2WD Jimmy
Re: How To: Ruin a Perfectly Good K/5
Where is the new one coming from? Someone restoring it for you?
#2 | |
A guy with a truck
![]() I'm pretty torn on this one, too. It is just SO clean and original in appearance, which is a big part of its appeal. If I came across an original 2wd frame (like the TWO that sold here while I was away!), I would consider a tub swap, but I'm hesitant to do a 'hack job' on it. On the other hand, if PB would produce a complete conversion kit, like they do for 73-87, weeeeeeeelllll, I might have to change my mind... I purchased a nice, original cupholder style; should arrive next week, I hope. I will be performing the console resto myself, including tear-down, cleaning, color change to parchment, and reassembly with stainless hardware (and maybe a stereo inside). I will document the process here.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). |
#3 | |
#4 | |
A guy with a truck
Nasty, dirty, filthy 5-minute photo-hack:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). Last edited by gringoloco; 10-31-2013 at 11:07 PM. Reason: added a ridiculous photo |
Oh yes it would.....
Needs a Big Block
Loooooooooove it.
I sold a conversion kit to a buddy here in town , he went mild front and rear. It's not a bolt in kit, theres some fitting and it's welded in. But was pretty slick, I just finished a 68 Lwb on mobsteels. Your idea for them and a 3/4 cap would be a home run. ( subliminal chant: Cut it up! Cut it up! Cut it up!)
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
#7 | |
A guy with a truck
Needs a Big Block
I've seen the work you did on the last blazer at Darren's.
Don't be mad, buuuut you know where we're gonna push you, It won't hurt , that side of the fence is closer to the ground!!
#9 | |
A guy with a truck
We'll see what comes out of PB's shop... Been doing a little work on restoring the console I nabbed off eBay. It actually went pretty smoothly. I disassembled, stripped with garden-variety paint stripper and acetone, then coated with SEM super white, which is supposed to be a good match for parchment.
A guy with a truck
Put it back together with stainless hardware and new bumpers after polishing the chrome with Mother's and 0000 steel wool. Also painted the bowtie blue using Testor's bright blue model paint. Looks pretty good sitting on the floor, but the SEM color is much cooler than the warmer, factory parchment. So, I will tear it apart again and the 'super white' will be an extremely expensive primer for the correct color that I'm having the local paint shop mix for me
Still Learning
Very nice work on the console. I have a black one that needs the same treatment. How long you here for? I'll send it right down.....bummer about the color mismatch. Been there done that on a hood and fender bc/cc it sucked
A guy with a truck
I'm around for another month or so, but I'm not sure I'm ready to tackle another console just yet. People look at you funny when you're disassembling your truck in the parking lot and spray painting in your hotel room
I do have another couple of things I'd like to get done before I leave, though.
Looks pretty good low there Chris....HMMMM What to do , what to do??
67- 72 Parts collecter |
#14 | |
A guy with a truck
![]() Tore the console apart again to change the color. This is a MUCH better match than the SEM super white- should have just had them mix it in the first place- oh well... Top is super white, lid is the custom mix:
#15 |
A guy with a truck
While I had it apart, I decided to go ahead and mount the head unit inside. I tossed around the idea of putting it in the glove box, but saw a few members had used an under-dash kit in the console and liked the way it looked. Also puts the controls within arms reach. Pretty happy with how it turned out and was stupid easy to fit- almost like it was made for it...
#16 |
Needs a Big Block
Super clean install.. Love it!
#17 | |
Still Learning
![]() Did you say you replace the trim piece around the edge at the top? or just polished an original? I need to replace mine, it has some small pitting. You don't know a source for this piece do you? Thanks |
#18 |
Chris, I'm getting ready to paint a few things on the interior of my Blazer to match my parchment seats. I've gotten the SEM color card in and the super white looks to be a perfect match, but I keep coming back to this thread and looking at how far off it was in reality. I've tried to use a color match camera that my painter buddy has, but it doesn't come up with a formula for that color. Is there any chance that you have a color code, formula, etc. for your custom mix that you used on your console?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#19 |
A guy with a truck
They're coming home!
#20 |
Tot Roddin'
That's a great location for the headunit.
Awesome work!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#21 |
A guy with a truck
Thanks fellas!
If it's possible to be in love with a truck's interior, I am
#22 |
67cheby
![]() Join Date: Sep 2008
I love it ! LOL
#23 |
A guy with a truck
You would!
![]() Thanks everyone for the comments/suggestions
#24 |
White walls are cool, especially with gypsies. But you ain't got a hair on your cajones if you don't get a set of these Highlander Plaid balonies:
JK |
#25 |
I say yes.....But i"m might be a little bias
I love yours and mine
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
| Bookmarks |
