Old 01-17-2013, 09:00 PM   #1
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Repair frame or throw away
So I need some opinions on this frame. Sometime along its life it was cracked and then inproperly repaired. They did not remove the front crossmember and only patched and welded it from the inside (side that was not covered by the crossmember).
Do you think it is salvagable or should I scrap it an look for another shorbed coil spring frame?
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 01-17-2013, 09:34 PM   #2
Spartan
Spartan's Avatar
Re: Repair frame or throw away
I'd fix it but it really depends on your skills/tools/finance.
A properly patched and welded frame should be just as strong or stronger.
'69 K20 350/4 speed/Rockwell/D44/HO52.
"orange rhymes with door hinge"
Spartan is offline   Reply With Quote
Old 01-17-2013, 09:38 PM   #3
Fldawg
Fldawg's Avatar
I would plate it and weld it up, i know on some of our international buses we have at work we did quite a few repairs like that. should'nt be a probelm, the plate was a international design, so if you used a piece of angle and weld it in it should be strong enough
Fldawg is offline   Reply With Quote
Old 01-17-2013, 10:25 PM   #4
SS Tim
SS Tim's Avatar
It is repairable and a section from another C10 frame might be the best start.
SS Tim is offline   Reply With Quote
