10-26-2012, 07:09 PM | #1 |
How Accurate are Vacuum Gauges?
Everyone I talked to told me to buy a vacuum gauge to help troubleshoot why my mid 70's 454 acts like it's running on 7 cylinders! I finally broke down and bought a vacuum gauge thinking it was the answer, thinking it was some magical tool that would point me in the right direction! WRONG! I hooked it up to manifold vacuum and long behold, it says everything is pretty much normal! Well I've done everything short of rebuilding the motor so now I'm at a complete loss! So here's the question, how accurate are these vacuum gauges?
10-26-2012, 07:23 PM | #2 |
Re: How Accurate are Vacuum Gauges?
It holds a steady 20 at idle? Goes down as you open the throttle??
10-26-2012, 08:15 PM | #3 |
http://www.classictruckshop.com/club...ts/vac/uum.htm
That may help you interpret the readings and needle motion. It's best to have the gauge mounted in the cab where you can see it while driving.
1977 GMC Sierra Grande |
10-26-2012, 10:06 PM | #4 | |
According to your link, http://www.classictruckshop.com/club...ts/vac/uum.htm, it says my timing is retarded! If anything is retarded it's me, lol because I've been trying to figure this out for over a year! I'm close to concurring this beast so any help on fine tuning my timing would be mucho appreciateo!
10-27-2012, 02:13 PM | #5 |
If average vacuum at idle is right around 20Hg, then mine idling right around 16 or 17 means a vacuum leak, right?
10-27-2012, 04:14 PM | #6 |
Your vacuum may be lower due to elevation, timing, mixture screw adjustment, type of camshaft used, compression or cam position.
16 HG doesn't indicate a vacuum leak. |
10-27-2012, 09:04 PM | #7 |
I QUIT! I gave it my best shot and failed! According to several friends it runs fine, I am kind of a perfectionist so I may have been wanting to much out of it but I've got other projects to attend to so I'm either parking it or selling it!!!
10-27-2012, 09:14 PM | #8 |
No one likes a quitter.
10-27-2012, 09:30 PM | #9 | |
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
10-27-2012, 10:01 PM | #10 |
FIRST.. cool down... relax.. go have a beer or 2 if you drink. Come back to it later... when you do.. loosen the holddown on the distributor slightly, and turn the cap clockwise slightly with the engine idling... watch your vacuum gauge. did it go up? if so keep going till you get around 20" of vacuum... go drive the truck... romp on it hard a few times... does it ping? if so, turn your distrubitor back slightly until you can drive it with the highest vacuum reading, most power, and NO ping. there, you have timed your engine.. try that before you sell it
Jay Bernard, Thibodaux, LA 1986 SWB Sierra Classic Stock roller 350/700R4 2008 Buick Enclave CXL 3.6 VVT, 6spd auto. PAINFULLY stock... (wife's ride) |
10-28-2012, 09:23 PM | #11 | |
are you still running all the smog equipment?
1985 Chevrolet K-10, SWB, 350/700r4, 6" Lift, 35" tires |
10-29-2012, 10:28 AM | #12 |
Just here to tinker
I never a vacuum gauge for anything more than checking my air/fuel mixture screws. I set initial and full advance with a timing light and then lastly set the air/fuel screws with the vacuum gauge. Normal engine vacuum at idle can be anywhere from 16-21 in hg, depending on your set up and all the things geezer mentioned above.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
10-29-2012, 04:17 PM | #13 |
As far as I know it's stock except chrome valve covers and air cleaner! No smog equipment, not even an EGR valve! I set the air/fuel mixture and timing and it runs much better but I'm still tuning!
10-29-2012, 04:19 PM | #14 |
I still have questions on the initial and full advance timing? I've set the initial timing but how do I set the advanced timing?
