Widest Rear Tire With Factory 12 Bolt?
I have the rear lowered 6 inches. I have the factory 1970 12 bolt (C Clip elminator) I am going to mini-tub the girl. What is the widest rear tire I can go with? Also what backspace would I need? I'm jammed up here on this boys! Some pics would be helpful too. Ooo factory springs and trailing arms. Thanks!
1970 Chevy C10 shortbox- 454 1970 Chevy Nova- 383 1987 Grand National |
meowMEOWmeowMEOW
Re: Widest Rear Tire With Factory 12 Bolt?
I asked this, and ended up having to just go and measure; are you asking for the widest tire on a normal rim, or the widest rim AND tire you can stuff in there?
If you want to go as wide as you can, you'll need to have custom wheels made or ordered. I squeezed a 15x12 with a M/T drag radial in 325. Assuming the 12 bolt is stock width, that will be about the biggest you can go (a slightly larger diameter rim might get you a tiny bit more width inside, but not much)... it requires about an 8.5" backspacing, which is deeper than some companies will do, although you can get them. It makes rear brakes a pain though, depending on the rim size (I run 15s) you may have to modify your brakes. ![]()
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
The Engine Whisperer
We run a 31x18.5" hoosier on a minitub and smaller diameter springs.
Prostreet68 what backspace are you runnin? I was wondering if 15x12 with 7.5 backspace and 325 tire would fit?
meowMEOWmeowMEOW
Not sure if your slightly newer fleetsides are wider or not. I've got eh trailing arm suspension w/ jeep springs which are a tad wider.
If I would have gone with a 7.5" bs, the tire would rub into the outside of the fender.
![]() Join Date: Oct 2009
315/60/15 MT drag radial on 15x10 with 5" bs on stock width 12 bolt. No tubbing needed.
#7 | ||
And we're running 8.75inches of backspacing. |
I had 12.5 wide sportsman pro's on this old 71 with an off the shelf Centerline Telestar wheel.
![]() ![]() This truck was not that low you would need a little more back spacing but not a ton.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Here is link to a pic i posted last year for some one asking the same kind of question. I was lazy and didn't want to find the pic and upload again lol
14 or 14.5 wide wheels with 15 inch wide tires and all stock susp. and stock width rearend that is what it had when i bought it. http://67-72chevytrucks.com/vboard/s...12&postcount=8
Brandon Street Car Mafia |
I have a 15x12 6"back space will it work on a 1965 chevy truck ,what is the lest back space u can have with a15x12 wheel
Posted via Mobile Device |
60-66 Nut
Is your truck a stepside or a fleetside?
Fleetside
mini truck racer
Welcome to the forum
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#15 |
#16 |
Truck and auto performance nut
My plan is replacing the 12 bolt with a stronger rear (Dana 60 or 9.5" 14 bolt) and narrow it by 1.5-2" per side w/mini tubs and 15x12's...then 315/60-15's will fit easily.
but for now...its factory 12 bolt with new Eaton posi and 3.73 gears they're 15x10", 4.5"b.s., with MT ET Street radials in 315/60-15
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#17 |
60-66 Nut
Is your 12 bolt the original 62" wide or is it the wider '63.5" width used from late '70 on up? Are you willing to widen the inner wheel wells? What size tire are you wanting to run?
#18 |
15"29x15.5 , later 70&up
#19 |
#20 |
#21 |
Nope. Cut the bed back to the frame and run straight spring instead of a factory style.beehive.
Widened factory wheels. Posted via Mobile Device
-Automatics win races, 6-speeds impress high school kids -Save a tree, support your local dragstrip. -"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui columbuscarsandcoffee.net and on Facebook |
#22 |
![]() Join Date: Jul 2009
My rear tires are a 29/15.50 15 sportsman or a 31 10.5w on a custom Holeshot 16" rim with a 10" backspace. I ordered a new set of factoy rear wheel tubs and welded them to my old ones. My frame has not been moved and I ran the factory style spring with this setup.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ |
#23 |
do you guys think ill be able to run 295/50/15 with a 5.5 bs, on a 69 short bed fleetside (factory tubs) and have everything clear?
#24 |
#25 |
factory 12bolt and 15 by 10 rims with either a 5 or a 5.5 bs
i seem to remember that there is around 12 or 13 in the factory tubs. the truck is in the shop being painted right now and i dont have it here to measure |
