Old 01-20-2013, 10:28 PM   #1
blackdiesel
blackdiesel's Avatar
'56 GMC LCF Cummins Diesel
Yeah so it is actually considered an "F-series" truck instead of a Low Cab Forward (due to being a GMC) but it is obviously more commonly known as a LCF.
I've had my eye on this jewel for going on three years now. Came across it on an old back road while test driving a repair on a truck I had made. Stopped and talked to the owner and he said he just sold it to some dude in Australia.
I drove by it several times in the past couple of years, and it never left. Fast forward to the first week in December 2012. I recognized a car that he had on craigslist and called the number. He said the Australian never came through with the cash so i made him an offer and he took it.
I hooked up the trailer and had it home within a couple of hours:
It set in the shop for three weeks until I could get a handle on a frame. I always wanted a diesel hot rod (i'm kind of a cummins nut) so i finally laid my hands on a 02 dodge dually quadcab longbed 2wd frame. I threw in a 12 valve p-pumped cummins i had laying in my shop in it with a 47rh trans.
Started stripping the sheet metal off of the front of the truck so i could get the cab off:
Kind of skipping a few steps here, didn't take the time to take a whole lot of pics:
The majority of the engine is actually in the cab. 1 & 2 cylinders are under the hood and the other four are actually through the floor board.
I got all the sheet metal hung yesterday and worked on the steering column today. I'll try to take some more pics of the sheet metal mounts and steering linkage sometime. Up next is mounting the brake booster/master cylinder and building a new dog house.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 01-20-2013, 10:33 PM   #2
cAlvis165
cAlvis165's Avatar
Re: '56 GMC LCF Cummins Diesel
I'm subscribing for this! Looks great so far.
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 01-20-2013, 10:45 PM   #3
shadow1967
shadow1967's Avatar
Nice project! Can't wait to see it.
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 01-20-2013, 11:01 PM   #4
blackdiesel
This truck not only is a big back glass cab, it also has the custom stainless, factory gmc radio and factory gmc deluxe heater controls. I've seen pics of a few 5 window task force gmc big trucks (which i'd really like to have!!!) But havent seen many straight big back F series trucks and none with the deluxe heater and factory radio.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-20-2013, 11:14 PM   #5
mr48chev
mr48chev's Avatar
That looks like it is going together great and add me to the subscribed list.
Boy Howdy would I love to have that shop right now.
My ongoing truck projects:
Old 01-20-2013, 11:30 PM   #6
blackdiesel
Thanks guys! I do love my shop, I'm very fortunate to be in a position to be able to have my name on the title.
Anyways the plan for the back half is a dump bed. I have the setup to run a pto off of a dodge automatic (dodge 23 spline np205 t-case with pto access due to the fact the 47rh has no pto plate) I have the transfer case and I have the pto pump for the 205, along with the bed and sissor lift.
I may just run it as a flat bed for now, with all i'll have to do later is slide in the hoist due to time constrant.
I want to keep it as ratty looking as possible but I'm not sold on the white looking paint. The interior is a two tone green, so would like to tie that into a patina look on the exterior. Any suggestions??
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-21-2013, 01:14 AM   #7
buggy5872
buggy5872's Avatar
Good to see another LCF saved.....looks like you are well on your way to a great truck.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 01-21-2013, 01:55 AM   #8
Maxxd07
Maxxd07's Avatar
I am liking this one, on board for more sweetness!
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 01-21-2013, 08:18 PM   #9
_Ogre
_Ogre's Avatar
nice find, nice save
shop air compressor timer
Old 01-21-2013, 11:10 PM   #10
blackdiesel
I'll get around to posting cab and grill support mounts one of these days, but for now i'll try to keep up with my daily progress
Yesterday and today I have messed around with the steering. I like the old school look, and despite my better judgement i'm going to stick with a non-tilt column. Besides that the stock steering wheel and hydromatic trans shifter adds to the look. Due to the severe steering shaft and u-joint angles I cut the stock shaft off flush with where it came through the floor. Then I cut off the end of a dodge column I had laying around and made it fit like this:
I drilled a 1/4" hole throught it to accomidate a steel roll pin. Today i picked up a bearing that would center the steering rod inside the column tube. Local bearing shop didn't have one that would fit as luck would have it so i got the closest they had and made it fit:
I beat the 1/4" roll pin in it, then a 3/16" in that and finally a 1/16" pin each inside of the other. I welded both ends of the hole then drilled a countersink hole 90* to that and burned it in hot.
I'm quite relieved that this will allow me to use the stock dodge steering shaft. I was dreading buying Borgeson double u-joints @ $150 apiece!!! It is at quite an angle, which I will take a pic of after I mount the cab for the last time. (still needs to come off for finish welding of cab mounts and I am going to build the trans)
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-22-2013, 10:57 PM   #11
blackdiesel
mounted my brake booster tonight, in the process I also got the brake pedal piviot and fuel pedal mounted. Two for the price of one! ha. Brake pedal needs a little more travel so I will cut it and bend it up. The accelerator pedal is in the way of the steering column but that will be easily fixed.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-23-2013, 12:40 AM   #12
sqrlnts
I am so jealous of your great find! I am hopping on this rig build thread cause you got TONS of room. Plus a Cummins :-)
sqrlnts is offline   Reply With Quote
Old 01-23-2013, 09:45 PM   #13
blackdiesel
it looks much more apparent in a picture vs in person that if i do go with the regular pickup fender that it needs to be scooted back. However there is a meathod to my madness, the farther i scoot the fender back the more difficult the front of the fender is going to be to graft into one another.
Anyways what do yall think? new fender or oem?
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-23-2013, 10:23 PM   #14
cAlvis165
cAlvis165's Avatar
I like the pickup fender. Do you know what size tires you are going to run on the finished project? That would help determine the "look."
Bigger tires look good with a stock fender
Old 01-23-2013, 10:35 PM   #15
blackdiesel
your looking at them. 3rd gen dodge dually wheels with tires came in at $400 dollars. Couldnt justify $900 dollar adapters, $600 dollar steel wheels, $2100 dollars in tires for 22.5's. Plus the weight of one big wheel/tire is more than a set of duals that i am running now. I hate additional un-sprung weight.
I'm putting my savings towards trans parts and seat upholestry
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-23-2013, 10:49 PM   #16
cAlvis165
cAlvis165's Avatar
If you run the smaller (smaller than Big Bertha anyway) tires, you end up with a more "hot rod" look, which I like. In that case, I like the fender mods you're working on.
Old 01-23-2013, 10:55 PM   #17
Chevette
Chevette's Avatar
Your truck is looking good. I really like what you're doing with the front fenders. Great idea!
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 01-24-2013, 12:18 AM   #18
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Awesome project! The cab fit on that dodge chassis really nice! I think your truck would look cool painted and then sanded and flat cleared for your patina look. Keep up the great work!
Ryan
1969 Chevy milk truck
Old 01-24-2013, 10:21 AM   #19
Coach529
Coach529's Avatar
Awesome build......subscribed!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-24-2013, 01:37 PM   #20
Fleet '66
Active Member
Fleet '66's Avatar
Subscribed. I want to see how this one turns out! Looks like you have a plan. These older LCF and COE trucks are so cool. Good Luck on the transformation.
Fleet '66
'66 C-10 SWB 350 w/3 spd OD 4:11's - driver/project...future T-5 trans upgrade
'64 C-10 LWB BBW near future project - "The Wife's Ride"
'58 "Apache"Stepside BBW w/'75 K-10 4x4 conversion 331 w/350TH and NP 205 transfer 3:73's - occasional driver/ show
Fleet '66 is offline   Reply With Quote
Old 01-24-2013, 03:00 PM   #21
63 & 64 Bowties
and a few others
Another big Cummins fan subscribed.
(I've got two Dodge Cummins)
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-24-2013, 04:46 PM   #22
_Ogre
_Ogre's Avatar
nice work on the fender. is that just a truck fender cut in?
Old 01-24-2013, 04:49 PM   #23
_Ogre
_Ogre's Avatar
i think your shop has a little more ''stuff'' laying around than mine
Old 01-24-2013, 05:04 PM   #24
blackdiesel
You got it!
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-24-2013, 10:25 PM   #25
blackdiesel
Much better i think!! still lack quite a bit of fine tuning in the front and especially by the step. Need to get these dialed in so I can pull the front sheet metal off so I can exchange the exhaust manifold with an industrial 5.9 manifold i robbed from a school bus. This will locate the turbo much closer to the block and underneith the 5th and 6th cylinders; allowing me to weld back in much of the passenger side floor board.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
