Old 12-19-2012, 10:22 PM   #1
Thumpt
Thumpt's Avatar
What sway bar to use ?
I want to fit a sway bar to my 69 c10, what can you recommend, I have looked at the ridetech, just wondering what else is out there.
Thanks Mark.
Thumpt is offline   Reply With Quote
Old 12-19-2012, 10:33 PM   #2
sjarrett71
sjarrett71's Avatar
Re: What sway bar to use ?
I've intalled a couple of original ones and they work just perfect. Couldn't ask for a more noticeable improvement from single part.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 12-19-2012, 10:36 PM   #3
Hubscrub
Cruzin
Hubscrub's Avatar
i got one off a mid 70's 3/4 ton truck for 20buck at the yard, they all bolt up through 87 models i just bought the lowered truck mounts from ece
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-20-2012, 01:08 AM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
For the price a frontt sway bar is the best bang for the buck add-on you can do. I put a 1 1/4 inch from a 70's Camper Special 3/4 ton and added the polyurethane bushing and brackets for lowered trucks that ECE sells and could fel the difference in handling right away.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-20-2012, 11:24 AM   #5
Scottshotrods
Take a look at CPP they have bolt on Sway-bars for your truck.We sell the complete line of CPP parts.We run a Special on there parts YEAR ROUND.
You can call us at the shop or p/m me or e-mail me
(805)485-0382
justin@scottshotrod.com
Justin
Scottshotrods is offline   Reply With Quote
Old 12-20-2012, 11:26 AM   #6
70blackfish
how about a good fitting rear sway bar.....?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 12-20-2012, 02:56 PM   #7
brad_man_72
the boat guy
brad_man_72's Avatar
Their is no best sway bar. Sway bars reduce body roll and reduce traction. Its best to do quite a bit of reading and knowing where you want to end up before spending a bunch of money.
Stock bars from square bodies work great for the money.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 12-20-2012, 03:12 PM   #8
1970 C10 MJW
1970 C10 MJW's Avatar
since when does a sway bar reduce traction???
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 12-20-2012, 09:12 PM   #9
ryans69chevy
What benefit do the lower mounts from ece do? Is that needed? Or how much drop do you need to have before this are required?
Thanks,
Ryan
ryans69chevy is offline   Reply With Quote
Old 12-20-2012, 09:35 PM   #10
ol_skool_chevy
ol_skool_chevy's Avatar
F body Camero.
I got mine at pick and pull $20.00 with all the brackets.
1 1/4 inch.
dont waste your money buying CPP, or hotchick's, or those other high end bars.
IMHP
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-20-2012, 10:10 PM   #11
NGN
NGN's Avatar
I used a C-10 sway bar don't no year, 67-72 from a V8 in my 67 short fleet straight 6, works great notice right away. Don't know if there's a differents between sway bars when it's for a V8 or L6
NGN is offline   Reply With Quote
Old 12-20-2012, 10:54 PM   #12
Already Gone
[QUOTE=ryans69chevy;5769642]What benefit do the lower mounts from ece do? Is that needed? Or how much drop do you need to have before this are required?
Thanks,
Ryan
[size=1]Posted via Mobile Device[
A popular drop is 4 inches in the front and I think with that amount of drop ( or more ) and using stock brackets which are I'm sure are another 4 inch drop you could hit the sway bar on curbstones etc. I got the lowered brackets cause I needed new brackets and they weren't expensive and unless you get down on your hands and knees you cant see the sway bar on my stock height truck even with the 29 inch high tires, and I like that you can't see the sway bar.
Old 12-21-2012, 04:28 PM   #13
brad_man_72
the boat guy
I'm sorry I thought this was common suspension tuning knowledge. Why else would sway bars come in sizes less than 4", why that when allowed racecars use adjustable sway bars, when you have 4 springs pushing down evenly on 4 tires you have the most traction available.
Blah blah blah, roll center, yada yada yada, camber curver, wonk wonk wonk, tire deflection, knuck knuck knuck, chassis flex, yougettheidearight? If not go to the suspension side of the forum and read "make it handle"
Old 12-22-2012, 05:17 PM   #14
Thumpt
Thumpt's Avatar
Thanks for all of the replies, much appreciated. I should mention is is on air bags and rides quite low. I see that hotchkis has a 25% off sale on at the moment too.
Old 12-22-2012, 08:23 PM   #15
Thumpt
Thumpt's Avatar
Old 12-22-2012, 08:27 PM   #16
67anthony
Good looking truck
67anthony is offline   Reply With Quote
Old 12-22-2012, 09:29 PM   #17
CC69Rat
CC69Rat's Avatar
I have Hellwig bars, front and rear .. The rear one is a little bit of a pain to mount but overall I really like it.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-23-2012, 05:28 PM   #18
Smith & Sons
Purchase a front sway bar from POL & had to modify the mounting brackets to get it to fit.I think Helwig would be better quality.You get what you pay for.
Smith & Sons is offline   Reply With Quote
Old 12-23-2012, 05:39 PM   #19
leddzepp
Moderator
leddzepp's Avatar
I have an OEM sway bar on my truck, works just fine.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-23-2012, 05:43 PM   #20
big_al_71
big_al_71's Avatar
(805)485-0382
Justin
I had both front and rear from CPP and they worked great.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-23-2012, 06:31 PM   #21
ryans69chevy
So with a 2.5 drop in front do you think the lowered brackets are needed?
Old 12-23-2012, 06:42 PM   #22
leddzepp
Moderator
leddzepp's Avatar
No.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-16-2013, 08:17 AM   #23
swanga c10
I'm guessing when changing from a stock sway bar to a cpp bar you need to drill a hole in the lower control arm as they are mounted differently?
swanga c10 is offline   Reply With Quote
Old 01-18-2013, 05:08 AM   #24
nate68
I'm also trying to figure out what to do for the rear as there are a few different types. For example, Hotchkis has 2 different ones. Do they all perform the same?
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 01-18-2013, 07:58 AM   #25
Andy4639
Old member
Andy4639's Avatar
Wink Re: What sway bar to use ?
Thanks Mark.
I have the ECP front bar with lower brackets. I like it just fine.
For the rear I bought a Z-28 rear sway bar.
It takes a little work but it was worth it. You need spacers for the frame mounts but they are easy enough to make. I have a extra set by the way.
I bought the clamps for 3" exshaust to clamp the bar to the axle.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
