Old 11-23-2012, 09:39 PM   #1
1970greenburb
Suburban rear floor
Hello can any body recommend the best way to replace the plywood floor in a 1970 burb.? Is it a body off frame deal or just unbolt everything and lift the body up and slide the plywood under the rails? Thanks for any info.
1970greenburb is offline   Reply With Quote
Old 11-23-2012, 09:51 PM   #2
vectorit
What?
vectorit's Avatar
Re: Suburban rear floor
Actually you can take the wood out while body on frame, but 40 some odd years of elements attacking the wood and metal supports; it becomes one with the body and chassis.
In my case I had to cut my floor out, but putting it back in was rather easy all things considered.
The floor is actually two pieces.
There is a small tongue and groove piece in front of the passenger side wheel well, and you are to remove that by sliding it rearward and then remove the spare tire tub. Once you do that, slide the main wood floor to the passenger side.
If you manage to do those things, you can then lift the floor out from the inside and out the rear.
Installing the new wood floor is just the reverse of that process.
Try to take the old floor out in the biggest piece you can, then that way you can lay it onto the new wood and use it for a template for all the holes for the carriage bolts.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-24-2012, 01:04 PM   #3
1970greenburb
Hey thanks Chris after I read your info went back to the garage and looked it over. Sprayed all the carriage bolts with some WD40 and started to attempt the removal on the wheel well ones first three came off the rest saws all them. Not looking forward to the one up in side the rails. Did you replace your with a marine plywood or did you use a treated on or ?
Thanks again
Old 11-24-2012, 02:45 PM   #4
vectorit
What?
vectorit's Avatar
Getting the bolts out is a challenge, but they are low grade steel type.
Most of them I didn't even bother trying to tackle with a socket wrench, I would just get a good grip on the nut with a pair of vise grips and bend back and fourth till it snapped off (The wood floor would give enough to allow room to flex).
I used marine grade wood, then primed and painted both sides.
The under side I brush painted on a liberal coat of paint, more so than the interior side just for added protection from the elements.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 11-24-2012, 07:55 PM   #5
1970greenburb
Thanks Chris grabbing the bolts with vise grips and working them back in forth worked good. I will check on marine plywood next week.
Old 11-26-2012, 01:29 AM   #6
1970greenburb
Well couple more broken saws all blades and a lot of working back inforth to break the bolts off, the floor Is out in one piece, ended up taken the wheel well out, not by choice they where rusted out didn't see that before they where covered up with carpet, it sure did help taken the plywood out.
Old 11-26-2012, 01:43 AM   #7
vectorit
What?
vectorit's Avatar
WOW! you sure kicked butt on getting that floor out.
So you got the floor out in one piece huh? Lucky you
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 11-26-2012, 01:52 AM   #8
1970greenburb
Yeah I was surprised too beings you said you had to cut yours in pieces I didn't know what to expect but breaking the bolts off went way faster. I am going to take out the spare tire well and I was thinking of taken two sheets of plywood T&G and putting the seem down the middle so that I can go all they way across.
Old 11-26-2012, 01:58 AM   #9
vectorit
What?
vectorit's Avatar
Glad the idea of busting the bolts off worked for you.
I remember when I did mine, I had a whole cup full of busted bolts when I finished.
Don't pitch that original floor until you use it to trace out the bolt holes, and the outline of the original floor.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 11-27-2012, 12:11 AM   #10
Slinger60
Slinger60's Avatar
I replaced the plywood rear deck on mine also went the same route as you did on the wheel wells as the were rusted. Used marine grade plywood. And did the same as Vectorit did I painted both sides with high quality paint and rubber coated the under side also. And I used galvinized cairage bolts when I put it back together.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 11-28-2012, 05:44 PM   #11
1970greenburb
Thanks slinger60 for the info on the rubber coating and the galv. bolts. I don't what they used back then for plywood but it held up good for 40+ years of the great northwest rain and beyond.
Old 11-28-2012, 06:41 PM   #12
vectorit
What?
vectorit's Avatar
I'm pretty sure it was just your standard ply wood sheet, since the one I took out of mine was definitely not marine grade. Mine held up good to the 40 years of elements as well, but it was damaged and had all kinds of extra holes drilled in it over the years.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 12-07-2012, 02:48 AM   #13
Gobuffalo
Gobuffalo's Avatar
I need to replace the floor in my 70 Suburban.
Has anybody used a metal floor? I have one out of a long bed fleetside. All of the bolt holes around the wheel wells are the same and the wheel wells are the same distance apart. Overall length and width are smaller than the metal floor. How much surgery will it take?
Any help would be appreciated.
Gobuffalo is offline   Reply With Quote
Old 12-09-2012, 04:44 PM   #14
blue 72 gmc 4x4
blue 72 gmc 4x4's Avatar
My dad is making a metal floor for his 72' burb out of some diamondplate. I'll post some pics when we're done with it. He had already made the sides for it years ago so now we're going to get rid of the wood in the middle.
1955 GMC Hydramatic
1959 Chevy Spartan 100
1969 Chevy C/10
1969 Chevy C/30 Bruiser
1972 GMC (Wrecked)
1972 GMC pickup..old blue
Restored Vent Windows
https://67-72chevytrucks.com/vboard/...d.php?t=766598
1955 GMC hydramatic build
http://67-72chevytrucks.com/vboard/s...d.php?t=429417
blue 72 gmc 4x4 is offline   Reply With Quote
Old 12-09-2012, 04:59 PM   #15
project 67 sub
project 67 sub's Avatar
im in the process of building a raised steel floor in the back of mine...
project 67 sub is offline   Reply With Quote
Old 04-07-2013, 06:44 PM   #16
Cumminpwr11
Southern Nevada Coal Roller
looks good. I am thinking about replacing my rear wood with metal so I can anchor in a newer generation 3rd row rear seat better. If I can find a suburban in the junk yard I will cut out the back and graft into the suburban
Chris
Chris
72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo.
36 Chevy P/U rat rod project. 4bta cummins
Cumminpwr11 is offline   Reply With Quote
Old 04-08-2013, 02:13 PM   #17
ERASER5
ERASER5's Avatar
Rockcrln put a newer modle Yukon floor in one with the pockets for a removable rear seat. It can be done.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-08-2013, 08:13 PM   #18
lrader99
Chris
This is my plan as well but I am looking at either using a sheet of 14 ga steel that I have laying around or get a descent used long bed floor and modify that to fit.
lrader99 is offline   Reply With Quote
Old 04-09-2013, 10:34 PM   #19
capev86
i would say use the floor from a 69-72 Blazer and weld in the pockets for the 3rd row seat from a 73-91 model burb. be really good for those wanting the restored look as the seats from the two generations are about the same so you could adapt the upholstery.
capev86 is offline   Reply With Quote
Old 04-15-2013, 04:08 PM   #20
68 TT
Still plays with trucks
68 TT's Avatar
Did you ever get any pics of this done? I have a spare long bed steel floor I was considering putting into my recently acquired 67 Suburban. A removable third row seat with proper support would be very nice to have.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 04-15-2013, 07:09 PM   #21
Cumminpwr11
Capev, How close is the rear of a blazer to the wood area of a Suburban? I would totally go for something like that. I like my 80's front buckets and 2nd row seats (except for the color and cloth...I prefer leather)
Chris
Chris
Old 04-17-2013, 01:45 AM   #22
68 TT
68 TT's Avatar
What about doing the rear wood like some of the trucks with metal strips and dimensional lumber for the bed wood instead of plywood?
Old 04-17-2013, 12:56 PM   #23
WH0DAMAN
You would have to tongue & groove or biscuit joint the wood into one piece. Kind of like a dining room table top. There are big gaps between the boards on a truck version & that is what the metal stripes cover. This is on the inside of a truck so the gaps would have to be filled. The noise would be pretty bad without making it one piece. Not to mention the possiblility of water getting in since it would not be a water tight seal.
I have been kicking around the idea of replacing my wood with quarter sawn oak. The only problem is that I am adding a third seat so 1/2 of it would be covered by a seat. If I do it (which will be very soon since I am in the process of restoring my 70), I will do a write up on it.
WH0DAMAN is offline   Reply With Quote
Old 01-02-2014, 08:34 PM   #24
68GMCburban
68GMCburban's Avatar
I know this thread is old, but did anybody ever put a truck bed floor in place of the wood? That's what I'm in the process of doing, just curious about what it might look like.
-Holden
1983 & 1972 Chevy Longbeds
(16) 67-72s (Rollback, 402's, Sierra Grande, Shortbeds, Shortsteps, Longhorn, etc)
1968 GMC Suburban- (Current project) Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=569806
(6) 60-66s (shortstep, rollback, two-ton, longbeds)
(3) 47-59s half tons
+ MANY more and always looking for more
68GMCburban is offline   Reply With Quote
Old 01-02-2014, 10:52 PM   #25
capev86
it would look similar to the Blazer. and the nice thing is you could weld in the pockets from an 80's Suburban and have a quick fold\remove seat that could even be upholstered to match the original interior (if you like the factory appearance like i do).
