12-03-2012, 07:36 PM | #1 |
Re: 1957 Chevy truck re-rebuild
I took my turn signals out and never really thought of putting anything in their place.
It should look nice when you're done. Kim |
12-03-2012, 07:53 PM | #2 |
Tack weld studs to the inside of the fender, and brackets to the gills. Then you could bolt or unbolt them as needed. Could even make them an accent color. I like them no matter what, it's a totally original idea so far as I know.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
12-04-2012, 12:31 AM | #3 | |
We are thinking the same on the color also. So far my plan is a two tone paint job. Silver bottom, maroon metallic upper. With the silver bottom that would include the gills. I've never tried air brush, it may be time to learn. I considered at least airbrushing the edges of the gills darker to help bring them out a little more when done. As for having an original idea......I know what you're saying. It seems everytime I think I'll done something original, grrrrr, I find an image somewhere that is similar to my idea. As for the truck, I took a picture that shows the difference from the new to the old. My issue of welding these in place and having was solved by cutting holes that matched the gills. This way I can insert the gills and do the weld from the backside. Sure there is going to bits of grinding to do on the exposed/front side but as for the majority of the weld will be on the backside where I can use the 4 1/2" grinder and smooth the welds. |
12-04-2012, 12:52 AM | #4 |
What about using some of that body glue they repair corvettes with and it also works with metal.
12-04-2012, 12:11 AM | #5 |
12-04-2012, 10:44 AM | #6 | |
The gills are coming out nice. Kim |
12-05-2012, 01:44 AM | #7 |
Hey butchp, thanks for checking in, perhaps a good idea, I've done the welding from the backside. Then came the grinding and more grinding, hmmmm, using a glue, might have been alot easier.
Ram, amazing what a couple of pictures can do to perk up some enthusiasm. Kim57, I'm hoping to get the headlights ordered by end of this week. I haven't seen them other than in the catalog. I hope they help the look of the truck with the way they have a 3 bar look inside them. The last picture was one side with the new and the other side with the new look. Here's both sides with the holes cut. Now with the gills taped in place. I have the tape on the backside so the tape doesn't show in the picture. After this comes a bunch of welding. |
