Old 01-23-2017, 09:13 AM   #1
Low Elco
Originally Posted by Low Elco View Post
Looks good! I stumbled across this pic in my axalta calendar. You can get one at the paint stores.
Low Elco is offline   Reply With Quote
Old 01-23-2017, 11:35 AM   #2
Vic1947
Vic1947's Avatar
Re: Crusty Rusty Leaky Squeaky 67 Step
Originally Posted by jeh View Post
Vic, just when I think you've quit cutting things up , look what you've done!!!!
It's going to look awesome man, keep at it. I really enjoy reading and watching your build on here.
Thanks, Jason. Hope your big block and new tranny are still operating smoothly.
Thanks, Chip, this is the exact same truck I'm using as a guide. There are several differences between what they did and my approach, though.
1. They raised the bumper up about an inch and the ledge they built comes straight off the grille shell below the bottom molding. (red arrow)
2. They cut about an inch more off the side of the bumper end than I did. (green arrow)
3. They extended the bumper out a bit farther than I did and built out the fender to meet it which results in a tapered body line versus the parallel line that's stock. (yellow arrows)
Their mods look great in the overall context of the build which was highly customized, but I was dealing with a stock setup and didn't want to modify the frame horns to lift the bumper up. So plan B was to rob as much of the idea as I could without the extensive relocations. This means I have a different problem to solve, which is how to make the transition below the corner of the headlight roll back under and follow the edge of the bumper at the same time. That's my next hurdle.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 01-24-2017, 07:17 PM   #3
Elliot949
Elliot949's Avatar
That is working out nicely...
I would think about running the "vertical lip all the way down that way the curve of the bumper is easier to work in the front piece and the side piece...
Just a thought...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 01-24-2017, 07:43 PM   #4
sduckworth13
sduckworth13's Avatar
Nice work Vic! That looks slick!
Scott
sduckworth13 is offline   Reply With Quote
Old 01-26-2017, 07:50 PM   #5
Vic1947
Vic1947's Avatar
Originally Posted by Elliot949 View Post
That is working out nicely... I would think about running the "vertical lip all the way down that way the curve of the bumper is easier to work in the front piece and the side piece...
Thanks, Dan, I did extend the vertical sheetmetal on the front of the fender down to the curved piece. Not sure if this is what you meant, but it filled the gap about as well as could be expected.
Thanks, Scott, now I need to tack everything up real good and move on to the other side.
I switched out wire in the MIG machine today to silicon bronze. Whole new learning curve. If you slow the wire speed down, it balls up on the end and if you speed it up, it welds great but spatters like crazy. The anti-spatter spray I use doesn't seem to work all that well with the SB. May have to lay my leather leggings adjacent to the weld area to help alleviate the problem.
The powder coater called today and said my stuff was ready so Dad, the dog and I went over to get it. Looks like pearlescent aluminum paint right now. They cure it in the oven at 750 degrees, so we'll see what it looks like when the engine fires up and it gets some real heat on it.
Victor
Old 01-26-2017, 08:17 PM   #6
Elliot949
Elliot949's Avatar
That exhaust is killer...
Old 01-26-2017, 10:54 PM   #7
ken4444
...I switched out wire in the MIG machine today to silicon bronze. Whole new learning curve..
I did some reading on silicon bronze MIG welding wire. What was the benefit to using it here?
ken4444 is offline   Reply With Quote
Old 01-27-2017, 12:01 AM   #8
Vic1947
Vic1947's Avatar
Well, my personal observation about it is that it has a lower melting point which translates into less shrinkage in the weld area. It's softer than steel, which makes it easier to grind so you remove less of the adjacent material. On thin sheetmetal, that can make a big difference.
The downsides are that it can be finicky and ugly to weld. With the TIG, it doesn't like to bridge gaps very much. Both sides of the gap have to be wet before the weld puddle will form correctly. I noticed with the MIG (after just a few test welds to determine wire speed and amperage) it leaves a lot of smut and spatter. I'm using pure argon which is recommended, but some say a mix of helium and argon also works if the material is thicker. Too much wire speed is probably the issue with the spatter, but if you slow it down, you don't get a smooth puddle. Looks a lot like a cold solder joint.
At this point, I can't honestly weigh in on the cost/benefit of using it. I like it for applications where strength is less a consideration than cosmetics. Not much I hate worse than trying to be as careful as possible, only to have whoop-de-do's in the panel when everything cools off. MIG with EZ grind wire is not far behind, though.
Victor
Old 01-27-2017, 09:57 AM   #9
ken4444
Well, my personal observation about it..
Thanks for the detailed explanation! The positives sound great because grinding a newly welded sheet metal seam is a pain, and like you mentioned, less heat is better on thin metal when burn though is a possibility. You list a number of drawbacks which are important. For my own work I will probably stick with regular wire and C25 gas, but I'm glad to have learned about the existence of this other wire.
Old 01-26-2017, 09:33 PM   #10
sduckworth13
Look like they did a real nice job on the exhaust!
Scott
Old 01-27-2017, 01:39 PM   #11
Low Elco
I'm diggin' it! I'm a big flag-waver for EZ-grind. (See Vic rolling his eyes.... look, there he goes...) It's soo much easier and more workable on sheet stuff. Vic did the guy in KCK do your Coating? Eric was gonna use him, but it was more than he wanted to spend. Keep it up, this is coming out neat!
Old 01-27-2017, 07:50 PM   #12
raggedjim
raggedjim's Avatar
Great job on that front bumper. I use the esab ezgrind in .023 wire and I really like it. The .030 was too much for me to use on sheet metal.
Keep up the good work. Rg
raggedjim is offline   Reply With Quote
Old 01-30-2017, 02:52 PM   #13
jlsanborn
jlsanborn's Avatar
All that is looking squeaky clean Vic!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 01-31-2017, 03:34 AM   #14
AKC
AKC's Avatar
Always a joy to see your work Vic.
Hope you dad is doing well and you're seeing good.
'Anela - AKC's 1968 C30 1T Flattie
"Trouble Rides A Fast Horse..."
AKC is offline   Reply With Quote
Old 01-31-2017, 06:43 AM   #15
GR8-68
GR8-68's Avatar
They make tucking the bumpers look easy on Kindig and Overhaulin Keep at it though it will look great when you finish up
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 01-31-2017, 09:12 AM   #16
Low Elco
I was thinking about you last night, they were tucking the bumpers on an 80 El Camino on Fast n Loud.
Old 02-01-2017, 07:40 PM   #17
Vic1947
Vic1947's Avatar
Thanks, John!
Yep, we're good on both counts.
That's the magic of TV! It just kills me when they tear something apart then skip nearly everything in between and go straight for the reveal.
Don't tell me how it ends... I have it on the DVR and haven't watched it yet.
We've had appointments every day this week except Friday for Dad or the dog which reduces the time available for beating on the bumper. I added a thin strip to the passenger side to close up the gap a bit and welded out some more splices. I've dialed the heat way back and started going much slower which has produced better results. Hole is starting to close up on the driver side.
I finally got in touch with the shop that does the spray on chrome and I'm weighing whether to go that route. They only guarantee the work if they do everything from the ground up. Bumpers start at $700 and $85/hr. for bodywork and prep. So I'd probably be looking at over a grand for just the front. I'm starting to think a high gloss silver next to the flat red oxide color on the truck might look pretty dang good.
Victor
Old 02-01-2017, 07:41 PM   #18
Elliot949
Elliot949's Avatar
Thanks, John!
That is looking great...
Old 02-02-2017, 11:20 AM   #19
69CST-V
69CST-V's Avatar
Nice work as always...
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 02-02-2017, 02:42 PM   #20
Low Elco
I am in the wrong business. That is all.
Looks good!
Old 02-03-2017, 09:29 AM   #21
snipescastle2
snipescastle2's Avatar
Talking Re: Crusty Rusty Leaky Squeaky 67 Step
Vic,
I gotta say, you have the utmost patience with this project....I'd have lost my mind by now.....just dealing with the little issues I'm having are driving me banana's
I'm trying to sort out this whole Holley carburetor problem I'm having, and I'm taking it step by step, but I'm finding myself reaching for that "Quadrajet" sitting on the shelf rather often, but I'm not one to give up on anything.....
Have a good one!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 02-05-2017, 07:23 PM   #22
Vic1947
Vic1947's Avatar
Thanks, everyone. I've been switching back and forth between working on CRLS and ripping a bunch of CD's that belong to Dad. When he moved in with us, we stashed a box full of them and I'm just now getting around to adding them to the music library. He wants to give an MP3 player to my uncle who's in assisted living and only has a radio with local stations. So, lots of trips up and down the stairs.
The metal work on the driver side is mostly finished. Next up are the filler panels that go between the bumper and the grille shell. You can see the pattern in one of the photos below. Not sure how well my box and pan brake is going to like bending that long of a piece... or if I have enough grunt to get the job done.
Victor
Old 02-06-2017, 06:19 PM   #23
Xeen
Xeen's Avatar
The bumper mod has really cleaned up the front end of the pickup, much more refined than the original factory design. I can't wait to see it all welded in and finished up, this is good stuff.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 02-08-2017, 07:24 PM   #24
Vic1947
Vic1947's Avatar
Thanks, Brian, me too!
I went ahead and used my box and pan brake to make the bends in the filler strips. The both of us creaked and groaned a lot, but we got 'er done. The profile was a bit more laid back than I'd planned, but it was necessary to make the filler strips flush with the bumper. I need the lip on the bottom because I plan to install these with panel adhesive. I've used it on the roof and the hood and it seems to work real well. We'll see if all that glue holds when we're going down the road doin' the shake and bake.
I put some small curves at the ends of the filler strips, but when I put the bumper back on after trimming it, I had too much gap with the strips in the initial location. Took the clecos out and let the strips slide forward and the gaps look way better. They also lay parallel to the bumper now. I'll have to massage the ends and the center a bit more, but I'm pretty happy with the overall look as it sits right now.
Victor
Old 02-08-2017, 08:52 PM   #25
sduckworth13
Nice work Vic! That does look really nice!
Scott
