Old 12-23-2012, 03:12 PM   #1
rwade
rwade's Avatar
What gears do you recommend?
I am putting a 6.0L (LQ9) with a mild cam, 4L80 with a 3600 stall converter. I currently have 3:73's in my 12 bolt. I will be running a 24X14 rear wheel with a 405/25/24 that is 32" tall. Wondering if I should consider going to a 4:10, or even a 4:56? Or would I even notice the difference? This truck will never go down a race track, just want some nice get up and go. Thanks for your responses.
rwade is offline   Reply With Quote
Old 12-23-2012, 03:34 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: What gears do you recommend?
I would leave the 3.73. I think my tires ars 28". Even with the larger tire i think the 3.73 is a great combo with OD. I have a 700r myself.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-23-2012, 03:44 PM   #3
Smith & Sons
With that much tire,I think you are going to want more gear.As it is ,you will be turning only about 1700 rpm at 60 mph.With the 4.56s you will be turning just under 2100 RPM at 60-about right.Just be shure you have high quality axils & u joints ect. Happy cruizing (see ringpinion.com-calculators) Your converter will also be happier w more gear
Smith & Sons is offline   Reply With Quote
Old 12-23-2012, 04:15 PM   #4
rwade
rwade's Avatar
I will be using custom narrowed moser axles and all new bearings & u-joints. Thanks for the responses.
Old 12-23-2012, 05:20 PM   #5
Smith & Sons
Sounds good.You may also want to consider a poly driveshaft center mount instead of the OEM rubber one.The terminal velocity of your driveshaft may be an issue ,especially if it's a long box-you don't want to end up wearing that thing.
