Old 02-09-2013, 05:38 PM   #1
haulnrat
haulnrat's Avatar
late model a/c swap into early pickup
Has anyone done this or have information on swapping an air conditioning system from a '95-'99 c/k into an early truck. Let me know what the pros and cons might be.
Thanks in advance.
haulnrat is offline   Reply With Quote
Old 02-09-2013, 05:43 PM   #2
1972CST
1972CST's Avatar
Re: late model a/c swap into early pickup
I have had this in the back of my mind also. I think it may be a good fit for our trucks.
1972CST is offline   Reply With Quote
Old 02-09-2013, 07:55 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I had a later model evaporator put into my original case with a sanden compressor, made lines and it works fine. Kept everything inside factory.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 02-09-2013, 08:56 PM   #4
oldspowered67C10
Those trucks used a CCOT(cycling clutch orifice tube) type system so rather than running the compressor constantly and using a expansion valve to regulate the evaporator temperature they use a orifice tube and a low pressure switch to cycle the compressor to control the temp.
The major differences hardware wise is that the CCOT system has a accumulator after the evaporator rather than before the condenser, has a orifice tube before the evaporator instead of a expansion valve and the way the electrical is set-up slightly different.
Ideally, you'd want to use the evaporator, the condenser and compressor from the donor truck but I suppose if you had a TIG welder you could modify the original evaporator and condenser to work. The electrical and having new hoses made would be the easy part.
oldspowered67C10 is offline   Reply With Quote
Old 02-09-2013, 10:39 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: late model a/c swap into early pickup
My 71. Factory boxes with late 80's components.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-09-2013, 10:44 PM   #6
haulnrat
haulnrat's Avatar
I'm dealing with a non factory air '72. So trying to make it look original is not a priority. I would plan on taking everything from the donor truck. I'm just not sure how big of a job it would be to remove everything. If would be worth it or not, but if I can save a $1000 over an aftermarket. Then it might be worth it.
Old 02-09-2013, 11:40 PM   #7
bonnieclyde100
i took a ac from a 1991 chevy truck and installed all the under hood parts into my 69 and left the inside factory controls and ducting alone. i had to modify the factory under hood air box to fit the 91 evaporator. here are a few pics
bonnieclyde100 is offline   Reply With Quote
Old 02-09-2013, 11:42 PM   #8
bonnieclyde100
more pics
Old 02-09-2013, 11:45 PM   #9
1972CST
1972CST's Avatar
Great info here.
Old 02-09-2013, 11:59 PM   #10
bonnieclyde100
a few more pics of my airbox
Old 02-10-2013, 12:08 AM   #11
bonnieclyde100
Old 02-10-2013, 09:59 PM   #12
haulnrat
haulnrat's Avatar
Thanks for info nice work
Old 02-10-2013, 10:23 PM   #13
1970 CST STEP
bonnieclyde100, very nice work!
1967 SWB (small window) original
1970 4x4 STEP
1970 CST SWB FLEET
1972 SWB FLEET ORIGINAL
1970 CST STEP is offline   Reply With Quote
Old 11-02-2016, 09:02 PM   #14
lanehicks76
Hey guys, I know this post is old, but I have a question for Bonnieclyde100, If he is still around, I am currently doing a 98 vortec swap into a 72 c10 and im swapping AC system too. before I cut the evaporator box to fit the 98 evap. is there a year model that is closer to the specs of my 72 evap.? Thanks in advance.
lanehicks76 is offline   Reply With Quote
Old 11-02-2016, 09:35 PM   #15
bonnieclyde100
I don't know if there is a evap that is closer to the 72 model. I just used what was easiest for me at the time by what engine I was using in the truck. sorry I don't have more info for you
Old 11-02-2016, 09:56 PM   #16
Bigdav160
Bigdav160's Avatar
Blazer and Suburban up until 1991 look to have the same (or similar) evap cases to the '72 case
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-03-2016, 04:15 AM   #17
lanehicks76
Thumbs up Re: late model a/c swap into early pickup
Ok thanks. I will look into them
Old 11-10-2016, 02:41 PM   #18
lanehicks76
Ok guys. I went with an 87 chevy truck evaporator. Fits pretty close I got my gaskets and compressor manifold in. Now I need to know what condenser will fit the best with standard (I assume) fittings, not metric. also what do I need to do about my orifice location. TIA
Old 11-10-2016, 07:52 PM   #19
kaycee
kaycee's Avatar
I wonder if cars are same as the truck/sub.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 11-10-2016, 08:31 PM   #20
lanehicks76
Originally Posted by bonnieclyde100 View Post
What exhaust setup are you running
Old 11-10-2016, 08:39 PM   #21
lanehicks76
what condensor did you use and what line, orfice setup did you use? TIA
Old 11-11-2016, 10:36 AM   #22
F.A.A.benny
Andy got kit from Classic Auto Air. They are also now known as Original Air Group. If you call, ask t speak to Curtis. I used to work with him there. Good guy and knows his stuff
F.A.A.benny is offline   Reply With Quote
Old 11-11-2016, 10:39 AM   #23
F.A.A.benny
Old air products also sells the same condenser that Andy got from CAA. It is a bolt in deal
Old 11-11-2016, 10:52 AM   #24
Andy4639
Old member
Andy4639's Avatar
Talking Re: late model a/c swap into early pickup
Correct, sorry just notice this.
Classic air group is the best. I've used them several times and never had a problem, well 1 time but they took care of it.
Old 11-11-2016, 02:47 PM   #25
lanehicks76
Thanks guys. Really appreciate your help.
