Old 03-12-2013, 07:32 PM   #1
mrhino
20 mpg or not?
Within the week or so, the wife & I will be starting the engine build for the crew cab project we have going on. Over the weekend, It brought up a interesting debate with a few buddies that I trust and respect for their engine performance knowledge. My Goal with this engine is to get 20 MPG. A couple said it could be done and a couple said it wouldn't happen. Everyone made their points and theories. The debate and conversation was educational and interesting so I thought Id ask it here and see what some of the thoughts are.
The truck is a 88 1 ton crew.
4:11 rear
305/70/16 tires
700r4 trans
the engine will be a .30 over 5.7
58cc 187 swirl port heads with a mild port job.
20cc dished pistons
vortec Roller Cam 191º/196º 0.414"/.428" lift on a 111º LSA.
1 5/8 headers
so do you think it will get 20 MPG?
mrhino is offline   Reply With Quote
Old 03-12-2013, 07:36 PM   #2
thotfulspot
Re: 20 mpg or not?
Since our vehicles have the aerodynamics of a brick I would be surprised if 20 mpg is possible unless coasting downhills.
thotfulspot is offline   Reply With Quote
Old 03-12-2013, 07:44 PM   #3
Keith Seymore
Keith Seymore's Avatar
Re: 20 mpg or not?
I suspect no.
I can get 20-22 ish with my truck, which is a 1/2 ton shortbox with a 4.3, 3.73 gears and overdrive.
You've got your work cut out for you, especially with those 4.11 gears.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 03-12-2013, 07:56 PM   #4
GM-power
GM-power's Avatar
Re: 20 mpg or not?
I highly doubt it. Its hard enough to get that with a sbc in a half ton.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 03-12-2013, 07:56 PM   #5
57rookie
Re: 20 mpg or not?
I work for the worlds largest heavy truck manufacture and we own our own engine company as well. My experience tells me with the current rear axle ratio, the rolling mass of the one ton, and the engine displacement with the specs you listed that 20mpg on a true highway only average is not realistic.
I would suspect if you watch your speed (60mph max) you might achieve a true highway only average of 17 - 18 mpg.
57rookie is offline   Reply With Quote
Old 03-12-2013, 07:58 PM   #6
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: 20 mpg or not?
Originally Posted by Keith Seymore View Post
I suspect no.
My 6 cyl 2x Jeep doesn't even do that.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-12-2013, 08:13 PM   #7
bohmankid
bohmankid's Avatar
Re: 20 mpg or not?
If you can get that beast to get 20 mpg, you should be an award winning engineer.
The weight, aerodynamics, size of the motor, tires, and wheel base all say no.
bohmankid is offline   Reply With Quote
Old 03-12-2013, 08:15 PM   #8
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: 20 mpg or not?
Certainly will have to change the gear ratio, the 700R4 will help with a lower ratio perhaps evan lower than 3.73. I'll be curious to see what you do get.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 03-12-2013, 08:30 PM   #9
mrhino
Re: 20 mpg or not?
I always new it would be a tall order. we all need goals right? I Figured I would be at about 1900 rpm at 65 mph
Old 03-12-2013, 09:03 PM   #10
ivorton74
ivorton74's Avatar
Re: 20 mpg or not?
pretty ambitious but like the others here I don't think u would achieve that. you would be better off swapping a 4.8 or 5.3 LS motor. you'll probably get 18mpg + with the LS motor...or switch to diesel.
ivorton74 is offline   Reply With Quote
Old 03-12-2013, 09:10 PM   #11
king-918
king-918's Avatar
Re: 20 mpg or not?
you're thinking about it all wrong, rid yourself of the old technology. time to find a hybrid Tahoe and get a Harvard grad
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 03-12-2013, 09:20 PM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 20 mpg or not?
6bt will do 20+
Old 03-12-2013, 10:04 PM   #13
Ziegelsteinfaust
Re: 20 mpg or not?
I don't think you get past 17 with those tires. There to wide, and heavy for mpg.
Plus you 14 bolt is a heavy girl at 550 pounds, and you'll need to do the disk conversion for rotational weight reductions. The disk conversion brings your 14 bolt down to a slim 475 pounds roughly.
Plus I think a 455 Buick will put down the torque you need for those tires if you need them, and the short stroke you need for mpg. I had a bolt-on "except headers" Electra for a minute with one, and 2.73 gears. It would regularly get 19mpg cruising 70 with the cruise one. I have a spare sitting in my garage from when I got the car, and I am on the fence of putting it in my C20.
Ziegelsteinfaust is offline   Reply With Quote
Old 03-12-2013, 10:10 PM   #14
meatwagon83
meatwagon83's Avatar
Re: 20 mpg or not?
not 20, maybe 16 or 17 if you keep you foot out of it
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 03-13-2013, 12:46 AM   #15
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 20 mpg or not?
I suspect no.
K
Where do you drive to get that good of mileage? city/ highway/what speeds/etc...?
Frank
Old 03-13-2013, 02:05 AM   #16
Oilbrnr
Oilbrnr's Avatar
Re: 20 mpg or not?
Yes, if idling off of a cliff into a mile deep crevasse.
Otherwise, no.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 03-13-2013, 02:46 AM   #17
74 stepside
74 stepside's Avatar
Re: 20 mpg or not?
With a Gearvendor added to that 700R4 you might get close, but realistically I dont see it. Heavy truck plus its lifted, thats a plow in the wind. No aerodynamics.
74 stepside is offline   Reply With Quote
Old 03-13-2013, 06:17 AM   #18
D13
D13's Avatar
Re: 20 mpg or not?
My 87 R10 gets 23mpg mixed, would get 26+ at 55 on the highway. But I'm running a 6.2 diesel, no turbo. SLOW.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 03-13-2013, 07:02 AM   #19
tucsonjwt
Re: 20 mpg or not?
For reference, the best I got out of a V8 was 18.5 highway on a 2010 4.8 GMC extended cab with 3.23 gear. On a 2010 V6 LWB Silveado I got 20 city/24 highway, but very little power. For gas mileage I think you should consider an economy car, and drive the truck sparingly.
tucsonjwt is offline   Reply With Quote
Old 03-13-2013, 07:51 AM   #20
Keith Seymore
Re: 20 mpg or not?
Roughly 30 mile commute (one way); mostly expressway, as fast as traffic will allow (my goal is 73 mph, probably ends up at 65 mph or so on average).
K
1979-1986
1986 - 2019
Old 03-13-2013, 10:32 AM   #21
SSC's76
No No
SSC's76's Avatar
Re: 20 mpg or not?
the engine cam and head combo is capable of doing it but like others have said you need to overcome the weight of the truck. i would suspect you will see 10 and 14 out of that combo in that truck. I would personally choose a more tq oriented camshaft it would provide much better results with your rear gear and trans your working with. anything that makes power from idle to 4500 would be great depending on your cruise rpm if it made max tq 500 + or - in that range thats where you will see the best results
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 03-13-2013, 10:51 AM   #22
mrhino
Re: 20 mpg or not?
I knew the weight of the truck would always be my downfall. Tire width was something I hadn't considered but it will add to the problem. Iv been playing with cam grinds. to find the best torque numbers. I mentioned the vortech cam cause it something iv had laying around and it it didnt seam too bad for bottom end torque and still be TBI friendly. 500 ftlb would be nice but im not sure I can do it with those heads. The engine is not together yet. so things can still be changed.
Old 03-13-2013, 12:35 PM   #23
rs72z
rs72z's Avatar
Re: 20 mpg or not?
I can get 18 on mostly highway with my ccsb dually. I have a 5.3, 4l60e and 4.10 gears. I doubt 20 will ever happen old school.
I would like to get mine out on a long tripp to see what it will do.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 03-13-2013, 12:38 PM   #24
camok10
camok10's Avatar
Re: 20 mpg or not?
I was averaging 16mpg out of my k5. I went from an average of 10-12 stock with 273's and 32's to a 4" lift a 44hd and a 14ff with 410's on 35's. it was just a mild tbi 350 with a low end cam, intake, high flow cat with dual 2 1/2" straight pipes off it.
I don't see 20, but I'd imagine around 15 possible out of it
98 K1500 ecsb
84 C10- 350/350- first vehicle still have 30 some latter
82 C10- 6.2l diesel 700r4
camok10 is offline   Reply With Quote
Old 03-13-2013, 12:58 PM   #25
86c20
86c20's Avatar
Re: 20 mpg or not?
well not saying you will get 20 but there are a few things that you need to do to help get it there. 1. gear it right. lot of guys over gear there trucks. find where your power band is and try to get your cruise speed in it. most stock small blocks are around1900ish to2300ish. not saying it is the most poweer but it is not luged down so much you have to shift alll the time. 2. air dam under the bumper. makes a big diff. my buddy did it on a dump truck and he gaind .25 mpg on averag. on a pickup i would think .5ish. 3. timing. timing is a big part or eco. in my c 20 the more retarded the wores i get. agian it is about freeing up power more then making power. 4.narrow tires. pizza cutters are the best. and free up all rolling resistanc. brake adj. should be right also. 5. elc fan. again freeing up power. did it in my monte ganied about .5 on the avg. 6. lock up trq convert. is better. standerd trans is best.
on the highway with my c20 i get 20's at 65-70 but my truck has stock size bfg at. and a crate350 that is 260hp and i run reg gas. good luck
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
