Larry,
Are those naked boobies I see by your toolbox??? ![]() ![]() ![]() ![]() ![]() ![]() Joe |
#2 | |
Where did you get the instructins, etc. Thanks Chris ![]() |
#3 | |
F.A.S.T. president
![]() Join Date: Sep 2003
I dont like to get my jeans dirty ![]() |
Boosted Member
![]() My newly completed shop. The "small" part is 24x30, and the larger part is 30x36. A 100,000 BTU industrial heater provides warmth for wrenching activities, and it will soon have an office built inside for our company. My dad, brothers and I built it ourselves. This is in addition to the 2 stall attached to the house.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
![]() Join Date: Jun 2002
moneyguru, A friend did his shop with the radiant heat, so thats where I got the idea. If you type in "radiant heat" on your search engine you will get alot if info... I used 900' of 1/2" "pex" tubing (3, 300' lengths) buried in the concrete. A typical 40 gallon hot water tank, a manifold system made from copper tubing, and a $80.00 dollar recirculating pump made for this type of application. The pump uses only 65 watts. I also insulated the foundation around the outside (2' deep)
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
I have also installed radiant heat in my floor. It is the most increddible heat system I have seen. The floor is warm to touch, There is no air movement from fans and is quiet. I use an electric boiler. I do not know how to post a pic, but if someone could let me know how, I will. I LOVE MY HEAT. Las week it was -20 Celcius and walking into the garage was nice. I do not no what the monthly cost will be as I have just got it up and running. I am using a Propylyne Glycol as a heating fluid. It gets way below freezing here and if the power ever went off for an extended period of time, I would be in serious trouble.
Jason |
Listening since '86
Or you could have something like mine!
![]() Ah well - better than none I guess. BTW - I bet my "heated floor" was the cheapest - it's called a creeper!! LMFAO!:p
2007 Saturn Aura - hey it WAS a GM product |
Don't forget about the floor. My friends shop has a ashphalt floor instead of concrete. If he lays a car hood on it's edge, the corners will sink in to the ashphalt. The shop was biult before he moved there!.
Nelson 1970 C10 350 Auto. A/C not Working |
Happy to be here
![]() Join Date: Mar 2000
I'm not sure what your budget is, but here's some neat stuff if you have the funds...
![]() Or this- ![]()
Happy to be here
And the guys are all correct. Build it as big as you can. I did, and all my stuff still won't fit. I have a 12x16' storage shed behind my garage just for pool chemicals, and lawn tools. All my trucks still won't fit inside...
Here is my boiler set up.
#12 | |
Half a bubble off!
There are some pleasures in life, one of which is admiration of the ideal feminine physique, and I admire that attribute in a woman! When I was 16, I had to keep those pictures hidden, now I put 'em where I damn well please. It's my shop, so anyone that doesn't like it can stay out, hehee! ![]()
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
look up garage plans on the internet, you'll find lots
My son, my joy.
That radiant heat thing is where its at. My neighbor just built a brand new garage and he has it. Nice and warm all winter. Has what jasonrog has, an on-demand water heater.
#15 |
Vortec in the works
Close freinds garage
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
#16 |
![]() Join Date: Dec 1999
so far nobody has mentioned a pit in the floor. for those of us that cant afford the lift or dont have room for it, its a great way to do work underneath comfortably and it can always be covered with boards or something more creative when not in use
Current owner of 2016 2500 Silverado Midnight Edition. Former owner of: 69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4 72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust |
#17 |
TEXAS 68,
Wow, You sure that's a garage and not a museum?? ![]()
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#18 |
Vortec in the works
a friend of mine restores 55-57 chevys and we took those before he moved all the tools in, its not that clean now but still looks great. 30x36 with 10' ceilings.
#19 |
I don't know if a pit is lagal anywhere, anymore. I know it isn't around here.
69 GMC K10 ..some restoration required....still.. ![]() |
#20 |
why would they outlaw pits? because people/cars can fall in?
70 longbed 496/th400/Ford 9" |
#21 |
Fire hazard too...gas fumes are heavier than air and will collect in the bottom of the pit, and then ignite. Also, most people put a drain in the floor, and the EPA frowns on the potential for contaminants to enter the ground water.
