Old 12-28-2012, 08:39 PM   #1
Miayota
Help, I want my motor to look like this.
I want my motor to look like this. What kind of paint should I use? Is it exterior car paint with gloss on it? Will that withstand the heat of the block?
Miayota is offline   Reply With Quote
Old 12-28-2012, 09:01 PM   #2
jonathan-m
Re: Help, I want my motor to look like this.
Seymour enamel engine paint code EN-48 for chevy orange.
Rockin' a '66 and loving every minute of it
jonathan-m is offline   Reply With Quote
Old 12-28-2012, 11:08 PM   #3
sigshooter
sigshooter's Avatar
Krylon ceramic high heat engine spray paint
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 12-29-2012, 07:34 AM   #4
tincan1966
tincan1966's Avatar
This was done using the Ceramic from Duplicolor. Sorry its the wrong brand, guys! That is actually a correct 1959 Ford engine color.
tincan1966 is offline   Reply With Quote
Old 12-29-2012, 07:36 AM   #5
tincan1966
tincan1966's Avatar
OK I can redeem myself- here's my '69 big block using Duplicolor Ceramic in CHEVY orange. LOL
Old 12-29-2012, 11:03 AM   #6
sigshooter
sigshooter's Avatar
I was wrong, mine was duplicolor ceramic not krylon...... I know my pics dont show how shiny it is ( camera phone and poor lighting ) but it is actually very bright and shiny..... I love the ceramic paints
I even baked the paint on in an oven on all my small parts, made it even better
1966 Short stepside
1964 long bed
Old 12-29-2012, 11:57 AM   #7
PoDuck
Yes, the duplicolor ceramic is the best I've seen so far. You can get it in pretty much every parts store. The cap is labeled "Chevy Orange". There are other colors that look similar on the cap, but they don't come out the right color.
PoDuck is offline   Reply With Quote
Old 12-29-2012, 02:21 PM   #8
yellow400ex05
no job in a spray can will get you that nice clean glassy gloss, I had the guy who helped me build my 327 use what he uses to paint his engines it comes in small cans or gallon size, I'll get back to you tomorrow about what exactly he uses he mixes it to the right viscosity, actually comes out VERY consistent, the valve covers were painted at a separate time from the engine as well.. and yes he uses a paint gun.
yellow400ex05 is offline   Reply With Quote
Old 12-29-2012, 02:24 PM   #9
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Now I want to go and paint my engine.. Those above look great!!! Way to inspire the rest of us
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-29-2012, 09:15 PM   #10
dougf
dougf's Avatar
Exactly! Makes me want to do the same thing! What process have some of you used in the past? Remove everything you can, degrease, clean, dry, then paint?
dougf is offline   Reply With Quote
Old 12-30-2012, 12:49 AM   #11
shortbed70
shortbed70's Avatar
Just put a bunch of shinny stuff on it and you will hardly even notice the paint on the motor... Just my opinion
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-30-2012, 04:09 AM   #12
bk2life
does you hood paint peal? you got heat of the motor, the sun, exhaust all baking that hood. in phx we get some hot hoods.. even will peel/burn skin right off
base coat/clear coat.
bk2life is offline   Reply With Quote
Old 12-30-2012, 09:12 AM   #13
corvettejim1968
corvettejim1968's Avatar
i want my engine to look like this.
anybody have the or any paint code for 1965 283 V8 grey
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 12-30-2012, 11:40 AM   #14
ABX131
ABX131's Avatar
Done with Duplicolor Chevy Orange from a spray can.
ABX131 is offline   Reply With Quote
Old 12-30-2012, 06:54 PM   #15
Dion Hildebrandt
I have painted many engines with straight automotive paint, either single stage or base/clear with zero problems. The trick is to make sure everything is clean, and then clean it two or three more times, dont paint under a bolt head or a mating surface for the exhaust, water pump intake, fuel pump, etc. The hardened paint helps with clean up down the road as dirt and oil dont stick like it does to aerosol paints. hope this helps.
Dion Hildebrandt is offline   Reply With Quote
Old 12-30-2012, 08:59 PM   #16
PoDuck
Depending on what you are doing, but on solid colors you can usually get just as good of a paint job out of a rattle can as you can with a paint gun. It's not as easy, but it can be done.
We've all seen cars that people painted with rattle cans that look terrible, and I was convinced at one point that you could never do near as good of a job with a rattle can until someone showed me an entire car painted with a rattle can the right way. Anyone would have been hard pressed to tell the difference.
Old 12-30-2012, 09:25 PM   #17
eldogg
eldogg's Avatar
I have had great results using VHT engine paint and VHT engine clear. The clear makes all the difference.
eldogg is offline   Reply With Quote
Old 12-31-2012, 05:15 PM   #18
sickboy_1456
Also Duplicolor Chevy Orange.
sickboy_1456 is offline   Reply With Quote
Old 01-01-2013, 01:37 AM   #19
63alloveru
It could be like this!!
63alloveru is offline   Reply With Quote
Old 01-30-2013, 09:21 AM   #20
Miayota
Not exactly what wanted but it's close enough considering my budget. Thanks Guys!!!
Old 01-30-2013, 10:19 AM   #21
LT1 Burb
LT1 Burb's Avatar
I took a factory color valve color in and they mixed me a can, I don't know if the code is on it but I will look. I had 2 grey valve covers and both were original and they were different shades of grey so like the green, there are variations.
LT1 Burb is offline   Reply With Quote
Old 01-30-2013, 10:52 AM   #22
geezer#99
geezer#99's Avatar
I hope you got another 50 bucks to spend.
You need to replace that oil cap on the drivers side valve cover with a breather. Just the pcv won't stop the oil leaks. You need somewhere for air to get into your motor so the pcv can suck out the fumes.
You need to replace that rubber fuel hose with a steel tubing line. Big fire waiting to happen.
geezer#99 is online now   Reply With Quote
Old 01-30-2013, 11:12 AM   #23
shawno72
C/10 junkie
shawno72's Avatar
I used Rustoleum engine enamel $6 a can
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-30-2013, 11:54 AM   #24
Miayota
Shawn did you also paint the pulleys or were those already black? Ya did a great job!!
Old 01-30-2013, 12:05 PM   #25
shawno72
C/10 junkie
shawno72's Avatar
Thank you for the compliments!! I painted everything except for the bolts which were new and the chrome. The headers came ceramic coated but everthing else I cleaned, sanded and painted with rustoleum gloss black and Chevy orange.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
