12-10-2012, 12:19 AM | #1 |
Moderator
Re: Camaro Caliper Brackets
I am confused. I went to the boneyard today to source/price all the parts to use with these brackets. I did not find any 94-97 Camaros with rear disc brakes....all of them were drum?? Were rear discs an option on these years? I did run across a 99 Camaro that had rear disc brakes, but did not pull the trigger because of the years you specified here.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-10-2012, 12:53 AM | #2 | |
60-66 Nut
Rear disc brakes were not standard equipment on the '93-'97 F-bodies. I believe they were typically found on the Z28's. The '99 Camaro has a different caliper and rotor than the '93-'97's.
12-18-2012, 04:32 PM | #3 | |
Still plays with trucks
The 98-up stuff was on all the cars V-6 or V-8. Same for the front brakes. The rear on them uses an internal drum brake inside the brake rotor for the parking brake so the calipers are different with no provision for a mechanical parking brake in them. The rotor thickness is different too so they would need spacers to work on the thinner rotors the kit is designed around.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
12-19-2012, 12:52 AM | #4 |
60-66 Nut
Good info 68 TT
Thanks for posting
12-29-2012, 01:17 PM | #5 |
Received my brackets for the 93-97 Camaro brakes and they look great! Question about proportioning valve. I am replacing my M/C and Proportioning valve due to prior leakage. I bought a new M/C for 78 corvette and wonder if I should buy the proportioning valve for the same, go with stock proportioning valve or I did find one on ebay that says it will work for 67-87 trucks disk disk although they refused to answer my question when I asked if it would work for this application. If anyone else has done this swap with sucess input would be appreciated. Thanks
12-29-2012, 11:33 PM | #6 |
60-66 Nut
You can try the Vette prop valve, but you may or may not be happy with the brake bias. Anymore I recommend the Wilwood #260-11179. It already has an adjustable valve in the rear circuit, so you can adjust the rear brakes to how you like them.
