Re: How To: Ruin a Perfectly Good K/5
It's all part of it... Get that out of the way, then the fun stuff can start!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Still Learning
Dang Chris, I thought this rig was without rust. I see you are making it right. Keep up the good work!
A guy with a truck
Thanks guys! Nothing like what some people deal with, but there's a few spots. I'm slowly exorcising the demons
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). Last edited by gringoloco; 09-21-2016 at 01:27 AM. |
I'm just glad to be here!
The repairs are looking good.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). |
Still Learning
Nice progress Chris! Looks like you are into it deep now. What's the plan for paint? just gonna touch it up and blend it?
#8 | ||
A guy with a truck
. Had to get the paint shop to remix, as their first attempt from the code was too light. Dropped the glove box door off for a match.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). Last edited by gringoloco; 09-21-2016 at 01:54 AM. |
A guy with a truck
Started out today after poking at the rust, being able to see the ground through the bed floor and rear cross sill. I cut it all out only to find that the good metal was under the rear stake pillar. At this point, I had two options, remove the bedside, or cut the post. I took the path of least resistance.
Made a patch for the cross sill and welded it in. Was nice to weld on something sturdy that I could actually stitch instead of using a million tacks. Coated it in weld through primer then fitted the ribs. The patch for this area is actually nicer than the original GM stamping with clean, crisp edges at the end of the ribs. Almost makes me want to use the whole thing. Almost. Lined up pretty good, with only minor massaging to get the peaks and valleys aligned. It will take a little extra body work to be perfect, or I might just leave it, as it will be under the carpet. I'll have to button up the pillar tomorrow, as I got sidetracked with the quart of POR-15 I picked up while at the paint store today. I coated all kinds of stuff, and was actually having fun doing it (I think the fumes were getting to me ) Side note: POR does not come off of skin easily. I have heard this a number of times and it is true. Very true. I'm just glad I wear long sleeves to work... The other side should be less involved, as the damaged area appears smaller and I don't have the gas filler/vent to contend with. We'll see tomorrow
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). Last edited by gringoloco; 09-21-2016 at 01:31 AM. |
![]() Join Date: May 2006
nice work. where'd you get that patch panel. reason,IMHO, they always rust out there is wheel splash. I suppose we should seal up that area with dum--dum
I can't see the seam
#11 | |
A guy with a truck
I plan on POR-ing the crap out of the area then sealing the leading edge of the crossmember where it meets the floor with flexible seam sealer. That's the idea
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). Last edited by gringoloco; 09-21-2016 at 01:41 PM. |
A guy with a truck
...and done. Including the big, boogery factory style weld holding the bedside to floor
A guy with a truck
Thought I could get away with not cutting the stake post, but the good metal was just a little too deep. This side is going easier than the drivers, partly due to no extra stuff in the way, and partly due to the learning curve.
The cross sill is patched and the floor patch is fitted. Need to punch the plug weld holes and she's ready to burn in. Taking it easy tonight, so I'll weld it in the morning. Thanks for tagging along
A guy with a truck
Done and done. Pass side patch did not line up as well for whatever reason. Took a little extra persuasion to coerce the ribs into alignment. Metal straightened and body-worked the drivers side as well. I'm through with this area until final prep for paint
![]() Looks like it's time to move on to the A and B pillars, which I am not looking forward to. I am, however, looking forward to coating the insides of the rocker boxes in POR--this stuff is addictive
#15 |
Still Learning
Excellent work on the rust repairs Chris. You made that look way too easy
#16 | |
A guy with a truck
#17 |
A guy with a truck
Randomly selected B pillar first. I've seen worse...
#18 |
A guy with a truck
Done cutting(?) for now. Leaving as much of the existing metal as I can.
Rocker box is super solid. Time to POR inside the B pillar, while it's accessible.
#19 |
A guy with a truck
First patch in and POR'ed: I only ground the welds that have a chance of being seen
#20 |
A guy with a truck
Built a template for the next piece and burned it in:
#21 |
67-72 parts collector,…
![]() Join Date: Nov 2002
You do great work!
#22 |
A guy with a truck
Thanks, man. All I know is I do slow work
Finished the outside of the support; still need to work the leading edge then it's ready to be skinned. Looking at these pictures makes me want to grind the welds in there--I need to get it buttoned up soon to quell the urge to perfect it. Ended here for the day:
#23 |
A guy with a truck
Cut a piece for the front side of the support and fitted a 95% solution for the outer skin:
#24 |
A guy with a truck
Tack, tack, tack, grind, tack, tack, tack, grind, sand, prime. It needs a little hammer/dolly and a skim coat of filler.
#25 |
A guy with a truck
Then the A pillar... HartRob, in his Superburb thread, described this area as a five-dimensional puzzle. I tend to agree. Everything comes together in the same place, then traps dirt/moisture and rots it all.
I cut out all of the offensive metal, including floor, inner rocker, kick panel, A pillar, floor support, and a small bit of the rocker box directly under the support. Decided to patch the support, as opposed to replacing it, as there was only a small area gone and the replacements I received are paper thin garbage--I used a scrap of one of the fender patches to repair the existing piece. Followed that with buttoning the rocker box back up, then ended the day with POR-ing as much of the inside of the box as I could reach. Next up: 5D puzzle
| Bookmarks |
