?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#83 |
Boosted Member
#84 |
Thanks, I've been looking for those to use on my trans x-member.
Looks good!
#85 |
Nice on that trans crossmember...hey Wasted...is that turbocharger setup on your 5.3 a kit, or did you fab that together.
#86 |
Boosted Member
I fabbed it from scratch.
In fact...I'm thinking about selling this setup as a kit to fit a 69-72 C/10. (Not to produce, just this specific setup). I kinda want to build something different to package it a little differently to allow for A/C.
#87 |
Boosted Member
All the parts for the Megasquirt MS3x.
Capabilities include realtime tuning with wideband feedback, electronic boost control, 3-step rev limiter, launch control, traction control capability, progressive water/meth control, bluetooth logging and tuning, 2 stage variable nitrous control, E85 flex fuel sensor control, dual fuel table switching, 2.5 bar MAP sensor. ![]()
#88 |
Just a nother gear head
So are you building your own harnesses for the lsx or do you you use the factory one and modifiy them?
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 ![]() |
#89 |
Boosted Member
I typically take a factory harness and modify it to be a stand alone. However with the megasquirt, I'm hacking up a factory harness for the sensor pigtails, and building a completely new harness.
#90 |
Boosted Member
Made some big progress tonight. It rolls again.
Assembled the front suspension ![]() ![]() Got the rear axle back under it ![]() Then set it on the ground and rolled it back and forth a few times ![]() And some glamor shots. Seeing it sitting on wheels got the motivation stoked up again. ![]() ![]() ![]()
#91 |
WOW that looks MEAN!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#92 |
That thing is going to be killer!
#93 |
![]() Join Date: May 2007
really like the last pic , that's sweet
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#94 |
that looks sweet. I like the stance. is that at your aprox ride height? What front coil over are you using?
#95 | |
Boosted Member
Thanks guys.
I was trying to get away without notching the rear rails, but I'm not a huge fan of the rake, so I want it to sit more level (lower) in the rear. I also want room so it won't bottom out with 3 buddys and a full cooler in the back seat. ![]()
#96 |
Great build, and exceptional talent! Enjoying your work, almost as much as you...
Thanks for taking the time to post up, keeps me entertained
#97 |
I reckon you'll want at least a small frame notch; I'm gonna do one pretty quick here.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
#98 |
Great progress so far. I think a c- notch will have to happen.... especially if your beer cooler has to support your three buddies. LOL. My 72 doesnt have one yet and the rear pings off the frame from time to time.
#99 | |||
Boosted Member
![]() Quote:
Not a ton of progress on the blazer over the weekend. I did get the tubes cut and notched to tie the trans crossmember to the trailing arm crossmember. Also did a lot of measuring...standing around...measuring...scratching my head....measuring....trying to figure out where exactly I want to mount the coilovers in the rear. ![]()
#100 |
Boosted Member
Ordered up some RideTech single adjustable coilovers a few days ago, and they showed up last night. Very nice units. I mounted them to the "stock" location on the Porterbuilt lower arms, and the upper shock crossmember. The packaging is nice, but I don't like how close together they are. I have the room to move them outboard on the frame, and behind the axle, which should increase the lateral stability quite a bit. That should also allow for mounting the coilovers in double shear. Time to fire up the welder and plasma again this weekend and cut up some more perfectly good parts.
