12-23-2012, 11:28 AM | #1 |
Horn Question
I'm trying to get my horn to work. I replaced the relay and it will blow with the steering wheel off. My question is: is there a spring under the canceling cam? My canceling cam is worn on the bottom from the bearing contact. The parts page on LMC Truck # 127 shows what looks like a spring but no part#. Is this part available? If not does anyone have a spare they will sell me? The rest of the horn parts are OK. Thanks!
12-24-2012, 05:31 AM | #2 |
Re: Horn Question
Do you have tilt steering?
A tilt steering has a spring under the cancel cam. Some info in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=515103 |
12-24-2012, 10:46 AM | #3 |
Re: Horn Question
no It's no tilt.
12-24-2012, 06:02 PM | #4 |
Re: Horn Question
See this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=494837 I have an extra spring and horn contact I can send you, but not the little plastic piece. PM me your address if that will help and I will send them to you. |
12-25-2012, 08:49 PM | #5 |
Re: Horn Question
Thanks for the replys.I think i have the contacts worked out [have a new set]but my canceling cam has groves worn in it where it has contacted the steering wheel bearing. Is there a washer or spring between the canceling cam and the steering wheel bearing? Thanks
