Old 01-29-2013, 10:04 AM   #1
Hart_Rod
Hart_Rod's Avatar
Porterbuilt extreme Dropmember and 2 piece drive shaft question???
Does anyone have any pictures of their 2 piece driveshaft installed in a PB extreme dropmember setup? Also, pictures and part numbers of the carrier bearing you are using would be great. TIA
Hart_Rod is offline   Reply With Quote
Old 01-29-2013, 11:02 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt extreme Dropmember and 2 piece drive shaft question???
Here is a Drtyrats thread: http://67-72chevytrucks.com/vboard/s...=406070&page=9
Also Del has a bunch of pics. We use the later model carrier bearing that has the mounting holes perpindicular to the drive-shaft. You can cross this part number from Carquest: HB88107A it has the 1.378 bore for the shaft.
You will have to shim the carrier bearing up approx. 2"... when you get ready for install shoot me a text and I will call you to explain a couple details for an easy install.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-30-2013, 09:45 PM   #3
YBNORML
YBNORML's Avatar
Great info, someday I might actually get to this stage
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-30-2013, 10:20 PM   #4
Hart_Rod
Hart_Rod's Avatar
Nate
Found it online:
http://www.carquest.com/webapp/wcs/s...6816?acesApp=1
Thanks Nate. I'll give you a call when I get closer.
Old 01-30-2013, 10:47 PM   #5
Bennett68C10
Bennett68C10's Avatar
Don't want to hijack this thread from Rob but I will need this info after I install the Mild Rear Dropmember I just ordered. I'm guessing since it's not the extreme dropmember I won't have to raise my carrier bearing by 2 inches. I'm subscribing for future updates.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-30-2013, 10:56 PM   #6
Hart_Rod
Hart_Rod's Avatar
The more the merrier, . You might be able to get away with using a 1 piece driveshaft.....
Old 01-30-2013, 11:26 PM   #7
Bennett68C10
I hope so I would rather run a 1 piece driveshaft, but I doubt it with my luck.
Keith
66 Suburban
IG: bennett68c10
Old 01-31-2013, 12:11 AM   #8
Rochlow
I'm need this info also. I spoke with Del about building a 2pc drive shaft for this application. He quoted around $700 complete, I think.
Rochlow is offline   Reply With Quote
Old 01-31-2013, 12:35 AM   #9
jmedero
jmedero's Avatar
How about the billet one CPP makes rob. A little shinny to match the headers...
I have one if you want to use it for mock up. Let me know.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-31-2013, 01:05 AM   #10
Delmo
Delmo's Avatar
I'll get some new pics of the one I just stuck in Grey Goose. It came in at $680 from scratch.
Delmo is offline   Reply With Quote
Old 01-31-2013, 09:13 AM   #11
Bennett68C10
Del I'm interested in the pics, also how much horsepower does this shaft handle. I have mild Big Block in mine but it still puts out over 400 hp. I don't want it to chew up a driveshaft.
Keith
66 Suburban
IG: bennett68c10
Old 04-15-2013, 04:27 PM   #12
Hart_Rod
Hart_Rod's Avatar
Hey Del, any pictures yet? thanks
Old 04-16-2013, 10:20 PM   #13
Bennett68C10
X2 as now I'm running the extreme rear dropmember and will need a 2pc driveshaft
Keith
66 Suburban
IG: bennett68c10
Old 04-30-2013, 11:23 PM   #14
RRC
RRC's Avatar
X3 just thinking about drive shafts
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline   Reply With Quote
Old 04-30-2013, 11:43 PM   #15
jmedero
jmedero's Avatar
Yea it's time rob gets shafted...... Lol.
Ok I'm going to get back to watching other people build trucks. Lol
Old 06-11-2013, 12:32 PM   #16
Hart_Rod
Hart_Rod's Avatar
Still waiting for pictures and a write up on this.
Old 06-15-2013, 06:57 AM   #17
Hart_Rod
Hart_Rod's Avatar
bttt
Old 06-23-2013, 09:09 PM   #18
Hart_Rod
Hart_Rod's Avatar
Where are those pictures Del?????
Old 06-23-2013, 10:17 PM   #19
Hart_Rod
Hart_Rod's Avatar
Holley LS accessory drive setup....check!
Old 06-23-2013, 10:19 PM   #20
Hart_Rod
Hart_Rod's Avatar
2010+ SS Camaro exhaust manifolds.....check!!
Old 06-23-2013, 10:22 PM   #21
Hart_Rod
Hart_Rod's Avatar
Hill's front wheel tubs...check!!!
Old 06-23-2013, 10:25 PM   #22
Hart_Rod
Hart_Rod's Avatar
2 piece drive shaft....HELP!!!!!
Old 06-23-2013, 10:26 PM   #23
RRC
RRC's Avatar
Looking good!!!
Rocky Lake Kustoms
Russ
Old 06-23-2013, 11:37 PM   #24
oldman3
oldman3's Avatar
Sweeeeet...Jim
oldman3 is offline   Reply With Quote
Old 06-24-2013, 10:35 AM   #25
fastbagged68
fastbagged68's Avatar
Run a single driveshaft. Cut the Porterbuilt driveline hoop and make a new hoop that is taller.
You will love the Hills wheelwells. They fit like a glove.
fastbagged68 is offline   Reply With Quote
