Old 12-18-2012, 12:29 PM   #1
shawno72
C/10 junkie
shawno72's Avatar
Air bag installation
Can someone point me to a thread that shows how to install a basic bag setup for say a 68 swb coil spring truck? Looking for a thread that shows how to install a PorterBuilt stage 1 kit front and rear. Thanks guys in advance.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-18-2012, 12:48 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Air bag installation
Not a Porterbuilt thread,... but a good "basic" airbag thread from our FAQ area.
http://67-72chevytrucks.com/vboard/s...d.php?t=129463
Keith
Convert to disc brakes.
Old 12-18-2012, 12:49 PM   #3
shawno72
C/10 junkie
shawno72's Avatar
Thank you Keith, I'm not quite ready for a bag conversion but I want to start getting all the info I can to make the best decision. Also is there any threads for cupping the lower control arms? I was kinda thinking it may be better to just buy a set of aftermarket lower control arms with bag mounts built in.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 12:51 PM   #4
lolife99
lolife99's Avatar
Bag install is pretty straight forward.
Your choice of air management is where you can spend some cash!
Keith
Old 12-18-2012, 12:54 PM   #5
shawno72
C/10 junkie
shawno72's Avatar
Yeah I see there is a ton of choices in that regard
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 01:14 PM   #6
shawno72
C/10 junkie
shawno72's Avatar
Hey Keith in the link you posted does the front lower cups just sit in the spring pocket or do you weld them in?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 01:18 PM   #7
lolife99
lolife99's Avatar
They just set there.
Most cut them down to 1-5/8" to 1-3/4" tall,... to get the maximum drop.
Keith
Old 12-18-2012, 01:22 PM   #8
shawno72
C/10 junkie
shawno72's Avatar
Ok, I get it. Thanks
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 01:33 PM   #9
shawno72
C/10 junkie
shawno72's Avatar
So in the Porterbuilt stage 1 rear kit does the upper bag cup not allow the rear to sit as low as the way the guy in the link did his rear bag install?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 01:37 PM   #10
shawno72
C/10 junkie
shawno72's Avatar
Another question is I have a CPP notch installed already, if I wanted to go with a Porterbuilt notch how far will the holes be off?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 01:45 PM   #11
lolife99
lolife99's Avatar
Attachment 1028020
The Stage 1 kit comes with an "upper hat".
This allows for easier mounting and air line install.
I would just use your CPP notch and install the bag directly to the frame, without the hat.
But that will require you to drill 2 bag mounting holes in the frame,... and 1 giant hole for the air bag fitting to pass thru.
The upper hat makes it easier,... and that amount of added height can be offset by using a lowering block.
The rearend center section will hit the bed floor, BEFORE the axle tube is all the way in the notch, anyway.
Keith
Old 12-18-2012, 02:11 PM   #12
shawno72
C/10 junkie
shawno72's Avatar
Gotcha, thanks for all your knowledge Keith, I really appreciate it.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 10:03 PM   #13
SBC
SBC's Avatar
I recently installed PB stage 1 in front and stage 2 in rear. Once you look at the pieces it's pretty straight forward. Just a lot of drilling. Once I fix my brake problem I could post some pics if you like.
1967 C-10 Project
2008 Suburban
2017 GMC Sierra
SBC is offline   Reply With Quote
Old 12-18-2012, 10:20 PM   #14
shawno72
C/10 junkie
shawno72's Avatar
Any pics would be great. I'm really leaning towards the pb kits when I'm ready. Thanks.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 10:46 PM   #15
Pro Performance
Pro Performance's Avatar
Here is the Stage 1 kit without a c-notch. Since you have a c-notch, i would just remove the upper cup and that should put you where you need to be or at least very close.
Pro Performance is offline   Reply With Quote
Old 12-19-2012, 10:51 AM   #16
shawno72
C/10 junkie
shawno72's Avatar
So are you saying that's about as far down as the axle would go because of th bag cup? Or because I have a notch it would go farther? To me as long as the pumpkin hits the bottom of the bed floor aired out with the bag cup that would be fine ad plus it's much easier I install.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2012, 11:38 AM   #17
CC69Rat
CC69Rat's Avatar
Wait .. what's all this? Bags?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-19-2012, 11:41 AM   #18
Pro Performance
In that picture, it is sitting on the internal bumpstop in the bag. If you remove the cup, it will move up that much farther until the axle hits the bed floor, which might be about another 1" appx.
If you are looking at the Porterbuit Stage 1, you can always put the cup on the top to see where it is at, and then remove if it is not needed.
Old 12-19-2012, 11:44 AM   #19
shawno72
C/10 junkie
shawno72's Avatar
Yep, I am in the stage of gathering info to see how I want to go about it
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2012, 11:46 AM   #20
Pro Performance
Is the white truck in the Avatar what you are wanting to put bags on?
That things sits low for a static drop!
Old 12-19-2012, 11:47 AM   #21
shawno72
C/10 junkie
shawno72's Avatar
Something I didn't see earlier but I have approximatley 1 7/8" in blocks, so really I can probably run with the cup then. Just would be so much easier to install the cup instead of putting more holes in the frame, even though I know its really not a big deal.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2012, 11:49 AM   #22
shawno72
C/10 junkie
shawno72's Avatar
Yeah thats the truck but it's been photoshopped for a year to inspire me to get the bags done. This is where its at now and the avy is where I want to be
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2012, 11:56 AM   #23
shawno72
C/10 junkie
shawno72's Avatar
And what really got me going again was I sold my 5" drop springs to put in some 6" drop springs. So while I am waiting for my 6" springs to arrive its been sitting at my shop like this and I REALLY LIKE IT!!
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2012, 12:23 PM   #24
Pro Performance
I agree, that would be enough motivation for me right there! lol
Old 12-20-2012, 11:01 PM   #25
cubber
I highly recommend Porterbuilt. I have both the front and rear kit, and also the c-notch. There are several pics in my build thread, here are a few
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
