Old 01-27-2013, 11:36 PM   #1
purdeydoubles
1968 GMC 3/4 Ton 4x4 lwb step side?
Hey guys I am brand new to the forum, and also new to these trucks. I have a 1968 GMC 3/4 Ton 4x4 long bed step side that i just bought from my girlfriends dad. I have had a very hard time finding info on this truck as it seems that this veriation is not too common. Is this a rare truck?
purdeydoubles is offline   Reply With Quote
Old 01-28-2013, 02:13 AM   #2
SS Tim
SS Tim's Avatar
Re: 1968 GMC 3/4 Ton 4x4 lwb step side?
With that name I'd expect you to be more of a Range Rover classic owner (not a bad thing :-) ), but to answer your question the 3/4 4x4 stepside were a fairly low production vehicle and usually commercial use trucks. Not sure where you can find actual GMC production numbers for it but Chevy the same year was about 1047 for the '68 K20 stepside.
Welcome to the board!
SS Tim is offline   Reply With Quote
Old 01-28-2013, 02:18 AM   #3
airdale94
airdale94's Avatar
Welcome to the forum! The long bed step sides I believe have the 8 1/2' bed like the Longhorns. Which I think actually have 1 ton suspensions. I'm pretty sure none of them are 4X4. I don't recall ever seeing a longbed stepside 3/4 ton 4X4, but I'm not sure. The long bed step sides and Longhorns are not exactly "rare" but there but there are less of them. Surely someone more knowledgeable than me will chime in. You should post some pictures.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 01-28-2013, 02:55 AM   #4
SS Tim
SS Tim's Avatar
Well to expand on my first post.
K2500 GMC trucks 4x4 3/4 ton were built on a 127" wheelbase.
It was offered in Chassis Cab, Wideside and Fenderside versions.
As you mentioned there were other bed sizes but not on a K2500.
The 8 1/2' bed was a Wideside only offering on a 1 ton chassis with a 133" wb as a 4x2 only in C2500 or C3000 ratings.
There was a 9' Fenderside C3500 as well, again 4x2 only.
Historically the 3/4 4x4 stepside/fenderside trucks were low production commercial use trucks and as I stated above Chevy built 1047 in '68 and since GMC number are usually lower it might very well be below 1000 units.
Old 01-28-2013, 03:14 AM   #5
SS Tim
SS Tim's Avatar
Here are some pictures of a very nice GMC K2500 Wideside.
Old 01-28-2013, 06:38 AM   #6
daves72C10D
daves72C10D's Avatar
Never seen one of those. Is that the stock ride height? I like the looks of it alot.
1972 Custom 10 Deluxe- original paint, interior- 72k miles
http://www.cardomain.com/ride/2466316
Cheap, Fast or Good. Pick any two.
1990 Eagle Talon AWD
1991.5 W250 CTD
1992 Cushman Truckster- Haulster
daves72C10D is offline   Reply With Quote
Old 01-28-2013, 06:41 AM   #7
gmc 2500 4x4
nice!!
gmc 2500 4x4 is offline   Reply With Quote
Old 01-28-2013, 08:09 AM   #8
Tim meant to say that's a Fenderside,the GMC equivalent to Stepside.
Old 01-28-2013, 10:26 AM   #9
purdeydoubles
Thank you guys for the information so far. I am working on the pictures and will have them up shortly. The bed on this truck doesn't have the spare tire cutout on the drivers side. It has the wooden bed (although it is in need of replacement), clearance lights (chicken lights), and is sitting on 6" of lift. Hope this might help to sort some questions out.
Old 01-28-2013, 11:28 AM   #10
SS Tim
SS Tim's Avatar
Thanks for catching that Tim, can someone edit that in post #5?
Old 01-28-2013, 03:33 PM   #11
purdeydoubles
My truck has the rockwell transmission and transfercase and i can't get the linkage to move the low range piston (sorry if that isn't the correct term). Is there a simple sollution to this issue or do in need to drop it out and overhaul the linkage. I can pull that piston, but only with the help of a prybar.
Old 01-28-2013, 04:12 PM   #12
BigRed76
BigRed76's Avatar
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-28-2013, 04:13 PM   #13
SS Tim
SS Tim's Avatar
Sounds like you are going inside and parts can be an issue.
Here is the exploded view.
If you don't have the service and overhaul manuals they can be downloaded here.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
If you have to pry on the linkage and it will not reverse there is likely a fork isssue or interlock. Dropping the trans and pulling the cover should give a quick idea on what the damage is and what parts are needed. Unfortunatelly it also leaves your truck stranded. Might start a search to see if there is a spare about to do a temporary exchange.
Starting a seperate thread like "T221 Help needed" in the 4x4 section might get more/better results after trying a site search.
Old 01-28-2013, 04:14 PM   #14
purdeydoubles
Thanks for the info!
Old 02-06-2013, 12:48 AM   #15
purdeydoubles
Not the best pictures in the world, but here she is!
Old 02-06-2013, 01:47 AM   #16
dougo
dougo's Avatar
Very cool truck. Welcome to the board.
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
Old 02-06-2013, 02:39 AM   #17
CrewCab59
CrewCab59's Avatar
Thumbs up Re: 1968 GMC 3/4 Ton 4x4 lwb step side?
Very nice , got to love the long steps .
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 02-06-2013, 02:42 AM   #18
MusicMan70
MusicMan70's Avatar
Nice! So all that side trim didn't continue onto the fender-sides, I'm guessin'.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 02-06-2013, 02:46 AM   #19
SS Tim
SS Tim's Avatar
Very nice, now how about a SPID or at least some specifics. Any luck with the t-case issue? By chance were you trying to shift it static with the engine off?
Old 02-06-2013, 03:09 AM   #20
SS Tim
SS Tim's Avatar
No, the 67-68 Chevy/GMC stepsides/fendersides unlike the later 69-72 trucks could be ordered with trim. However it was on the cab only.
Here is a '67 9'CST
Old 02-06-2013, 06:30 AM   #21
gmc 2500 4x4
i love your truck!!
Old 02-06-2013, 06:00 PM   #22
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Love it! I wouldn't change a thing on that beast... Perfect color and patina
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 02-06-2013, 06:14 PM   #23
Madtat
Madtat's Avatar
nice truck. thats one heck of a rear bumper!
Madtat is offline   Reply With Quote
Old 02-06-2013, 08:13 PM   #24
srvivor71
srvivor71's Avatar
Great looking truck!!! Love the color (but I may be partial).
srvivor71 is offline   Reply With Quote
Old 02-06-2013, 08:35 PM   #25
cheyenne shortstep
cheyenne shortstep's Avatar
That truck is about as cool as it can be, I wouldn't change a thing.
From the slots to the stance and perfect patina, I would drive the wheels off that thing.
Thanks to SSTim I learn something new, never knew '67'68 stepsides could be had with trim.
cheyenne shortstep is offline   Reply With Quote
